@jaecjaec: Thanks a lot for this! What you're referring to as the professional model, is the same model, but with the follow focus, mattebox, monitor and battery, right? Was the monitor included? How's that quality? (sorry Vitaliy if you consider this off-topic)
@Retina. You're correct. The professional model is the economy package in the deal here, plus the follow focus, matte box, battery system, monitor, and case. The monitor is the same as the Liliput 678 which has favorable ratings. Look it up on Amazon.
I have ordered and payed the rig last wednesday and never heart anything from them so far. No confirmation, no shipping notice, no answer to my mail... Should I start to worry? Has anyone else received the rig already?
@spreegurke It is ok. Most of the guys had been at BIRTV. But your rig must be shipped already. Send me PM with your paypal address, I'll try to check with seller.
@Vitaly thanks a lot. i'm already in touch with the manufacturer by skype (through alibaba). very kind contact and he's sending me the whole package tomorrow including straight & offset :)
Received my rig today. It got stuck in costums, because they declared to little value on the invoice, so I had to send in the PayPay receipt...
However, the AF100 fits into the C-Clamp of the rig, if you remove the camera handle. All in all the system looks OK for the money, but I came upon one problem. You have to tighten the ball-joints of the hadle-bars quite firm in order to prevent them from moving, when you operate the rig. The little handles which you use to tighten it up have the screw-threats supposedly only screwed and glued in. So when I tightened it, the threat got stuck to rig, and I can not open/remove it without any tools. So this is nothing you would want to happen on a shoot. See pictures attached.
Also they send me the Offset Clamp, but I ordered straight.
Payment for personal-view.com rig deal - straight This is the paypal title, so I thought the straight you said were the straight version. We will double check the handle problem. Anyone get the problem will get the new handle which lock tighter, I will upload the 3D render on monday. Sorry for the issue again, we will fix it.
@spreegurkespreegurke I am starting to develop the same problem on my handle after a weekend of shooting. I thought it was my fault b/c my rig is heavy and sometimes I'm not too gentle with it. But seeing that you have the same problem I think perhaps there is a problem with the design. I've contacted Lanparte and he's promising a solution.
@lanparte The problem is not where the screw goes into the plastic lever. It appears that the rubber gasket material that holds the ball joint is not strong enough. Not sure if there can be an easy fix for that.
right, that seems to be the problem. After tightening and losening the ball joints a few times, they can't be locked firmly anymore.
Take a look at the picture here. The screw does not drive directly into the ball joint. It drives a piece of rubber into the joint to create friction. It may work OK for a couple of times, but I think the aluminum chews into the rubber and makes it loose its grip.
Hi guys. We found the problems, there is do have a little problem of the handle joint. (the ballhead with thread and the rubber washer works weel)See the following pics. We will use a stainless steel ring to solve this probelm. Our engineer made the ring, our worker will finish it tomorrow, we will try it as soon as we get the part, we do believe we can fix it. We are so sorry to bring you this kind of problems, we will delivery the new handles to you immediately after the test.(of course we will make sure this solution works) if this solution failure we will give the latest handle to you which can totally overcome this problem, I will post the latest handle tomorrow when I back to my office.
