Thanks for the feedback. I tried an alternative card; same issue (scandisk 16 gig 30mb extreme). However, it's not the recommended high performance 95mb card. This is why I didn't even try Sedna Q. So... I'm back tracking to QUANTUM v9c. It seems to be doing better with the external hdmi monitor so far. What is the consensus for a generally good performer on these lame transcend (32 gig class 10) cards. I have like 8 of them.. So..
@edgenumbers No problems with camera movements.
Few cameras/codecs can take this (sorry for post it twice):
@xavieramelio There is something wrong with the Prores files exported with 5DtoRGB. I don't know what but, for example when you try to conform a file with CinemaTools, the application can't do it. It says that the file contents "Temporal compression", so basically that the codec is not Intraframe. That makes no sense.
I asked the people at 5DtoRGB and they recognized the problem but were unable of giving an explanation.
@adcockstudios Since 24p is always output in some strange pulldown sequence via HDMI, I'm sure it's imposing additional load on the processor. Settings like Sedna are carefully tuned to push the envelope and this extra load may drive it over the edge.
@xavieramelio Could be that the kBts/s of the files are more than your hard-disk speed?
The motion is fine and is actually improved with driftwoods settings since they are all i-frames. There are no motion vector frames to cause perceived smearing.
@adcockstudios I haven't tried it. I've been having a ball with this little camera and no rig. It wouldn't surprise me to have that problem, especially with Transcend cards. Some of the settings have caused issues with HDMI. There is a limited amount of processing power in the camera and I can see whee the added strain of hooking a field monitor could fill the buffers early.
Just to see, try a different card. That solves a lot of problems I've had.
I am using Sedna C Q20, All is good in camera, I can watch and play the clips fine, when I transcode to prores 422 using 5dtoRGB, I play the QT files and I get a jumpy image around the 8 seconds (sometimes more) into the clip, when I use the file in FCX my sound goes in and out constantly during the clip. Anyone experiencing this? Any suggestions? Please some help!!! thank very much for any solutions.
I have been following for a while. Has anyone else experienced shorter record cycles when using an external monitor such as a SmallHd. I've been testing the most current version of Orion 4d (black matter). All is well until the external monitor is plugged up. 24P H record times go from a usable time (4 minutes and going) to less than a minute which makes this update unusable for me. :(. Keep in mind I'm using 32gb transcend class 10 cards. I'm sure this doesn't help. I'm open to an feedback or suggestions.
He isn't gonna post it until he's happy with it...Thankfully!
Patience.
Please tell me Where is Cluster v2?
For me atleast, somehow Vimeo always shows video a bit stuttery. Don't know why this is. Youtube doesn't.
@AmandaNL, Sorry. Yes, you are right. The stock firmware shows the same issue. This is not a complaint about the excellent work done by people like Vitaliy_Kiselev, driftwood, bkmcwd and more. :)
@edgenumbers The "problems" you see, aren't these just because you're shooting 24 fps? With the stock firmware you get the same effect when panning.
@thepalalias, Are you shooting HBR 25p? I think you can see what I am talking about in L1N3ARX's vimeo clip posted above.
@L1N3ARX Though, do not let the desire to compare that motion interfere with D800 comparison you mentioned. I think most would find that more important. :)
Would either of you mind posting comparison clips between the patches with the motion you prefer and those you do not? It might be helpful because I have not noticed the negative effect in any of the recent patches in the hundreds of clips I shot with them.
@L1N3ARX, I can see you have the same problems I do with all of these hacks/patches and I mean all. They produce amazing image quality but try and move the camera....oooof! Panning, even nice slow pans produce stuttered motion at some point in the motion. Some seem better than others. Have you tried "Driftwood Quantum X 'SpanMyBitchUp' v2b"?
Finally I found some time to make some macro shots with Sedna A Q1. I´m stunned with the quality. The detail, the noise... Wow. I´ve had some writing errors in ETC mode, but I knew they would occur. Here are three short test clips. Actually they say nothing about the hack, because of the compression. Please fill in the quality gaps with your own imagination. Before the hack I never thought of using 720p, now I love it.
After trying out the different Sedna options, I can't help but revert to Orion v4b, I freakin love that patch and I don't even know why. For some reason, it just seems like it produces the best motion and detail combination of the Driftwood's patches. Here's a quick test with a super crummy lens that was covered in dirt and practically falling apart, but it turned out okay.
Ok here's the footage I was talking about above"
Bee footage- Stock lens 14-140mm and Driftwood Seda. Hand held on full zoom and teleconverter mode! 24 cinema mode about 80Mpbs, other setting were crashing due to my 30Mbps card. Looks fantastic in 1080p
@rajamalik Glad it is working well for you. I have been shooting stills the last couple days and look forward to getting back to video again soon.
@driftwood Looking forward to Canis Majoris!
