Hi All. Could you help with question about changing compression ratio for photos.
Hi All, Currently I have 1.2 firmware installed on my camera. In the same time the latest downloadable firmware from Panasonic web side is also 1.2. It means that I have "one way ticket" and after hacking I will not able to come back to my original firmware. Is my assumption is correct ?
how to crack GPS can't use in china ?
Just wondering why PTool 365d doesn't remove the European time limit for Quicktime / Mov recording
It removes all fine. MJPEG mode is also limited by file size limitation. This can't be changed.
Would it be possible to change the JPG compression to reduce noise in the photos? Maybe to zero?
Is this still going? Seems quiet here. I would love to be able to shoot RAW. Is it/will it be possible?
I think it can be done sometimes, but noise is really from small sensor.
It is not in plans, sorry.
Would love to see a timelapse option added. This is a great little camera for it.
I suggest to sell it and get latest ultrazoom with wi-fi, it looks like it could have advanced timelapse. But this needs checking.
