@spacewig@cowpunk52 Can you run the same test and uncheck the Max ISO limit box, save firmware and reflash? And let me know. Also, check in camera settings - see if some kind of reset has happened. And also attempt switch off/on first.
Just received Sandisk 95MB/s card. Spans with Quantum V3. However, after shooting a few minutes today, it won't let me record any more. I get a " CANNOT RECORD. FILE NUMBER EXCEED LIMIT. Could someone elucidate me on what this means? Muchos gracias.
I am still awaiting one of these cards coming from Sandisk's PR company this week. If its good, Ill be buying it from them. @piotremanuel has two of these cards. Piotr could you film a death chart of Quantum for me? Thanks mate.
45mb/s version will not span so your recording times will be limited to approximately 3-4 minutes with the highest quality patches. The 95mb/s card (only the 64 gig one though -- with the SDXC, which emphasis on the X) will span with highest quality driftwood patches, meaning if you are doing interviews, events, or long takes you will be able to record until you run out of card space -- generally around 55 minutes.
I have one since yesterday. It does span correctly with new Quantum V3 Driftwood's patch in 24 P H Mode, but not in 1080 I FSH. It's very odd... Theorically, 24P H need more resources than 50i stream
Thought I read reports that it spanned too... most of my interviews don't go over 2 hours so I don't want to shell out for another sandisk card but would like a backup for long interviews (and a cheaper one at that).
So just to clarify, is the spanning your guys are saying the 64gb card can do spanning on photo burst. I know this is probably a dumb question since I keep seeing the word burst used. Just want to be sure I understand this.
