Driftwood Quantum X Settings, Series 1: v3b Rocket - v4b Orion - v5 β Pictoris
  • 1019 Replies sorted by
  • @hunter thanks hunter!, so there is a problem with the patch cause your card is top line. what could be the solution to avoid crash after 12 minutes recording?
  • MTS playback's working fine for me in the new VLC 2.0. It drops a few frames when the clip first starts but it's solid after that.
    Just tried some shooting with my 32GB Transcend Class 10, got write speed errors after a few seconds in ETC and standard modes, 1080p/24H. This was using native m4/3 glass (the 20mm Pancake) so maybe manual lenses will fare better. My Sandisk 32GB Class 10 isn't giving any issues at all, so I will continue to use that.
  • @chauncy Can you include the type of detail in image you are filming with the streamparser charts? Use the playback and pause it on where the frame drops, then screen grab?
  • @driftwood results are virtually identical with lumix(non x) 14-140 lens. Even with manual focus. Errored quicker if anything. Chart below with frame drops from 14-140lens. 95mb card in 720p 60
    Quick test with voight 0.95- seems very stable over 1 min test. with 20mm lumix. stable also with mf and af. Changing light, moving camera.
    all with 95mb.sec cards
    1296 x 680 - 131K
  • @towi Film Strays death chart on your monitor on v1.1 and dropbox me mts files, I'll take a look at them.
  • I will test out HBR/25p in the city today.
    Why is the frame and buffer limit so much smaller for the settings that affect HBR?
  • @dritwood
    upload what? The Streamparser graph or the actual file?
  • Brilliant reporting @chauncy, I'll get down to this tomorrow, thanks mate. I havent got an X lens yet to demo on so Im relying on you.
  • @driftwood
    thanks for the info
    just watched the video of guy building one.... looks a beast!
    i did not know anything about hackintosh before this...
  • Just a note I've seen the shutter freeze on my x 14-45 when zooming in 720p. It's different than anything seen before. The display just freezes with no error and have to drop battery to get out of. Saw it twice in 50 tests.
    I have tested the frame drop on a 30mb/sec card and saw it again.
    I formatted all cards prior to use. The frame drop is not just one time but occurs randomly across the clip. In the pic you can see it happens twice, happened 4 times total over 20 sec clip. It never happens right at the exact end.
    There were two clips out of ten that I saw no frame drop but they still write errored. So frame drop may be red herring.
    I also could get a longer clip before fail time at lower isos.
    with the 95mb/64gb card: Using 14-45 x lens With manual focus and no zoom. Just holding camera i went 45 seconds with no error. As soon as I changed focus(manual)- write error.
    at 720/50 like a rock. no fails with 95mb card no fails with 30mb card. No frame drop seen.
    1296 x 657 - 129K
  • @Mr_Moore Defo change the card.
  • GH2 user here. 24H just failed to span on a Transcend 16GB Class 10 card. (Wouldn’t play back in camera either.) Canon 50mm ƒ1.4. Trying 24L now.
    24L spans without problems.
  • @towi Show me. Stick up stray's death chart on your screen and film it on any of those 'settings' and upload it. I think Chris's are the only ones which are fine - but thats not on v1.1 yet. Don't forget he's working on new settings and so is Lee so you guys can only benefit. :-)
  • "I was waiting for this one... Name me one patch that doesnt do that? Indeed, most fail after a few seconds."
    I don't want to bother you ;-) ... I am testing all your patches... everytime you release a new one. They are absolutely phantastic for 24H but the all fail in FSH (and HBR). Still waiting for an Inra patch from you that can do reliable, clean FSH/HBR.
    Patches that do not fail in FSH (and therefore most likely also work in HBR mode)
    cbrandin 44M
    cbrandin 66M
    zero adverse effect patches
    Patches that definitely work troublefree in HBR at great quality:
    Flowmotion
    Sanity
  • Not to seem ungrateful I had two lock ups (out of 12) with HBR 95MB/s card.NTSC
  • @sid much cheaper than buying a slower mac. seriously.
  • @towi I was waiting for this one... Name me one patch that doesnt do that? Indeed, most fail after a few seconds. Also, as I mentioned this morning, I have two other variations of Quantum X (v2 Rocket)... more info tomoz.
  • @driftwood
    wow sounds expensive pro stuff!
    i was thinking just a mac with a i7 and 8gb ram would do me
    i only do small stuff at the moment
  • The examples I posted earlier are 25p HBR stuff.
  • "I would love someone to upload a top quality HBR mode video... any takers?"
    I would love to do so ... but in HBR mode (25p) shooting the codec stress chart I-frames go down to around 360Kb. Lots of mosquito noise... and the codec is "pumping" (like noise on/off)
  • @sid 8-core Hackintosh with multi-boot win7 drive using 'Chameleon' - much better and faster than latest Macs. Testing Apple's new OS, OS X 'Mountain Lion' on my hack later tonight...
    Google hackintosh or insanelymac.
    Most computers of the last few years should be able to playback these mts files though ... just get the right codec... there's quite a few out there.
  • @driftwood
    how powerful is your computer?
    mines struggles... need to know what spec to invest in for better editing
  • I would love someone to upload a top quality HBR mode video... any takers?
  • @Driftwood: That shutter freeze is what I have been seeing when I use Clip Wrap to wrap the file as 25p. Files play back fine when imported as Psf. Weird but I am sure you're used to that :)
