AN "Valkyrie", GOLGOP3-13, GOP3ZILLA, natural, Freeze-less Reliable All-round GOP3 Settings :-)
  • 1001 Replies sorted by
  • 1x the gh2 freezes in 720 mode, and i dont no why? .
    all other times there was no problem................
    300% record did not give any probs in H mode.
    but higher then iso 1600 is a no go, that will say, for so far in what i tested.
    there is a lot of noise/grain then..........
    i did try to shoot 720p, hbr and 24p in exact the same shot....
    lens was set 22mm to 55mm for the different shots..
    I will edit the video, and see what happens then...
    btw, all is done in the highest settings..
    1280 x 720 - 1M
    1280 x 720 - 1M
    1920 x 1080 - 2M
    1280 x 720 - 1M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 3M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1280 x 720 - 1000K
    1920 x 1080 - 2M
    1920 x 1080 - 3M
    1920 x 1080 - 2M
    1280 x 720 - 904K
    1920 x 1080 - 2M
    1920 x 1080 - 2M
  • how is that posible, al pictures are placed random ????????????
    and i mis 2 images??
  • @mozes
    Which card did you use? And is 720p modified from my setting by yourself?
  • @bkmcwd Camera is often freeze at SanDisk SDHC 32GB class 10 32mb/s . SDXC is no problem excellent!
  • @hi1130
    Thanks for your report! :-)
    Yes, also in my test, it often freezes with cards other than 95MB/s SDXC. It is normal for this setting.
    However, since it may somewhat be too aggressive, I readjust slightly in 50p.
  • I did not change any off your setting.
    it looks like the changes you did in goptable setting x2 did the trick.. ;-)
    card used is a Sandisk Extreme Pro 32gb 95 mb/s.
    Datarate.
    720 +/- 65mb to 75mb (SH)
    hbr +/- 45 to 65mb (H)
    24p +/- 70 to 118mb (H)
    300% 75 to 90mb (H)
  • @bkmcwd shot 36gb today with the TYPE-ZERO2 candidate2 setting. froze twice in HBR 25p, but that wasn't a big deal. ExTele worked without problems. I only looked at a couple of shots quickly and they look really good. Tomorrow we gonna import them into PP CS6 and have a closer look.
    Maybe I'll try candidate3 tomorrow...
  • @mozes
    Many thanks for feedback! :-) About 50p, I will tweak a few. Just a moment...:-)
  • @Tobsen
    "TYPE-ZERO2 candidate2 setting"
    Since it is a matrix slightly more aggressive than others in HBR of Candidate2, the matrix of Candidate1 has been inherited in Candidate3. I think that Candidate3 is better than C2 also in HBR.
    Please feedback tomorrow! :-)
  • i forgot to say, tele2 works also....
    i am render a clip now, 3:30min, it makes things perhaps more clear.
    you did already change really a lot between Candidate 2 and Candidate 3 ...
  • @mozes
    "you did already change really a lot between Candidate 2 and Candidate 3"
    Yes, however, it seems that the former GOP tables are better. :-(
    I am changing back them now.
  • @bkmcwd cool, will try your next candidate then once you upload it (hopefully soon).
  • @Tobsen
    It has almost completed. I am just going to verify in both PAL and NTSC now. :-)
  • no grading or correction.
    720, hbr and 24p on the same timeline, and renderd to 1080p 23.97fps
  • Just tried out the patch.
  • UPDATE(12/09/2012) Since mistake input was in the setting of Candidate4, what was corrected is set to "Candidate4.1".
    bkmcwd Valkyrie 444 TYPE-ZERO2 Candidate4.1 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix' - Setd.ini - Released 12/09/2012
    "TYPE-ZERO1" released previously was not good in other than 24p. And, TYPE-ZERO2 "Candidate3" is too agressive in 720p mode. Therefore, I made experimental 4th candidate setting **for HBR mode and 720p.
    *In 720p, Candidate4.1 is safer than C3.
    I reduced artifacts in HBR and 720p, following the pure original matrix of Chris as much as possible.
    Please try this. And I am very glad if feedback can be got.
    Special thanks to @har_k and @syoushow! :-)
    Of course, thanks to @cbrandin and KING @driftwood!
    • Superb-looking simulated 444 matrix from cbrandin
    • Modified 444 matrix from my BETA Team in Japan is adopted in HBR/1080i modes.
    • Upto 140M for Top Quality 1080p24 at Q18
    • Upto 140M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
    • Upto 75M for Top Quality HBR/FSH modes
    • Upto 70M for Top Quality 720/50p modes
    • Upto 55M for Top Quality 720/60p modes
    • Extremely reliable top performance in AVCHD 24H and 24L
    • 80% Slow-Motion is available in 24L only
    • Fully working iA and iDynamic modes if you require them
    • Beautiful 3 GOP bringing short GOP style detail & movement-rendition in 24p
    • Bush of Death / Death chart tested.
    • Wonderful Pasadena Pulse Audio Patch V2 B2, by Per Lichtman
    • Top quality 2K mjpeg Mode in HD by Nick Driftwood
    • In camera playback is sometimes not available in 24p. In other mode, available after reboot the camera.
    *Please DL 2nd ini file! 1st one is not good.
    bkmcwd Valkyrie 444 TYPE-ZERO2_Candidate4 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix'.zip
    1K
    bkmcwd Valkyrie 444 TYPE-ZERO2_Candidate4.1 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix'.zip
    1K
  • @mozes Many thanks for feedbacks from you and beautiful sample footage! :-)
    @Shishboombah Thanks for testing Valkyrie! How did you feel? :-)
  • @bkmcwd I think its very good !,looks great..gonna try the new patch you just posted.
  • @Shishboombah Thanks! Please tell me comment again. :-)
  • @bkmcwd We like reliable high quality setting of Japan. I expect the team of you and Japan thanks always!!
  • While I know there are newer versions, here's a little vid of the GOP3ZILLA Beta 3 shot with a macro lens and combination of shot at 24p and slo-mo 60p, with most shots in ex-tele mode, which works fine in iso160 and a bit noisy as 320. Only light grading done.
  • @hi1130
    Welcome!
    In this forum, a year ago, although the camera was made in Japan, I was almost the only Japanese. As for me, it is glad that the Japanese who can arrange a setting other than me have increased in number recently... Many thanks. :-)
    @atothek707
    Thanks for very good footage with GOP3ZILLA! The countenance like Philosopher of a lizard and the beauty in nature are wonderful. :-)
  • Now, I am tweaking in order to improve TYPE-ZERO2_C4 slightly. Probably I am going to release C5 during this evening. :-)
  • NEW!
    bkmcwd Valkyrie 444 TYPE-ZERO2 Candidate5 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix' - Setb.ini - Released 12/09/2012
    "TYPE-ZERO1" released previously was not good in other than 24p. And, TYPE-ZERO2 "Candidate3" is too agressive in 720p mode. Therefore, I made experimental 4th candidate setting **for HBR mode and 720p. Furthermore, I release "Candidate5" which changed in the Deblocking tables of C4 slightly and was retuned up.
    *In 720p, Candidate5 is safer and better quality than C4.
    bkmcwd Valkyrie 444 TYPE-ZERO2_Candidate5 'Apocalypse Now' with cbrandin 'Pure Original 444 Matrix' and 'Modified 444 Matrix'.zip
    1K
  • @bkmcwd Does C5 only improve 720p?
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
