I 2nd that... people need to realize that its been asked for, programers are working on it... It will happen IF ITS POSSIBLE. Just please stop spamming that request. Whats so bad for B-footage to be conformed to 25p? I live in PAL land but, prefer steps in bitrate and 10bit to be highest on the priority list.
@Ptchaw and daihard - If you would like to use the GH2 for broadcast work in PAL countries, you require 25p - 24p is NOT an option. That's why people are 'spamming'.
"B cam work" But yes, broadcast and GH2 as main cam will need "proper" 25p... as well as higher bitrates and probably 10bit... And now i feel like im spamming ;)
>New PTool will be released only after we'll move forum and domain to VPS.<<br /> @Vitaliy
You´ve already moved to VPS, right? Is there a chance to get the new Ptool today or tomorrow now? Sorry for being a bit impatient, but you promised so much good things so that it is hard to wait...
@Mark_the_Harp You won't notice. This is done on a daily basis. Pretty much every american film you see on pal TV is sped-up and vice versa. Did you ever notice? Probably not...
@cordvision, I notice. The big problem is the audio, voices and music are pitched higher. When I first saw a US Frasier episode at the proper rate after years of watching conformed-to-PAL, I couldn't get over how deep their voices actually were, and how slow the pacing of speech was. It distorts reality in an unpleasant way.
@_gl Usually a slight pitch adjustment (pitch correction) of the audio is done to compensate... After doing so, there shouldn't be noticeable difference....
@cordvision - if you're working in PAL broadcast, then you're pretty much tied in to delivering on tape at 25fps. Which means shooting and post producing at 25fps. No one - but no one - posts at 24 then speeds up to 25fps if they can avoid it.
*sigh* Im sure it would be different if some said "you can conform 25p to 24p" if there was no decent 24p on gh2 (see GH1 lol) its not a ideal solution. Its something Im doing at the moment (matching to GH1 25p & HX9 50p footage with GH2 24p footage) and can be a headache. Im pretty sure this'll all work out in the end. Good things come to those who wait! Let the man do his thing...no point is rushing!
@mrbill It is done with NTSC footage shown here. Even if it wasn't, so what? Who cares if no one else does it, it works, you'd never tell the difference and you end up with 25p.
@Mimirsan I've done it on PAL cameras with no 24p. No big deal.
@_gl You're talking 30p to 25p, which is a much bigger difference than 24p to 25p. In Premiere Pro, at least, preserving audio pitch is done by ticking a checkbox.
