Driftwood Quantum X Settings, Series 1: v3b Rocket - v4b Orion - v5 β Pictoris
  • 1019 Replies sorted by
  • The HBR mode in 30fps land fails with battery pull on the new span my and V3 rocket with 95MB/s card. Wish I didn't need it but the broadcaster I work for wants 30fps.
  • @royfel OK, it got thru my death bush outside... I'll take a deeper look & readjust frame buffers more.
  • @driftwood Same panning as above with Rocket v3 now give me around 64 mbits and with a scene with more iregular motion close to 76 mbits. Thanks a lot. will also try Orion later.
  • I need someone to test the 25p out on v3 Rocket beta. @Tomaso was that 25p HBR you tested?
  • @driftwood I just tested 25p HBR on strays denser death chart and got battery pull after 1 second, whereas 24p just keeps going...
    hopes this helps ya
  • @driftwood, doing it now. do you prefer with 14-140 or with manual lens? pan or static?
  • Can somone tell me what the difference is gonna be with v3 and v4 in stead of the v2 ? is it even better or does it have other perks? I'm having a hard time getting the technical terms so if someone could explain it on dummy level.. thx!
  • First test with Quantum Rocket V3: I just shot 25 p HBR f 7.2 with shutter 160. Lumix-Leica 25 mm. lens. Record stoppes after a 30 seconds. Battery out
  • @driftwood Sorry, yes it was 25P HBR. I have tested all other modes as well with good result, but battery pull ones on FSH. Same panning. Sandisk Extreme Video.
  • tested1. HBR25p, 14-140@140, f14, ss125, iso200, 5600k, standard - STATIC tested2. HBR25p, 14-140@140, f20, ss50, iso200, 5600k, standard - PAN
    Sandisk Extreme 32Gb, 30Mbs
    posting framegrabs and mts soon soon.
  • Second test with Quantum Rocket V3. Now I'm using panasonic 14-140 lens. I'm getting the same results than lumix-leica 25 mm.: Record stopped after 30 seconds. Camera hangs I forgot to mention that SD card used is Sandisk 64 GB 95MB/s
  • First test with Quantum Rocket V3 HBR 25p mode using sandisk 64gb SDXC 95 MB/s card. Converted MTS file to prores. Looks great! Slow acceptable panning cause some stutter/cadence issues. Looking forward to try the CBR version.
  • Just did a quick handheld test with Rocket HBR V3 aiming the camera out against my window. Randomly it stops recording after a couple of seconds (resulting in battery pull). This happened at ISO 200, and sometimes when it works I can crank it up to ISO 3200 without any issues. If I first record a couple of secs in 1080 25p and then 720p it's fine most of the time, but sometimes the 1080p crashes before I get the chance to record anything. Even the Class 6 works sometimes, but all of the cards has a similiar pattern with the crashes.
    This happens both with HBR 25p and manual 50p. Sometimes it works, sometimes is crashes. I've tested Sandisk class 6 and 10 ( all 30 mb/s and 45 mb/s cards).
    Hope this helps! I'm probably doing something wrong here =P.
  • Ok, Think Ive found the issue. RC of Rocket v3 will be posted shortly.
    1920 x 1080 - 788K
    QuantumXv3_HBR_25p_iso200_5600k_s125_f14_std_MF_Pan14140@140_OISoff_Static.txt
    3K
  • Thanks all for this rapid testing... we'll have a final release candidate soon (RC)
  • @dirftwood, I am amazed. I just can't get the rocket to explode!!! Just the slight panning issue but even that for me is greatly reduced even from the earlier versions of Quantum I have used even in 24p. Really looking forward to try the CBR version and very very interested in the Driftwood Quantum X AVCHD-I 100/50.
    GH2 Quantum Rocket V3 Sandisk 64gb SDXC 95 MB/s
  • Ok, about to release 'Orion CBR' and 'Rocket v3 VBR RC' - final tests are going on.... :-)
  • Thanks for all your work man!
    Can't wait to get my hands on a stable 25p/50p setting with the driftwood mojo loaded in it!
  • Just back, damn battery was empty.
    and "Quantum X 'SpanMyBitchUp' v2b"worked without any problem.
    i HAVE ALL possible settings in the gh2 used, HBR. 24P in H mode, 300%, 80%.
    720p 50, in SH and H, with and without tele2, iso 160 to 800, shutter from 1/50 to 1/1300, white ballans clouds. auto and manual focus
    sandisk extreme hd video 32gb 30mb/s.
    I will edit my files and upload it perhaps tonight.
  • "Quantum X 'SpanMyBitchUp' v2b"
    1280 x 720 - 1M
    1280 x 720 - 1M
    1280 x 720 - 1M
    1280 x 720 - 798K
    1920 x 1080 - 3M
    1920 x 1080 - 2M
  • driftwood@
    Whats the best for 1080p (24p) ? Good work... ;P
  • @mozes Thanks for these screenshots. Looks like SpanMy... is holding up well. Are the clips overall looking good without probs?
  • FINAL Rocket v3 Release Candidate and Orion being uploaded right now. :-)
