There has been various reports from P-V users that the new 95mb/s Sandisk Extreme Pro SD cards are fast enough for previously un-span-able PTool settings to now span.
@Jspatz reported earlier today that he was able to achieve spanning with @driftwoods SeAQuake on a 64GIG Sandisk Extreme Pro 95Mb/s. This is HUGE news!
>Ed Lee confirmed that his 32gb 95MB/s failed to span. Its safe to assume that the 16 and 8 will perform likewise. >Only the 64gb is labeled as 'SDXC'.
UPDATE 2nd Dec 2011: @itimjim >I can confirm that the card (95MB/s 64gig) spans with SeAQuake
I filled the entire card, 57 minutes worth until it stopped by itself. 16 files. They do not play back in the camera like the single clips do.Each file loads all the others in Premiere pro. So if I load #1 it is 57 minutes long and If I load #14 it is 57 minutes long. In Windows media player, some files come in as singles, some as themselves plus the higher numbered ones and some as the total length. If I rename the files, they behave as individual files about 3:50 in length each. They all seem OK and usable.
80% mode should not be expected to work with SeAQuake. 80% mode increases the frame rate and bit rate by 25%. Driftwood made Aquamotion with lower frame limits and bit rates specifically to account for the increases of the 80% mode.
(Sorry @Sage; @FGCU, I don't want this thread closed- I just want to keep this thread about the newest 95MB/s as the reports that are coming in are CRAZY! In a good way...)
@sohus I thought that it also needs to be moving... hence filming the TV... (when I have filmed a LCD screen that was sometimes as good as a deathchart anyway- as there are SOOO many pixels to draw)
I filmed a 30" monitor with wildly moving moire producing 150 MBits and it spanned. Also figure eight motion on tree clusters a high shutter speed on pancake. I will try death charts.
@sohus, if that failed to f*(#k up the spanning, then I don't know what would have. @Jspatz how did you get this card before EVERYONE else... ?? Who do you know?? I want the number! ;-)
@chrimsbroome we all should be getting one! But remember that this will ONLY span for 1 day before @driftwood has had his evil way with it... bu ha ha ha! (also - super cheap at B&H- only $190!!- how do they do it SOOO cheap?)
Driftwood, this card is king. Perhaps a terraquake-like patch could be made to allow 80% to record seaquake style quality to this card? I personally don't need spanning with 80% (just w/ 24p), but I do want to be able to record 80% in seaquake quality. ;)
@oneday to make it easy all of the 95Mb/s Sandisk cards. 8, 16, 32, 64 (64 being the only SDXC) The only card currently reported to span is 64gig, (I believe this is the only one that has been tested). Personally 64 is great for me and spanning! (As expensive as the 32 one I bought here in Australia! Darn!) :-D
Amazon's return policy is easy and liberal. Press a button, print a label. Give to mail carrier. If you don't like quality they pay the return shipping. I have never had a bad card from them.
I just got my Amazon card and it is fine. It even seems about 3-5% faster than the one I received from B&H last week, although my testing is not scientific. The first card clears the write buffer after a full burst of high quality still in about 21 seconds. The new card seems to do the same job in just under 20.
