Would anybody please check-out if remote (wire or wireless) after fw update now wakes up GH2 from econo mode? Maybe Pana has fixed it without a word, just like a mic input...
If you want to save time with workflow, MainConcept plugin for CS5 (works with 5.5) is awesome, you could use the MainConcept rendering engine (both software and CUDA) or you can stick with Mercury, plus what is -really- great, is the CUDA H.264 output encoder. It is fast (on my GTX 260 even,which I had to edit the text file for support for).
if you look at the light on rail (ground) it' "pulsating" and colors bleeding (v1) ... however it would be best to have both footage in mts for download in order to compare ...
@ chef your Samyang-Skater has just what i missed in 24p. Only one picture more and to me it moves far more in a smooth but also clear direction. With 24p the similar motion for me looks allwas hard an jerking. So not only for 50Hz lightning reason 25p is quite usefull. To my eyes in fast "moving" situation its definitely better.
I agree with balazer, its only lighter, no diffrent quality. And on the vectorscope you can see that the llights at the cone are allready clipping. Try to read the electronic signs in the light version on the right side, maybe for train, tram or something. Would be interesting to see if there is realy any difference with the same lightning impression. And how much aperture or ISO i will spare for the same impression with the same lens on the same scene. Seems like you have two GH2. So it would be graet if you could make such a test :-)
@amateur: Is it just me, or was there HORRIBLE compression on that last one? Firstly there was so much aliasing, almost at Canon level. Secondly the sky was extremely blocky from low bitrate. Doesn't look like in-camera compression, but rather the person who uploaded it.
@amateur: you can see the light flicker in the left one, it was clearly not a shutter which corresponded with the frequency the lights on the tower flickered at. in the right one it is. No flicker. So they were different shutter speeds. which of course can account for the brightness difference. :)
but will be interesting to find out if there is really more detail resolved in the high ISOs.
@ Vitaliy A question: Once the porting ptools on the new firmware 1.1, we can still use the old one (1.0) or have to use an old version of ptools? I ask because some friends who have tried the new firmware are not happy, especially for the noise at high ISO.
