AN "Valkyrie", GOLGOP3-13, GOP3ZILLA, natural, Freeze-less Reliable All-round GOP3 Settings :-)
  • 1001 Replies sorted by
  • My short video shoot using bkmcwd Valkyrie Cinema Smooth TYPE-ZERO1_BETA2 'Apocalypse Now' with cbrandin 'Pure Original Cinema Smooth Matrix' setting. Camera setting : 720/60P at 1/100 : ISO 200 : f2 : rokkor 50mm f1.4 lens : variable ND filter : edit/CC using PP and MBL
  • Hi bkmcwd, i bought a Sandisk 95Mb of 32G, when using H i can see some of the error frame or pixelated frame say every few seconds, especially when shoot at forest or trees where lots of details. But in L seems to be fine. I love the smooth look, any way u can fix the bug? Thanks
  • @bkmcwd Thank you, in the next patch, avoid this mistake 8-)
  • @Shon I already reuploaded. Many thanks for the indication from you. :-)
  • @Shon
    Inside the patch is the same mistake :)
    Yes, I know. Is it necessary to reupload corrected zip? Thanks! :-)
  • @bkmcwd Inside the patch is the same mistake :) Where is the word "cinema" 'Pure Original Cinmea Smooth Matrix'
  • Woops!!!
    I corrected the mistake in the name of "Cinema Smooth". LOL
    @Shon @ignatius Many thanks!!! ;-)
  • @bkmcwd
    I think Shon means change "cinmea" to "cinema"
    Keep developing your settings!
    Cheers
  • Hmmmm... I cannot be prevented from still freezing in HBR of 444 TZ2 C1.5e. In order to remove freezing in HBR completely, it may be necessary to change the matrix a little. It is likely to take time beyond anticipation until the next candidate completes. I am so sorry... :-(
    BTW, regarding newest GOLGOP3-13s and Valkyrie CS TZ1_B2 which have already been released, I think that they do not freeze nearly perfectly. :-)
  • @Shon
    Please correct the name Pure Original !Cinmea! Smooth
    ??? What kind of meaning is it?
  • @bkmcwd Please correct the name Pure Original !Cinmea! Smooth
  • Although I am doing the last verification about 444 TZ2, it is still under test, without being made to the setting which is not frozen perfectly. It may be released after tomorrow. :-(
  • @bkmcwd probably it was yes. My computer was probably a bit laggy the other day.
  • @2many Thanks for detailed information! :-)
    When I heard your talk, I guessed that it was an issue of the player in PC. Isn't it?
  • I was using hybrid C1.
    It's odd though, now that I play the footage; where I thought I noticed a slight drop in frames, it appears to be normal again! I could have sworn that I saw something strange yesterday, as if a few frames got skipped..
    I still do notice the kind of 'choppyness' in the movements of faces in screen. But I'm guessing this isn't settings related but camera sensor related and thus not fixable; footage looks great already anyway.
    Thanks! :)
  • Since verification finished mostly, I am going to release Valkyrie 444 TYPE-ZERO2 C1.5e today. :-)
  • @abraham1307 Many thanks always mate! :-)
    @2many Thanks for your report! :-)
    some drops in the framerate with Valkyrie 444
    About the drops of the framerate, it was heard for the first time. Is it in what kind of situation concretely? Could you present the data itself or StreamParser results?
    EDIT: Would you tell also about the exact edition of 444?
  • hey could it be that I noticed some drops in the framerate with Valkyrie 444? I'm using a 45MB/s card ... setting was HBR 25fps
  • @bkmcwd I will test and let you know how everything goes.
  • NEW!
    bkmcwd Valkyrie Cinema Smooth TYPE-ZERO1_BETA2 'Apocalypse Now' with cbrandin 'Pure Original Cinema Smooth Matrix' - setd.ini - Released 14/11/2012
    This is Valkyrie which adopted 'Pure Cinema Smooth matrix' of Chris.
    About the concept of CS matrix, I think that it will be later explained from @cbrandin or @driftwood officially.
    All of these matrices are the same as previous BETA vesion. The main changed parts are having realized Freeze-les and high-bitrate in HBR and 720p. Especially in 60p, the highest bit rate goes up to 65M from 55M, and is upgraded from 9GOP to 6GOP like GOLGOP3-13s.
    Warning! : in this "TYPE-ZERO1" setting, all the modes of AVCHD are experimental.
    Please keep in mind that artifacts may often appears in HBR, 1080i and 720p in spite of being very stable.
    Please try it! And I am very glad if I can get any feedbacks.
    *If this is also still unstable, I will further adjust.
    *Special thanks to @cbrandin and KING @driftwood!
    *24p is completely the same as a former setting.
    • Superb-looking Cinema Smooth matrix from cbrandin
    • Upto 140M for Top Quality 1080p24 at Q18
    • Upto 140M for Top Quality 1080p30 at Q18 in 24L mode with 80% Slow-Motion Mode (No Sound)
    • Upto 75M for Top Quality HBR/FSH modes(Experimental)
    • Upto 75M for Top Quality 720/50p modes(Experimental)
    • Upto 65M for Top Quality 720/60p modes(Experimental)
    • Extremely reliable top performance in AVCHD 24H and 24L
    • 80% Slow-Motion is available in 24L only
    • Fully working iA and iDynamic modes if you require them
    • Beautiful 3 GOP bringing short GOP style detail & movement-rendition in 24p and 1080i
    • Bush of Death / Death chart tested.
    • Wonderful Pasadena Pulse Audio Patch V2 B2, by Per Lichtman
    • Top quality 2K mjpeg Mode in HD by Nick Driftwood
    • In camera playback is sometimes not available in 24p. In other mode, available after reboot the camera.
    Please download 2nd zip file! 1st one is wrong in the name of Matrix, although the contents of setting is correct.
    bkmcwd Valkyrie Cinema Smooth TYPE-ZERO1_BETA2 'Apocalypse Now' with cbrandin 'Pure Original Cinmea Smooth Matrix'.zip
    1K
    bkmcwd Valkyrie Cinema Smooth TYPE-ZERO1_BETA2 'Apocalypse Now' with cbrandin 'Pure Original Cinema Smooth Matrix'.zip
    1K
  • @tetakpatak
    ??? Even if I check in windows explorer, audio is displayed as 256kbps. Although I have seen the file as which only an audio is displayed occasionally before, since there was no problem in contents, I do not care. Although I do not know to be a file with which setting, it has seen in the high-bitrate setting several times.
  • @bkmcwd @flaschus
    is it possible that windows explorer displays with 256kbps only audio bitrate of your files? Does this patch record sound in 256kbps?
  • I am also working on improving Valkyries.
    The improved versions of Valkyrie 444_TYPE-ZERO2 and CS_TYPE-ZERO1 are due to be released soon! :-)
  • @ GOLGOP3-13 lovers :-)
    "GOLGOP3-13-A2_BETA" and "GOLGOP3-13-MAX2_BETA"
    I release the new "GOLGOP3-13-A2" and "GOLGOP3-13-MAX2" settings.
    All of these matrices are the same as V1s. The main changed parts are having realized Freeze-les and high-bitrate in HBR and 720p. Especially in 60p, the highest bit rate goes up to 65M from 55M, and is upgraded from 9GOP to 6GOP.
    Please try them! And many thanks for your feedbacks!
    Special thanks to @Mrhechang and @syoushow! :-)
    NOTE:
    *Although bit rate setups are quite high, the bit rate which actually appears are lower than these. Since the actual bit rate changes by the object to shoot, please confirm by yourself.(Max bitrate : about 110M in 24p, about 75M in HBR.)
    *'MAX' versin and 'A' version are completely the same except 24p.
    *The original matrix is adopted in the newest GOLGOP3-13s. It is the middle of a Sedna matrix and a stock character. If it says plainly, it will be the Sedna matrix optimized in 3GOP structure.
    *24H and 24L are high quality 3GOP setting with mega size I-frames in GOLGOP3-13-A.
    *24H and 24L are high quality 3GOP setting with super mega size I-frames in GOLGOP3-13-MAX.
    *24p80%(30p) is available in 24H & 24L both.
    *60i, 50i, HBR30p and HBR25p are also high quality and stable 3GOP settings.
    *720/50p and 720/60p are 6GOP. It has tuned up so that the bit rate at the time of motion may go up rather than the time of statics.
    *In camera playback is available in all rec mode except 24p in GOLGOP3-13-MAX, at least available after reboot the camera.(Not tested full yet, but probably)
    *EX Tele, iA mode work.(Not tested full yet, but probably)
    *Spanning in 24H, 24L with SanDisk 95MB/s 64GB SDXC Card. In other rec mode, need test.
    bkmcwd GOLGOP3-13-A2_BETA.zip
    1K
    bkmcwd GOLGOP3-13-MAX2_BETA.zip
    1K
  • @flaschus Hi mate! Many thanks for your report. Since the improved version is released soon, please try. :-)
    when windows explorer reads some of the 24h footage shot, the bitrate displays as "256kbps" the file plays back fine, but is this a sign of the patch?
    I have also experienced many same issues until now. Since I was experiencing also not only in my settings but in other persons' settings, I did not care at all. Is there any detailed person some?
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
