@rNeil Awesome info - thanks so much.
Matt,
Mostly it works great, though there's a couple things to remember. Actually, it's pretty fantastic as far as time-saving goes ... but ... :
Going from P-Pro to Speedgrade through the Dynamic-Link thing is marvy, NO render-out time, import re-linking, that sort of thing. Many of the tools (including ALL timeline controls) are NOT available in Sg with this process. So, if you want to have grading layers separate from your editing layers, you need to make those in P-Pro before going over to Sg. I still forget that occasionally ... and it takes a couple minutes to close out of Sg/reload P-Pro and make a new timeline layer for the area to grade. Big whoop.
It's the P-Pro/Ae trip that's a bit more problematical, but manageable. It seems that though P-Pro has "Lumetri" built into it now, so it can see anything done in Sg, for some silly reason ... Ae doesn't. So simply going to Ae with the project means you are doing titling/fx over the 'raw' footage, not your graded look. You've two choices to deal with this:
1) Back in Sg, make a look or LUT of your grade, saving it ... and then over in Ae, go to the Apply Lut's option and choose/apply that specific LUT. Not really the best way ...
2) Rather than "sending" the project to Ae from P-Pro over the same path as you sent it to Sg, instead ... open Ae, use the "Dynamic Link" feature to bring the P-Pro project into Ae that way. Weird, but ... it "works". And it's a heck of a lot better than it was prior to this upgrade.
Neil
@rNeil Thanks for this great info. Yeah I was thinking same to do test mini project for workflow. Looking forward to trying it all out.
Video about new features:
Better response as to working through P-Pro/Sg/Ae process from Dave Merchant over at the Adobe P-Pro forum. Yea, it's gonna be a bit different that I've done, as the grading stuff you do in Sg (if in the "Lumetri" tool) doesn't pass through to Ae yet.
"You can open a Pr sequence that contains AE linked comps in Speegrade and they will display the same as any other clip, so you can grade afterwards (which is the intended workflow). If you have AE text layers, lower thirds, etc. that need to be excluded from the grade, then you would create them separately (as a new layer in Premiere Pro) and grade only the underlying footage, that's how it's always been done.
If you want to convert part of a sequence into an AE comp after grading, then you have two options:
1) Apply the Lumetri effect to an adjustment layer and exclude that track when you send to AE. Of course the grade won't show in AE, but it will remain editable through Dynamic Link.
2) If you want to pass an Sg grade into an AE comp, you have to save it as a .look file then use the "Apply Color LUT" effect in AE rather than the Lumetri effect in Pr."
Matt, I haven't checked this out, but ... perhaps a quick trial might be wise before working the main project. I'll be working this through later in the day if I can get to it, but thought I'd pass it on.
Someone over on the Adobe boards just noted that when he started in P-Pro, went to Speedgrade to grade, then back to P-Pro, then to AfterEffects ... the Lumetri stuff from Sg appeared to be disabled or something in AE, so he "lost" a lot of his color work.
A response was that the "typical" workflow is that one edits, then adds effects, then grades, so what's the problem? Well ... if one does the titles et al in AE AFTER grading the main project ... yea, that would be normal, right? So ... you might do a quick mini-project first testing out the 'flow' to make sure you don't hit a glitch.
Other than that, and having to re-think the process as my brain STILL wants to think of Sg as a completely separate program/process ... it really works quite well, very fast really. Neil
@rNeil That's good to hear. Have a project about to go into editing, and editor likes to grade while editing instead of waiting until the edit is locked, so that should work out well for us.
There's a major change in the basic approach to working the Adobe cine/vid "paradigm" with the new release. It's got some WAY cool handiness, but ... you've got to think it through a bit.
For example ... think of P-Pro as the "main" software, and use the other things such as SpeedGrade and AfterEffects as ... essentially ... plug-ins for P-Pro. You're going to do some grading? You might want to add an adjustment layer or two to your timeline in P-Pro before sending the project to Sg ... as you can add layers to your footage for grading each separate clip, BUT ... you can't add ANYTHING to the timeline ... such as an "old-style" grading layer.
Once you know how to work the new way, it's pretty fast and slick ... but at first, there's quite a few things that feel like it's broken, and you just can't get there from here.
Yes, you can ... but ... you need to re-think how to do it. And going out for short bits to Sg or AE ... rather than say finishing the whole thing, then taking the whole project one time to Sg, then exporting back to P-Pro, re-working your transitions, then exporting the whole thing to AE ... that's an old and slow paradigm.
Once you do start going forth & back regularly ... it's pretty damn quick ... AND ... wow ... rendering out a project is several times faster now. A project that took on average an hour & forty-five minutes now renders in around twelve, on the same computer.
Neil
From the P-Pro & Speedgrade boards over at Adobe, there are several folks having issues with cinema DNG's, and from the answers ... there's a flavor or two of them that the Adobe software simply doesn't "read" period ... and others that for certain people and if the moon's in the right phase and they've thrown salt over the proper place on a Tuesday the 14th ... are usable. And a couple that people have had no issue with.
For that middle group ... I think perhaps that is a typical problem with a new major product change. Give them a month and seen how it does.
Um ... if you're in that group, I don't expect you to be thrilled with a wait, you know?
Neil
Apparently BlackMagic DNGs are not showing up with the pink cast: http://forums.adobe.com/message/5805819?tstart=0
I'm also working with 5D Mark III DNGs. Right-clicking in the clip bin and choosing 'import' wasn't allowing me to import the image sequence (the box was grayed out) but I can import by locating the folder in the media browser. Once it's in my clip bin and reading as a single clip, I am seeing the same pink that @Oedipax is talking about. Even if I wanted to, I really couldn't do an edit like this because I cannot see what I am working with.
I imported some 5Dmk3 CDNGs and the image sequence import worked, and they do play back in realtime for me at full quality. A couple big problems - they have a massive pink image cast (maybe something to be fixed on the raw2cdng side), and you can't access the full RAW data from inside Premiere (there's no ACR controls). So the point of editing CDNG is kind of muddled unless you want to send it to Resolve afterwards.
I just downloaded Premiere CC 7.1 and I am having trouble getting it to recognize Cinema DNG files. Once in the imported into the clip bin they show up as folders full of DNGs, not playable image sequences like in Resolve. I thought that this was supposed to be one of the major feature upgrades for this version. Anyone having any better luck with it?
They don't seem to have released the CC update in the UK as yet. I would also like it for a project to do roundtripping from Prem to Speedgrade. Come on Adobe!
I've been using the "new" updated CC versions today ... it's going to take a bit of getting used to, such things as using a DirectLink P-Pro -> Speedgrade, quite a few of Speedgrade's typical options are locked out ... such things as say, making a grading layer on the timeline that spans several clips.
However, if you put an adjustment layer over those clips in P-Pro afore sending the project over, you CAN then use that adjustment layer as a clip-spanning grading layer. There's some other odds and ends to get used to.
On the other hand ... the trip to Speedgrade is only a few seconds, as is the trip back. VERY nice. And my oh my ... rendering even a lowly H.264 clip could take HOURS ... now, the same thing is a few minutes. I am VERY pleased with that!
And to the comment still complaining about the cost of the CC stuff ... well ... I'm using P-Pro, Speedgrade, AfterEffects, Audition, Photoshop, Media Encoder ... for what, just under $50/month? $600USD/year?
You know what that slew of programs would have cost me piecemeal?
Neil
Nevermind! They made it just in the nick of time :)
Looks like the mid-October update isn't going to make it out until November. I wonder if they pulled people off the video app teams to deal with the source code leak clusterfuck?
Well, I switched jobs and my account was tied to my old email address. Then they decided to reset the password, just before I went in to change it. The result is that I have now waited 1.5 months, and contacted them 6-8 times to get this updated, without results, so no way for me to use the software I paid for. At this point, I don't think I will pay for any adobe product again, whether it is subscription based or one-time cost.
Adobe, like Netflix when they announced they were splitting the business (and then quickly recanted after the damage was already done), just screwed themselves over this Creative Cloud debacle.
There have been numerous calculations made that the normal, "Average Joe" Premiere user will be paying A LOT more for their cloud service over buying a disc every so often. Most do not work for big post production houses and cannot afford the perpetual cloud "shakedown." You can't rent it by the month whenever you need it for the occasional project. It's a YEARLY contract with no guarantees the rates won't get jacked up after the second or third year of use!!
After this theft of sensitive user and internal source code, Adobe is going to be drowning in a PR nightmare of their own making.
Can't wait to edit cimea dng files in premeire.
Winner gets. ..drum roll please...AN ADOBE MOUSEPAD...that's right ladies and gentlemen...an official Adobe mousepad! Jokes aside, Creative Cloud works for me and I consider it a good deal. Premiere for edit, Audition for sound, and Speedgrade or After Effects for grading. No problems or hiccups for me yet after 1 year of use.
Winner gets working software :)
Shall we set up an "office" betting pool? Winner gets ... what?
Pretty much in same boat here with project timing. Lol - maybe we'll get lucky with timing.
Just checked the Premiere Adobe forum ... and the last word officially (two days ago ... sigh) is that they are working hard at finalizing the 150 new features implemented in the product and will 'ship' as soon as they feel they have stable code.
In other words, have you got a crystal ball, and ... should we set up an office betting pool on when they FINALLY will ship?
I've got three different projects that would be SO much simpler if the new process works as said. They all came up for working right around the 15th, and I've had a couple other things to work on in the meantime ... but by the first of next week, I've got to move on them. I'm gonna be SO ticked off at getting half-way (or better!) through them and THEN the stuff comes out ...
Neil
