@OSGondar There's never a bad time to grow balls, gender dependent I guess! I didn't read through it I'm afraid, just knew I'd seen something useful. Didn't include the how much time you've been wasting bit!
@feha I know I'm being dumb here, hence the topic! but I set the 720p as normal in the menu. I have the monitor out set to auto, but when I connect the monitor the record setting option greys out and becomes inaccessible. I need to test if I set the monitor out to 720p rather than auto if that would over ride whatever I've set as recording format, I know it makes no sense, that the monitor out would dictate the recording format but that's what seems to be happening. Someone bringing non-hacked GH2 round tomorrow to see what happens with theirs when I plug in monitor.
@eyeBOX Hi, they were kindly written by OSGondar and testicle enhancement was out of context! Wouldn't 30->24 just mean that? Changes the 30 frames per second to 24, though there is obviously the cinema mode available that is 24 fps?
Hi guys. I've been patching my hacked GH13 for a year and now I've hacked the GH2...but something's gone wrong. I installed 1.0E firmware to camera without checking anything. Left the name GH2__V10. This would be my 'base' firmware. Then I waited for some testers to make something stable. Vitaliy came out with 3.61 patch that looked stable and I decided to install it, checking off version increment and the few settings 'hints' he recommended. I successfully loaded it up, saved it as GH2__V11.bin and put it on my GH2. So far so good...then I saw Kae's 3 GOP patch and decided to give it a try. THIS is where things went weird. I can't re-install original firmware?? So then I looked at my menu Version Disp. and it still reads Body Firmware 1.0??? Shouldn't it say 0.0? On my GH1 every time I loaded up a patch my Body Firmware would say 0.0 - so I could revert back to the original firmware and load up a new patch. So what can I do? Any ideas? I feel like a noob, but I'm not.
UPDATE : Discovery...Seems I cannot go 'back' to original firmware but I can go 'forward' to each new firmware I name. This means that if you want the original 1.0E firmware again, just load the GH2__V10.bin into ptool and don't check anything, but save it as latest firmware increment. This is different than GH13 as you could always load original firmware back to camera (1.32) Works for me. Hope this can helps anyone else.
@feha it is weird, I've just tried connecting two different monitors and it's the same with both. As soon as I plug in a monitor whatever record mode I set previously I can only record 1080i and it seems it doesn't matter what I set the HDMI to either, whether it's auto, 1080 or 720 I always record 1080i. If I just plug in an HDMI cable with no monitor on the other end I'm still able to select my record mode, if I connect the other end to a monitor the rec mode option is greyed out and I record 1080i. Weird.
Summit seems to be working, after a few tests and is there any sign of a proper [GUIDE - GH2 Hack - From Flashing to Camera Operation] on at least the basic findings? (PS donated, and will donate more soon). So to fellow noobs Elecard Streameye Slim reports this when you hit the 'i' button using kae's setb.ini file. Plus No record crashing on transcend 32gig type 10 cards.
I have seen some posts in other threads which recommend saving different versions of the firmware (both original and hacked) onto separate SD cards to enable easily switching from one to another. But does this work? From what I understand the version increment must always be checked. Doesn't this mean that I cannot go back to a previous version without recreating it in ptools? Can anyone clarify this for me? Thanks.
first patch applied: increment checked; value 1, saved file to GH2_11.bin...
Cam still says ver. 1.0. but patch applied.
second patch: increment checked, value 2, saved file to GH2_12.bin
Cam says version is 1.1.
So now I am gonna try KAE's file. Increment checked, value 3, saved file to GH2_13.bin
Cam updates but still says version 1.1... Haven't tested yet or checked bitrate. But I am wondering: Is this the way to go? I don't feel so confident. :/
Someone PLEASE shed some light on this. I understand it is in HEX but I don't speak hex - hence I am not a hacker but a patcher... He he.
Thanks! But I think the hint is a bit ambigious (could mean two things). I thought it meant that EACH increment should increase by one (1) everytime you apply new patch; like: 1,2,3,4 and so on.
So it should always say value 1 (never change that?) Sorry for being stupid.
Anyhow. I just tried KAEs patch and I used "3" as the increment number. It seems to work anyway. Streamparser topped out at 6.352.000 for I-frame. at 24H (trees and stuff)...
Could somebody tell me about GH1 patch settings - Encoder settings1/2/3, constant 6000 and Framerate related comparison. Just basic things about result of tweaking this settings. Thank you.
i mean...does panasonic use the same firmware for GH2 for different country?? in other country which has no this kind laws,,does GH2 use a firmware that has no this limit?
