GH3 Best Video Settings
  • 814 Replies sorted by
  • Yak- From what I gather from your posts: Natural or Standard 0,0,0 or -2, and I presume -5 ? Natural for high contrast light, Standard for flat? Ideal ISO 640. The LUT you made is for all -5, not the settings you mention on this page?
  • @yak Yep it's not so much how well it sharpens in camera, I'm ok with that. It's that double edged sword of how much it also may bring out stuff that I don't want (aliasing and noise). If use in-camera sharpening while recording to the card I can't change my mind if the results are unacceptable. It's in the original recorded file. There was this one shoot I was doing early after getting my GH3. There were power lines in the background up high. Sharpening was on +2. I could start to see the stair step aliasing of the line instead of a nice continuously clean bending line.
  • @maddog I don't know why but I find inner camera sharpening better than in most editing software. -2 is what I dial in with 43 lenses... On FF manual lenses 0 is perfect for me.
  • @SuperSet I still want as much dynamic range as possible so I'm consistently -5 on contrast. Saturation is no more than -3 but sometimes at 0 especially for skin. I'm with @rNeil on the noise. In-camera NR -5. Sharpness -5 with the same mentality - I don't want the camera doing it's own "voodoo" to sharpen the image. I can do that all day in post. PLUS in-cam sharpening can easily over exaggerate artifacting, aliasing and noise. That's my two cents.
  • I'm still a bit minus on things ... -3 contrast, -1 sat, -4 sharp & -5 noise as I really don't want their noise routines messing the footage ... on "standard" w/ hand-metered exposure, custom WB with a notch or two of orangey-grid adjustment after the Expodisc.
  • @superset
    My conlusion it that I shoot at 0 Contrast and Sat and only change the profile "Standard or Natural" depending on the lighting.
  • That's what I figured, fellas and it makes sense. Did we finally come to the conclusion that Sat -5 is a no go?
  • I think the discussions we've had vis a vis settings for the GH3 here are as good as we're going to get for "hacking" that camera. With VK having dropped the section even talking about it, and the replacement coming out in a couple months, not a great deal of reason for anyone to even finish off what work they've got into that project.
    So ... using our GH3's with the things we've learned it's still a very good tool, and ... like at least a couple others around here ... I'm so eager to figure out how to pay for a GH4 so I can use that as the "A" cam & my GH3 as my "B" cam ... :-)
  • @SuperSet I'd say it's safe to say don't hold your breath. And honestly with the GH4 in 2 months (reliable stock firmware shooting at 100Mbs IPB and 200Mbs All-I) who cares? Not me. The GH2 hack days were fun but looks like it's run it's course. And It's been months with no news since VK closed the section about it. Driftwood had been recently working on, and was supposed to release, the updated to Moon T8..... for the GH2. Enough said i guess.
    Sorry to the group for posting off topic.
  • Has the GH3 hack effort been abandoned?
  • @liammatador ...
    Yea, the more you get right in in-cam set-up the easier EVERYTHING is down the line. True in stills but I've found it even more so in video. The more "depth" to a file & the more dynamic range you have make it a bit easier to recover from initial ... mistakes? ... but a "recovered" footage from a cam with higher bit-rate & dr is often out-shone by a "lesser" cam that was spot-on for initial setup and handled wisely in post. So better initial setup is realistically never something you completely recover from. With any cam no matter how expensive.
    The GH3 has an issue (as I've seen it) with the engineers trying to out-think the users as to what "our Ideal" would be in skin-tones, and used the facial/tonal recognition ability of the processor to bake-in certain parameter to "help" skin along: lower contrast, lower sharpness, and over-saturated and lighter magenta (blue/red mix) coupled with a bit of de-sat in yellow/orange areas. Going for soft "pink" skin, I think. Which is where the "pink plasticine" look comes from, as far as I can tell.
    I ran this by a Panasonic rep who's done a lot of work with the GH3 and the user-base, MUCH experience in working the files himself ... and as I suggested the above reason for the look of the files, he ... um ... well ... um ... carefully chose not to demur ... um ... yea, he understood my point, you know ... and um ... well ... um ... maybe the design engineers don't always make the right choices, do they? ... Um.
    When I pushed a bit more about whether he'd actually discussed this with "Home" ... I got a rather distressed initial look ... and um ... um ... well ... um ... at which point I said I had to take his reaction as a rather powerful affirmative on my conclusions. He looked away for a bit, and noted that while he couldn't really say anything more on this ("You've been ordered not to?" actually got a brief nod) ... he wasn't certainly wasn't going to say I was in any way inaccurate or missing something in my statements either.
    Right.
    But ... all in all, a GH3 is a very fine tool. Initial WB on-set with skin should include an adjustment on the grid of the menu-driven WB set-up for a bit to the orange side of things, in my humble opinion. I neutralize with an Expodisc, after setting exposure by hand metering, then go in and take the manual adjustment on the grid a couple points towards orangey.
    Then in grading I "lift" the upper mids a bit while taking the straight-mid down ... both fine adjustments, just to get a bit more contrast in that Zone VI area that most "diffuse" fully-lit skin "inhabits". There's a couple of the LUT's available here that attack it slightly differently but end up about the same, one of which I've used some.
    And cam will have it's joys. A rather high-end grader I know of has a massive distaste for Canon glass and finds that to be a rather larger limitation on a multi-cam shoot than dealing with a hacked GH2 mixed in with a couple different Red's. For his tastes and experience, of course.
    And to my utter joy, the GH4 the better footage that's been out there and available for individual download/grading does NOT show any sign of pink plastic skin ... it's real honest-to-gosh people with pores & color and ... everything odd that real skin has. Yippee!
    Oi vey was this too long ...
  • Thanks man.
    Yeah I'm going to try not to rush into the GH4. A lot of new cameras will be on the way this year for sure, and also my current iMac probably won't edit 4k too well!! Upgrading probably means upgrading more than just the camera.
    As for the bitrate on the GH3 I've always used 50 due to others advice, but I didn't actually realise that the All-I is actually less intensive on your processor so is easier to edit, any experience with this? For edit heavy stuff like the video above I convert to ProRes so that my system doesn't drop frames and be annoying as it deals with it much better than H.264.
    I'm considering getting an external monitor and getting more of the image right on the day, as it can be frustrating messing about with some things that could possibly just have been better if they were setup properly. That's the theory anyway!
  • @liammatador Hey, regret nothing. The GH3 is a fine piece of equipment. I still really like mine. Not just throwing a bone to the GH3 either. I'm sure we (or I) sound like a nit-picky hair splitter regarding the GH3's weaknesses. I still have my GH2 but I do use my GH3 80% of the time. 1080p at 60fps for slow mo can't be beat. The "issues" for me with the GH3 have been skin tones and bit rate. For All-I you really need to be shooting at 100Mbs or greater to get a noticeably superior quality. While I was very excited about shooting 72Mbs All-I, I've found it to be pretty much useless now. (Remember that 50Mbs IPB Interframe is the visual equivalent of 100Mbs All-I.) That said, If I were on a dessert island and could only take one... GH3 wins out over GH2 for an essay of reasons.
    The perfect world for me would be the GH3 camera as is... with the 158Mbs bit rate of my hacked GH2. Hello GH4? We'll see, but I'm in no hurry.
    Since You've Asked: Technically: Well done. Definitely a time consuming edit. Skin tones work great especially for this stylized kind of execution. Again, nicely done.
  • I have to say guys, thanks for all the info and the LUT's and all. I know I haven't contributed to this thread much but I have kept track of all your discoveries. I am left feeling a little bit like I don't want to do any grading at all though! Ha. There are just so many variables. Is the GH3 really that bad? I sold my GH2 to get one about 6 months ago (before GH4 announcement of course) because of the practical advantages and weather proofing as I stayed on an island with it for 3 months. I have generally liked the results I have got, but saying that when I look at my old GH2 footage it looks really good and I wonder if I shouldn't have sold it. I just don't know anymore! Blimey.
    Here's a music video I finished recently with only the GH3. I did a tiny bit of correction with FCP and then used FilmConvert for the final look at about 70%. See what you think. It's obviously heavily stylised though.
  • @maddog15 You're very welcome! I've been doing nothing but watching color grading breakdowns the past several days :) Very inspiring stuff. And to think that up until just a couple of weeks ago, all my editing was finished after step 1! And hopefully with more experience I'll be able to look back and say, "I can't believe I used to be done with grading in just 4 steps!" :)
  • 2014 winter was fun while it lasted but I'm glad it's coming to an end. All shot Natural -5-5-5-5. Graded in Premiere Pro CC
  • @rNeil Thank you for your comments. This Slidecam is like having a new camera. And it's not easy to do well... just like getting a new camera. LOL
  • @maddog15
    Nice cam handling/setup. Very smooth, and "pretty" grade ...
  • 15 Minutes with a GH3, Slidecam S900 and a Lake = 2 Boring minutes. BUT... I enjoyed being out when the temp wasn't 12 degrees. Trying warmer tones for cinematic color and grading. Natural -5 -5 -3 -2. Lumix 14mm f2.5 with 0.9 ND filter.
  • @jonpais Cool tests. Thanks for posting your settings on this.
  • some gh3 with old nikorr 28-105 mm 3.5 no color correction
  • Here's a two-minute test shot over the weekend at Natural -4, -3, -3, -5. No sharpening or noise reduction added in post. Extremely minor color correction; saturation added for good measure, and a tiny touch of Osiris' Jugo LUT thrown in :)
    And here's the same as above, only with CGC's LUT Utility Kodak 2393
  • I would like to know, to make your white balance, you prefer use one white paper or one neutral grey 18%. With what do you obtain the best result ?
  • @Matthew very nice grading, feels cinematic to me. But I do feel GH3 renders better darker skin.
