I've used @driftwood GalaXian latest settings and didn't tweak anything. Recording in both SH and FSH mode is working without issues. However ICP of SH files causes "Read error" (FSH ICP is fine). After importing to PC I can play all the clips without any problems.
I'm using PAL G3 camera with SanDisk Extreme 30 MB/s 16GB.
EDIT: Checked everything in NTSC mode. All above applies as well.
Answer is negative, unfortunately. I know about bracketing things, and this is present in plans, but we need to dig deeper and understand this part better.
I´m totally new to site, found the info in another forum. I´m not really using the video functionality, but I would like to see the chance to edit the bracketing options: Can I use the tool to change the Bracketing options to 3, 5 o r 7 pics with 2EV difference between each picture? Right now, there is only the possibility for 1/3 , 2/3 or 1EV between each picture which is not enough for good HDR series...
At the moment G3 only has some sort of shutter priority mode for video that you can force using the "Anti-Flickering" menu... Not full PASM modes.. It is planed for a future version of the hack, but until implemented you never know how much time it will take or if it will work without issues..
I wouldn't buy a camera based on expected features.. For a video-centric usage the G3 is not the camera to buy...
Hi Vitaliy! Regarding your great work and, in particular, that video mode via mode dial (C1/C2): I've just donated (see transaction #47U412215X217604B). Thanks again!
So here is my G3 setting based on Driftwood's 'GalaXian' 12/15 GOP patch. Tested with Panasonic 'Gold' class10 SDHC 16GB, SanDisk 'Extreme Pro'- 95MB/s class10 UHS-1 SDHC 32GB.
Setting is 72M/50M, average Bitrate 35-42. After days of testing (dif. conditions, dif. lenses) it's currently the highest stable bitrate setting. I've changed the Video Buffer settings, Auto Quantizer settings and some other things i don't remember... The results are very impressive !
Use only with fast class10 cards, best UHS-1. Enjoy...
That would be awesome and ultra-helpful, since none of the wireless remotes available have an option for triggering the movie mode. Thanks a lot, Vitaliy! As soon as I get paid (for my under-paid freelancer job), I'm gonna donate 20$ or so!
Just a question, no request. Thanks a lot.
I'll add it to my list.
Hi. I'd like to start recording video with the wireless remote Pixel RW-221. Since the G3 has no mode dial function to set it to video mode: Will the firmware hack allow you to select video via C1 or C2? Just a question, no request. Thanks a lot.
@driftwood thanx... didn't know that... AQ=4 IQ=18 so I try to uncheck AQ
