24H and 24L are set to the same values as FSH and SH. (first setting file 32/24, second setting file 24/18). If i now flash the first firmware and record a movie in 1080i 24Mbit FH, then flash the second one and record with 24Mbit FSH, is there a difference in quality?
@swen24 First. Read hints. You need to have 24H checked. Always, if you use any bitrate patches. Other patches won't be applied if 24H is unchecked. Second, that exactly "first setting FSH 32MBit/FH 24MBit and second setting FSH 24MBit/FH 18MBit" mean?
If i have two different setting files for bitrate in Ptool 3.62, like first setting FSH 32MBit/FH 24MBit and second setting FSH 24MBit/FH 18MBit, nothing else checked but AutoQuantizer Mode 2. Is then FH 24MBit exactly the same output quality as FSH 24MBit?
How about higher resolutions than 1920x1080 in MJPEG mode ? How far can we go ? It would be wery usefull to have some stabilization and framing correction space around a 1920x1080 crop.
@rigs VK has mentioned before that the GH2 is very different in its AVCHD (which is were most of the work is now). I have a feeling not much, (possibly the PTool Software?)
