GH2 driftwood hack in shootout with Canon C300
  • 471 Replies sorted by
  • I'm guessing #9 is 5n
  • @ehr: There could be problems with the hair IMO, on #5
    I'm guessing it's the AF100
  • #1 = 5D
    #2 = GH2
    #3 = NEX5N
    #4 = C300
    #5 = F3 AB-Range
    #6 = AF100
    #7 = F3 S-Log
    #8 = D7000
    #9 = FS100
    #10 = 7D
  • 1. 5D
    2. D7000
    3. GH2
    5. NEX5N
    9. AF100
    My guess at the unconfirmed results.
    Confirmed are...
    4. C300
    6. F3 AB
    7. F3 Slog
    8. FS100
    10. 7D
  • this is 8 of 10:
    1 5d
    2 nex5
    3 gh2
    4 c300
    5 af100
    6 f3
    7 f3 slog
    8 fs100
    9 nikkon
    10 7d
  • my best guess:
    1 5d
    2 GH2
    3 D7000
    4 c300
    5 af100
    6 f3
    7 f3 slog
    8 fs100
    9 NEX5N
    10 7d
  • 1
    2
    3
    4 C300
    5
    6 F3 AB
    7 F3 Slog
    8 FS100
    9
    10 7D
    Those we know are correct.
    Going by bokeh and negation the rest would be: 1: 5d, 2: 5n, 3: gh2 or af100, 5: Nikon, 9: gh2 or af100.
    But of course, there are no certainties in terms of the same aperture and distance being used.
    The two shots with smaller bokeh could also be the 5n and the Nikon if the distance was moved before they were shot (to accomodate different sensor sizes)..
  • #9 is the GH2, looks damn fine to me!
  • why he did not 24H tests
    70MBit? the comparison is nonsense
  • 9 could certainly be the GH-2, DOF would definitely support that. Personally I am just not that used to getting that much red in my skin tones.
  • GH2 = 2
    Look at the neck. THe picture is out of focus.
    Why would would you post an out of focus still to represent a camera?
    Man...
  • 9 is GH2, has to be - look at high ISO bar in lower 2/3 on left side lol.
    My prediction
    9 Gh2
    5 AF100
    1 nex
    2 5d
    3 d7000
    It would be really easy with a highlight gradation - the AF100 would stick out like a yellow thumb
  • @plasmasmp
    Hmm you may be right about 9, but it's hella oversaturated to have everything dialed down.
  • Ha ha, I give up, but damned if 2 isn't the skin tones I am used to getting after I transcode.
  • 2 and 5 look the best over all.
  • 9 is the smallest sensor and 1 is the largest. Just look at the Bokeh and you can tell the difference in crop factor.The larger the sensor the more compression. You have to widen from a Full-frame crop to a 2x crop to get the same frame. Wider lens = smaller bokeh.
  • If 9 is the Gh-2 then the af-100 probably has to be 3 look at the shadows, looks 24mbps.
  • If 3 is the AF100 that's pretty nuts. Look at the pixelization happening to the right of her head where the light falls off, and the stairstepping in the bokeh on the left side.
  • 2 Would make sense as 5D, then, since it's out of focus.
  • Reckless yes for me number 9 and 3 lock like the same sensor size,1 cam be 5d
  • #1: 5D
    #2: NEX5
    #3: AF100
    #5: D7000
    #9: GH2
  • 2,3, and 9 have the smallest bokeh. So other than the AF100, which is the next smallest sensor? Sony?
  • @disneytoy both nikon and 5n has aps-c sized sensors. We know the second image is not Nikon. But if you look closely the bokeh is slightly bigger than on 3 and 9.
