Here you go. Probably the most stable settings to date.
*** NEW *** Cluster v6 'DREWnet' - The Ultra Reliable Setting is now released.
Hi @zinin, your videos with GF2 are incredible. Fast lens like 50mm 1.4 and cctv 25 mm 1.4 on GF2 makes the difference, indeed. I am very interested in your use of lomo cctv 25 mm 1.4 it seems a good lens, very sharp and natural look, however, like other 25mm cctv lens, I've noticed that has a specific look, too smooth on the corners. I want to know if this smooth-effect is more evident when you focus a close subject or viceversa...
@driftwood I will do the testing once I am back from Holidays next week...
@coors Although I designed Flow Motion v2.02 explicitly for the GH2, it also appears to work reliably on the GF2 and GF3, with one exception - in-camera playback does not work reliably in 100Mbps modes. This is an unfortunate limitation of the GF2/3 that I found with any patch higher than about 50Mbps.
In terms of motion picture quality, I wasn't able to compare FM2 with Cluster 720p modes myself, as Cluster consistently produced write errors on nearly all of my FM2 test subjects.
On my Gf2 really liking Cluster 5 in 1080i seems to be a great quality to file size mix. I also use 720p for the ex tele zoom mode. This is also good but not having in camera playback is a real restrcition for me. I've tried disabling B files. This sorts playback but also causes write errors in EX mode.
Any suggestions on how to keep the 1080i settings but have realiable 720 not using B frames would be really appreciated.
Cluster5 is the clear winner, in my recent test. Both Cluster4 and Cluster5 are out-resolving Flowmotion2.02 and now Cluster5 has the better shadows, too. This is, of course, just my own opinion, based on my testing, which may or may not be accurate. I try to eliminate all variables, but there could easily be something that I've overlooked. I know that framegrabs, or whatever they're called, would be helpful here, but I don't know how to do that.
@diafragma1939 relative to your questions on the Flow Motion v2.0 thread. I only use the GF2 in 1080. I've been shooting in the two other formats for testing only. I don't own a GH2, so I am not disappointed with any aspect of the GF2's image quality. It serves my needs very well. If the GF2 had full manual controls, I'd be very, very happy, indeed.
I suggest you to look into development plan.
Right now I don't have time, and spend all available on GX1 and G3,
@zinin Try GOP3ZILLA (standard) http://personal-view.com/talks/discussion/2960/golgop3-13-gop3zilla-natural-for-mega-size-i-frame-lovers-/p1 and EOSHD GF2 setting on the bottom of this page: http://www.eoshd.com/gh2-patch-vault
These two are the cleanest from everything I tested (pixel-peeping the screengrabs to see where codec falls apart) in AVCHD 1080. I am yet to try @subco 's MJPEG settings (ложил я на ГФ с большим прибором: http://personal-view.com/talks/discussion/comment/64258#Comment_64258 ), but he is right, the real resolution is way below even 720. My workflow for now is AVCHD@1080 and final export at 720.
VK never fails. It's a question of time.
