Shot this in HBR mode with Sanity 5. Very satisfied with the results! Canon FD 28mm 2.8 and 50mm 1.4; Vivitar 35mm 2.8; Peleng 8mm
Yeah that was intentional. I probably shoulda mentioned that! I've noticed it does show up as a stronger blue on some monitors and lighter on others. Not sure how it looked on your monitor but I definitely like how it looks on mine lol. I like to use skate vids of friends to just try out different little things like that. I felt it added to the feeling of the carnival at night. Maybe I won't go so intense next time....haha
Anyway, I decided to post it here though because I was surprised how well the GH2 with Sanity 5 was able to handle the low light conditions with such clean noise!
@RandyCatanach "I was surprised how well the GH2 with Sanity 5 was able to handle the low light conditions with such clean noise!"
That was one of my goals!
Yes, these particular 64Gb cards are wonderful. I use them almost every day here, zero issues so far. Flawless spanning with Sanity v5 (except for the 1080p30 mode). 1080p24H, no problem - spans forever! Also, affords very fast transfer times, and works great with USB 3.0 readers - which some cards don't play well with, notably Lexar and some Transcends.
I have this USB 3.0 Reader: http://goo.gl/Umsyf
@mo7ies Yes, SanDisk 45MB/s Extreme edition (the good one with 46MB/s measured speed, not Extreme Pro) is not reliable for spanning. Out of 4 times, two times it did not span in 24L mode when using Sanity 4.1.
@Ralph_B I suppose that Sanity 5 is not more reliable than Sanity 4.1 in 24L mode?
Do 64GB 95MB/s cards have some problems in a sense that you have to make one short clip before switching the camera off? If yes, it might be a problem for me, since I will forget to do that in more than 50% of the cases.
Sanity 4.1 and 5 are totally reliable for spanning in 24L if you use Sandisk Extreme HD Video 30MB/s cards. I can't speak for other cards. mo7ies has obviously had good success with SanDisk 64GB SDXC Memory Card Extreme Pro Class 10 UHS-I.
But in the broader picture, cards are a variable we can't control. One person reports success with a given card, another reports problems with the same card. Is there variablility in the manufacturing of these cards? Possibly. Did the person inadvertently buy a counterfeit card? Possibly. We don't know and may never know. All we can do is plow on and find something that works for us.
@Ralph_B - that's awesome news! I tried it on location with the fantastic Olympus 14-35mm http://goo.gl/Kc7x0 via the Panasonic adapter http://goo.gl/rlF3N , and it did not span - alas, that adapter is electronic and GH2 probably sees the lens as a native one, I guess. Will try some manual lenses next time!
I get 1 hour of video with Sanity v5 1080p24H, shooting landscapes (NYC skyline with moving clouds), in 4GB file easily!
Indeed super efficient, and excellent for timelapse (just speed it up in post as needed!)
http://www.personal-view.com/talks/discussion/3305/timelapse-with-sanity-v5
I've got a long take shoot to do in the morning and have switched back from FM2 to Sanity 5. My issue is the camera will be locked off and unmanned for at least 45 mins. I need to shoot high res (so 1080p) and we'll be moving on a boat for around an hour, pretty slowly. Do i go for 24L and risk it for Spanning on a 32gb 45mbs card? Just wondering what will be reliable. I only get one go at this so it needs to work!
@tl2bass - no, the card will span on its own. Once it spans though, and you turn the camera off and then back on, nothing else can be recorded on the card. It's the glitch.
The fix: after it spans and before you shut off the camera... record a short clip. A few seconds would do. Then you turn the cam off/on, and it will be ready to record again.
