Guys try out 'Galaxian' on the G3 for me. Its over on the ptools 3.66d thread - Please let me know if it works, however, Im not so sure mp4 playback will work in-camera (however, its fine on WMP, Movist, Quicktime, NLE's etc...)
GalaXian is the first hack settings featuring parts of my Cluster v6 GH2 settings. Give it a whirl and report back here.
                  @driftwood: so first attempts failed... when I hit the record button, camera switches to video mode and freezes... It's focusing but timer didn't show up and camera doesn't responding to any button. Hard reset is needed (take out the battery). I will be elaborating with settings a bit...
G3 doesn't have MP4 mode... only AVCHD I figured it out.. Encoder Setting 1 1080i/p was the cause.. Lowering from 9 to 5 resolved the issue... I have also lowered bitrate to 36M as before, it was giving me write errors when set above 40M.. Will elaborate with this with your settings... Here are some samples...
                  Theese samples was taken before the sunset so light conditions wasn't perfect, but instead of that, result is very good... Decent Leica glass do the job for less light out there :) Here are my settings tweaked a bit to got it to work... Thanks driftwood for your work too... great comunityhere...
                  @driftwood thanx... didn't know that... AQ=4 IQ=18 so I try to uncheck AQ
Hi. I'd like to start recording video with the wireless remote Pixel RW-221. Since the G3 has no mode dial function to set it to video mode: Will the firmware hack allow you to select video via C1 or C2? Just a question, no request. Thanks a lot.
I'll add it to my list.
