no grading or correction.
720, hbr and 24p on the same timeline, and renderd to 1080p 23.97fps
It has almost completed. I am just going to verify in both PAL and NTSC now. :-)
@bkmcwd cool, will try your next candidate then once you upload it (hopefully soon).
"you did already change really a lot between Candidate 2 and Candidate 3"
Yes, however, it seems that the former GOP tables are better. :-(
I am changing back them now.
i forgot to say, tele2 works also....
i am render a clip now, 3:30min, it makes things perhaps more clear.
you did already change really a lot between Candidate 2 and Candidate 3 ...
Thanks for your report!
"TYPE-ZERO2 candidate2 setting"
Since it is a matrix slightly more aggressive than others in HBR of Candidate2, the matrix of Candidate1 has been inherited in Candidate3. I think that Candidate3 is better than C2 also in HBR.
Please feedback tomorrow! :-)
Many thanks for feedback! :-) About 50p, I will tweak a few. Just a moment...:-)
@bkmcwd shot 36gb today with the TYPE-ZERO2 candidate2 setting. froze twice in HBR 25p, but that wasn't a big deal. ExTele worked without problems. I only looked at a couple of shots quickly and they look really good. Tomorrow we gonna import them into PP CS6 and have a closer look.
Maybe I'll try candidate3 tomorrow...
I did not change any off your setting.
it looks like the changes you did in goptable setting x2 did the trick.. ;-)
card used is a Sandisk Extreme Pro 32gb 95 mb/s.
Datarate.
720 +/- 65mb to 75mb (SH)
hbr +/- 45 to 65mb (H)
24p +/- 70 to 118mb (H)
300% 75 to 90mb (H)
Thanks for your report! :-)
Yes, also in my test, it often freezes with cards other than 95MB/s SDXC. It is normal for this setting.
However, since it may somewhat be too aggressive, I readjust slightly in 50p.
@bkmcwd Camera is often freeze at SanDisk SDHC 32GB class 10 32mb/s . SDXC is no problem excellent!
Which card did you use? And is 720p modified from my setting by yourself?
how is that posible, al pictures are placed random ????????????
and i mis 2 images??
1x the gh2 freezes in 720 mode, and i dont no why? .
all other times there was no problem................
300% record did not give any probs in H mode.
but higher then iso 1600 is a no go, that will say, for so far in what i tested.
there is a lot of noise/grain then..........
i did try to shoot 720p, hbr and 24p in exact the same shot....
lens was set 22mm to 55mm for the different shots..
I will edit the video, and see what happens then...
btw, all is done in the highest settings..
@peternap Thanks for feedback. Since especially I improved so that the matrix of Chris could be used in 720p this time, I am glad supposing a result is good.
"I think low light will be the deciding factor."
Interesting! :-)
I just started but the usual keep it or not shots in 720 and 1080, look good. The 720-60 looked especially good and this was freehand. Color is good in standard -2 I think low light will be the deciding factor.
Many thanks for feedbacks!
"I even reduced the 24L to 88M from 118M for lower storage alternative and it still provides great quality."
Very interesting. I will also try. :-)
"With the same profile settings as i have done in Valkyrie 444 TYPE-ZERO2_Candidate2"
In my judgment, I think that as it is may be sufficient about 720p encoder settings. However, I am very interested also in your result. :-)
@bkmcwd Then will i do it in . 1080 24, HBR and720-50, tonight from a Sunset.
@bkmcwd. I tested your latest settings on all modes using Panasonic 14-140mm and Sandisk 64GB 95mbs. All recording modes worked fine with great image quality. I even reduced the 24L to 88M from 118M for lower storage alternative and it still provides great quality. Thanks for your hard work.
I am very interested in your results. :-)
@bkmcwd I'm going to look at the big three today. 1080 24, 720-60, and very low light.
Many thanks for feedbacks! :-)
Instaling as im writing... i´m going to do some tests today and post. Thanks!
UPDATE(12/09/2012):
I released 4th candidate of following Valkyrie 444 TYPE-ZERO2 AN.
bkmcwd Valkyrie 444 TYPE-ZERO2 Candidate4 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix' - Setd.ini - Released 12/09/2012
http://personal-view.com/talks/discussion/comment/84273#Comment_84273
*Please use new Candidate4 rather than Candidate3!
bkmcwd Valkyrie 444 TYPE-ZERO2 Candidate3 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix' - Setd.ini - Released 11/09/2012
Since "TYPE-ZERO1" released previously was not good in other than 24p, I made experimental 3rd candidate setting for HBR mode and 720p.
I reduced artifacts in HBR and 720p, following the pure original matrix of Chris as much as possible.
Please try this. And I am very glad if feedback can be got.
Special thanks to @har_k and @syoushow! :-)
Of course, thanks to @cbrandin and KING @driftwood!
Superb-looking simulated 444 matrix from cbrandin
Modified 444 matrix from my BETA Team in Japan is adopted in HBR/1080i modes.
Upto 140M for Top Quality 1080p24 at Q18
Upto 140M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
Upto 75M for Top Quality HBR/FSH modes
Upto 75M for Top Quality 720/50p modes
Upto 55M for Top Quality 720/60p modes
Extremely reliable top performance in AVCHD 24H and 24L
80% Slow-Motion is available in 24L only
Fully working iA and iDynamic modes if you require them
Beautiful 3 GOP bringing short GOP style detail & movement-rendition in 24p
Bush of Death / Death chart tested.
Wonderful Pasadena Pulse Audio Patch V2 B2, by Per Lichtman
Top quality 2K mjpeg Mode in HD by Nick Driftwood
In camera playback is sometimes not available in 24p. In other mode, available after reboot the camera.
I am preparing the release now. Writing explanation in English requires time for me rather than making a setting. LOL
