When you say "garbage", do you mean poor quality or just very low quality?
They are garbage, not images at all.
One proposal for the D7000 which would be really cool: Auto-ISO on/off using the front scroll wheel. I think the D7100 got this feature, it would be very useful if someone could backport it to the D7000. Or maybe even a quick adjustment of the lowest desired shutter speed for Auto-ISO (this would kill two birds with one stone: Quick adjustment of minimum shutter speed and Auto-ISO on/off by using a extreme low shutter speed).
The same file reference is present in the D5100 and other models firmware also.
They are not fully same in all firmware images.
Nikon 1 models have many more different debug file references.
Also usually this is called within routine driven by one of debug flags.
Btw, D7100 seems to have many ARM references and of you check latest Fujitsu LSI use ARM cores.
They have the technology now - as usual they just don't want consumer cameras to effect their hi-end stuff.
I do not agree on both statements here. And we went offtopic anyway.
Yep. They have the technology now - as usual they just don't want consumer cameras to effect their hi-end stuff.
I like the 7100 otherwise - especially as the optical low-pass filter is removed and the sensor is highly regarded. It'll be good to see the progress on its raw capabilities even for small clips. :-)
I think with problem will be solved by major manufacturers soon :-) With the instant death of BM cameras niche.
Shame the D7100's major let down is its sd card write speed.
SD is most common card now. CF really went to niche, sometimes hard to get in distant places.
Interesting news about the LiveView Raw! :) I just registered on this forum due to that find. I'm myself a D800 owner and would be very interested in any kinds of video improvements on Nikon cameras. I'll keep following this thread. I'll be happy to contribute with donations as well. Cheers for working on the Nikons :)
Vitaliy, is there any plan to add the still photography options to the d5100 in the near future such as: -advanced backeting... bigger sets, move ev stop increments -timelapse capabilities... standard timelapse, bulb ramping, star trail timelapse
You better ask @Simeon . I just made NTool, not D5100 full reversing and D5100 patches.
downloaded the software but it says load firmware should i download the firmware separately for the patches to come please help.
Barely understand you. As for firmware, of course you must download it yourself from Nikon site.
D7100 has fun string present in firmware
A:\LvRaw%03d.raw
If someone do not understand, it means LiveView Raw.
Overall D7100 firmware is quite different to D7000. All menus seems to be image based now.
NTool 2.55 released
Version history
v2.55, 14 June 2013
Note that Nikon 1 bodies firmware update can not work if you already updated to same firmware.
We are working on this.
hello, I do not speak much English, but I have understood that the patch for the d7000 is out, congratulation for your work, I m going to talk about rush on french forums, but I have not understood what all this patch gives Now you can film a 25 second picture
in any case thank you for your work
OK, I'll look into this.
i have d800, is there coming something more than text patch?
Nope, for now.
But you could test it and let me know.
