GF2 Stable Settings
  • 614 Replies sorted by
  • Looks great. I think it can use some color grading through :)
    Good luck with the film. I'd love to watch the entire thing (especially if it's filmed with the GF2).
  • FILM LOOK on GF2... We have now begun shooting a low budget Feature film on location in New Zealand. The below clip did not have any colour correction or grading. Simply assemble-edited using Sony Vegas. All the footage is GF2 running PVDOG at approx 40Mbps (PAL) with the standard Panasonic lens. I am so happy with the look of this footage that I will gladly shoot the whole movie this way. Please forgive the Youtube compression. Hopefully you can still see it OK. Would appreciate your comments-
  • AlbertZ, I don't have any 550d or 600d footage to compare to , but yes the GF line is softer than the GH2 not much but softer yes.. still has tons of detail.. if you like a filmy look try mysteron or other all intra patches, they seem to feel more film like to me, slightly more fine grain is seen and just seems to look like less than 30FPS. The biggest thing at this point would be the lack of manual controls, it can be worked with but makes it challenging.. however if this gets fixed by VK these are going to be hard to beat for a high end camera with great footage and dirt cheap.
  • I am a 16mm look lover, amd I think that GF2/3 really have that soft look! However, do you think that GF2 hacked video quality can beat canon eos 550d/600d?
  • Having a good ND filter I do consider a must have especially if you like shallow DOF outdoors. in the test I did on pvdog at the lake I had a shot of the pine brush with shallow DOF, no way in heck you could get this shot any way but with a ND filter, best is dedicated ND filters using a system like the cokin filter system.. but I use a decent variable ND filter.. I think this is the one I have. low cost but decent results. It works good but wish I invested in the cokin system instead... the cokin system is on my (very long) list of stuff to get. http://www.amazon.com/Polaroid-Multi-Coated-Variable-Neutral-Density/dp/B004GYXRRE/ref=sr_1_12?ie=UTF8&qid=1333776330&sr=8-12
  • JayB38 :))
    603 x 716 - 216K
  • Thanks @Ebacherville. I just did a shot not too long ago, and I notice that I might need an ND filter or another adapter with the aperture ring. I was going to try out my Anamorphic lens adapter and do some shots.
    Also when I shoot pictures, the overexposure is not there. Pure clean shot, picturewise. Oh well, you live and learn.
    Here's a test shot, using pvdog's settings.
  • JayB38, the footage in my above post was without ND filter, but my lens was stopped down to F16 and it was about 6pm so the sun was not at its brightest and overcast slightly.. if your fully stopped down and your still blown out, then you need a ND filter... or if your trying for shallow DOF in bright conditions, that's the main reason I use a ND filter is shallow DOF in bright conditions. most of my lenses can stop down enough in bright conditions for general shooting needs.
  • Is it true that one needs an ND filter for non Panasonic lens (Canon series), in doing day scenes. I tried to shoot something with my Canon EF 50mm 1.8II with a Fotodiox adapter and shooting a day scene, it's all white. Maybe it's an aperture situation, I don't know.
  • Testing a new mix, I barely had time to shoot some video today (AVC 1080i60). Still... I prefer seven two O mj for serious stuff. Can't beat the progressive quality.
    edit my apologies, I meant to post this on the 'Hacked GF2 footage topic' thread
    1920 x 1080 - 1M
    1280 x 720 - 1M
  • New favorites settings .. If i need spanning Flowmotion 1.11, and if I don't need spanning Mysteron I'm going to test these on the waves on the water test and see what they can do.. Once you try Mysteron on GF2 or GF3 you know what this camera can do. The Mysteron footage I took today steller stuff. Unreal a 200-250 dollar camera can do this quality of stuff. Footage from today with Mysteron, don't know why I bother since YT bit rates are 4.3mbits/sec, 95% of what the original is.
  • @Rambo , great tips, please can you explain in more details the "understand the trigger points" ?
  • Shot it slightly flat -1, -1, 0, 0, actually lowered brittleness a bit and poped it up a bit in contrast in post. All the outdoor stuff was on a Rokkor 50mm F1.4 (30 year old manual lens) with a cheap MC to micro43 adapter.
    really sharpwhen its stopped way down..
    I was going for a bright film look , crushed blacks and bright feeling. I typically go for that look...
    The package shot was on the 14mm f2.5 panny, indoors, as I needed auto focus because, I do all my own stunts..
    I really like this Flowmotion 1.11 Patch , very nice compromise of quality and reliability, it will have to beat out pvdog at the lake in image quality, but it is in my top 3 of everyday do anything patches at this point.
  • pdlumina, good for you, but why boast about it then not explain when asked, that's what creates doubt.
  • @Rambo I don't, only the stock Panasonic lens that came with the camera. But it's OK to doubt. By proving anyone wrong I gain nothing, so I'll continue to tweak my settings and posting results here.
    @Ebacherville that some nice looking footage there. Did you punch the saturation or/and contrast a bit? What sort of lens do you have?
  • pdlumina > @Rambo I'll explain what I mean with a video in the future. I really have selective iris that can be changed while recording with a GF2, with manual 'trigger points' as you call them. In the meantime, a few shots from today.
    No kidding, we all have canon or nikon adapters with aperture control rings too, big deal.
  • @chief OK :-(
    very unscientific quick test. Night, indoors, single 60Watt bulb on ceiling, AVC 1080i60 converted to 720 MP4 for web, iris wide open, 1600 ISO, stock lens. Attached stream analysis of said video.
    http://minus.com/mgklKdWe/1f
    680 x 875 - 383K
    1240 x 608 - 56K
  • Flowmotion v1.11 video sample.. walked to the mailbox to check the mail
  • I just found something interesting , got my GF3 body today and in M mode , with a manual lens, once you start the recording and then close the aperture after recording , it does not seem to adjust ISO.. Was just a quick finding messing around.. anyone else have a GF3 they can test vs a GF2? Maybe I'm wrong and it was just because I had a lens that went to absolutely closed on it .. just the GF3 seems to handle it far better.. the GF2 got super noisy before absolutely closed.. GF3 didn't get nearly as noisy
  • @pdlumina your posts remind me of "Lost" - one big teaser with no real ending
  • @Rambo I'll explain what I mean with a video in the future. I really have selective iris that can be changed while recording with a GF2, with manual 'trigger points' as you call them. In the meantime, a few shots from today.
    1920 x 1080 - 2M
    1920 x 1080 - 5M
  • Tested Flowmotion v1.11 tonight, medium bit rate, nice looking video, stable, and spans. going to lake test this one too.. Video sample coming soon.. rendering right now..
  • Hello all. I decided to post this on YT - I did a shot last week using pvdog's settings. Quite impressive so far. I did all editing effects on Sony Vegas MS11.
  • The closest we have to ANY control so far is what i show you in this video and you need ND and understand the trigger points.
  • lol. We won't have manual settings until VK says we do :)
