Sometimes i try to record a video but the camera says my sd is too slow or something similar (i dont use english language on it). My sd card is a uhs-1 u1 32gb sdcard (kingston sd10g3/32gb)
Its sad but thanks for the info! :(
You can't. It is old camera :-) But very nice one.
Can i use exFat with my TZ10? If i format with my pc, camera want to reformat all time :(
I really do not remember. Most probably it is another check.
Why does PTool 3.66d beta not remove the European time limit for Quicktime / Mov recording? It did so, for AVCHD recording but not for Mov.
Card formats to exfat so it should not have a problem with file size.
Thank you
May be, but it is quite hard thing. Even to find related parts.
If you ask me - it is simpler now to just buy new camera with such feature.
Hi Vitaly, Would it be possible to add an option to the firmware to make the self timer setting permanent until changed to off again. Now, after setting the timer to 2 secs and shooting the pic, the selftimer is set to off again. I need this option because I shoot a lot of panorama's on a tripod with the TZ-10. Still a great camera. But to keep the shots steady, I need the permanent shutter delay of 2 secs. I believe it could be easy to fix for you as an expert.
hello I'm new here, I have a TZ10 and I was wondering if it was possible someone post the best configuration for AVCHD Movie? Or Maybe someone can share some pictures, with all the best settings/changes to apply in pTool for TZ10?
I'm a bit noob when it comes to shooting video, but if it is possible to improve it and liked someone help me to choose the best settings for that.
By the way, I already have pTool 3.66d, and the original firmware (TZ10_V12) I'm just waiting for some tips from someone more knowledgeable for the the best changes to make! AC3 compression is worth it?
Excuse my english I'm Portuguese...
PS: By the way, can someone share an optimal settings for shooting?
I'm a little disappointed with my photos, they are too grainy ...
I suggest to sell it and get latest ultrazoom with wi-fi, it looks like it could have advanced timelapse. But this needs checking.
Would love to see a timelapse option added. This is a great little camera for it.
Would it be possible to change the JPG compression to reduce noise in the photos?
I think it can be done sometimes, but noise is really from small sensor.
It is not in plans, sorry.
Is this still going? Seems quiet here. I would love to be able to shoot RAW. Is it/will it be possible?
Would it be possible to change the JPG compression to reduce noise in the photos? Maybe to zero?
Just wondering why PTool 365d doesn't remove the European time limit for Quicktime / Mov recording
It removes all fine. MJPEG mode is also limited by file size limitation. This can't be changed.
how to crack GPS can't use in china ?
Hi All, Currently I have 1.2 firmware installed on my camera. In the same time the latest downloadable firmware from Panasonic web side is also 1.2. It means that I have "one way ticket" and after hacking I will not able to come back to my original firmware. Is my assumption is correct ?
Hi All. Could you help with question about changing compression ratio for photos.
