@APXmusic Hey, I think you should be fine. I have not used anything other than the 64gb 95/mbps cards which gives you 90mbps write capability I believe and never had any issues that I see on the forum. All of the patches I tried works with no issues so that's why I'm recommending it if you are hacking the cam. One thing I do know is that you have to make sure the Sandisk is legit. There are many fakes on Ebay and other websites so buy it from a reputable company.
This thread may be helpful http://www.personal-view.com/talks/discussion/1491/95mbs-sandisk-extreme-pro-cards
@strancali Did I just fuck myself by ordering 3 32gb Sandisk Extreme 45mbps cards? Those 95mbps were just too expensive. I thought that the GH2 didn't support UHS-1 anyways.
@Mirrorkisser Thanks for those kind words! No, I didn't use any stabiliser other than in post. Very minimal use of warp stabiliser in Premiere Pro CS6. I applied it to 4 shots; the big red temple gate, the futuristic looking bridge, the part where i walked down the thousand pillars and the train station platform shot that came after it.
Konica 40mm 1.8 is fantastic
@Strancali Yeah I almost brought that before the 35mm
@DeShonDixon Great! I'll keep an eye out for a clean copy. If you get a chance, look for the Konica Hexanon 40mm f1.8, that lens is beautiful and sharp (under $50).
@Strancali That's man!! Yeah you can find it right here http://www.ebay.com/itm/Olympus-Zuiko-OM-System-35mm-F-2-0-Lens-with-Two-Caps-and-Case-/170886716025?pt=Camera_Lenses&hash=item27c9a45a79
@DeShonDixon very nice, I'm looking forward to seeing more videos with that lens. Have a link on ebay?
@Strancali @Axisart Oh!!! Thanks yeah its not a kit lens it was old zuiko olympus 35mm lens I brought off of ebay for cheap
@DeShonDixon @axisart is just complimenting you :). I think he meant that the video did not look like it came from a kit lens but a much better lens.
Having the 64G/95mbps card, what do you guys think that is the best hack at this moment for cinematic look in a short film?
@thehaz: i like your video a lot. you have an eye for details and a nice perception (i dont mean technically, but i mean observation of surroundings. thats key for making good films). and the music fits too, plus its not stereotype.
did you use any sort of steadycam?
@DeShonDixon and don't tell me it was the kit lens lol...because its NOT!
@johnhizzle If you can afford it, I would strongly recommend you get the 64gb 95/mbps card. After all, we are doing hacks and why take the chance of ruining a shoot because the card cannot handle the data. That would end up costing more in the long run with all the time and effort that went into the production. With that said, I'm confident that your 2 sandisk 95mbps cards and the class 10 card can handle Cluster v6 DREWnet (correct me if I am wrong).
@driftwoow @MattRobertson7 @mistan
Thanks for the props y'all. The post process was pretty simple. On the Red, I dialed in a different black and white look in camera on set for each scene, this made it easier to quickly tweak the look in RCX. From there I made a prores 4444 and a prores proxy of each shot. I converted the MTS files in adobe prelude to the same. Then sliced and diced as usual in PPro CS6. The only filters I used on the GH2 footage was 'RGB curves' and the saturation slider in the 'fast color corrector.' I applied a tiny bit of Neat Video to the mpc overhead shots because I used the telephoto crop mode to save time on set. The gh2 footage was shot 2x anamorphic 16x9 while the red was capturing 2.4 square pixels through regular cinema glass. So I had to crop some width off of the sides of the GH2 footage. I set my sequence to 1920x820 and just fit height. This allowed me to do a few slick pan and scan tricks, bumping the frame side to side to the beat using motion key frames. As far as landing these jobs, all I do is try and make the best thing possible and work as closely as I can with directors to make it the best it can be, and then they come back with bigger and bigger jobs and we all grow together. It's basically an evolution of free work into paid work by not screwing anything up along the way in terms of quality as well as relationships.
Hello I'm in the the process of purchasing a GH2 and I shoot a lot of long form things (wedding videos, music videos, and assorted events.
The Highest Capacity Cards I have are 16GB Class 6 Cards and the rest are 8GB class 10 Transcend cards. I also have two Sandisk Extreme 95 mb 8GB cards
Would these cards be sufficient to run the Cluster 6 DrewNet Patch or should i just save some cash and get the 64GB Sandisk Extreme Cards?
Thanks in advance for any help I receive on this question.
@driftwood My entry into the sunset competition. Have original MTS.. and have various versions.
Two shots: a wide, and a more telephoto shot.
Sedna AQ1 'A' 24fps, 24H, Smooth -2, -2, -2, -2
Lens was Zeiss 85mm f1.4. Second shot used Tele-Extended mode
Some weird youtube compression, but none in original or ProRes.
May upload to Vimeo, to check compression there as well.
Hello. I'm new here, and just starting to GH2. I want to say thank you for this hacks. Thank you very much. (sorry my bad english)
Hi guys. Earlier this year, I loaded my GH2 with Sedna Q20 and headed out to Japan for a week. Tokyo and Kyoto and back to Tokyo. Here's what I got. It would be awesome if you guys can weight in on my video. Thanks! And seriously, I know this has been said a lot, but you guys rock! I'd put the whole personal-view dev team up for a technical oscar if I had that much pull.
Password is tokyotoEDIT: Took out the need for a password.
@Quinnthouzand Small world! I know those girls in the video. Well I know one of them and I know OF the other one. The spanish one is named Jackie and I've worked with her before. You must be based in ATL. Pretty crazy how I was just checking out her BTS photos a little earlier and I go to chk this site and bam, there's the video lol :)
I shot this with Canis Night check it out!!
Here's the vimeo verison for you guys that hate YouTube like me@thepalalias shot few dawn i am gonna shoot more.,... results are bad....what about you anything for the competition,...canis night looks better for sunrise,...tell me what do u do?? any good news???
@pundit Only a few shots I had to pull up the shadows but all in all what you saw is what we filmed (levels wise). With color, it really brought out the pop. It was actually kind of hard to grade as that day was ping ponging between overcast and sun. It finally settled down near the tail end of the video though!
@jhero Great looking video. The overall contrast was great and the highlights looked really well controlled especially with the backlit sun shots. Did you need to pull any of the shadows up in post?
