I've noticed that my GH2 turns on instantly after I installed the 1.1 firmware. I mean instantly. I'm thinking maybe after the firmware install I need to go to one of the menus and turn off some sort of 'instant on' feature? I looked for it but can't find one. Doesn't mean it isn't there. Anyway, with the original firmware it took just a bit before I saw the LCD screen all ready to go. Now when I flip the switch to On...boom, it's on and ready to use. I'm not complaining but is this normal?
Can't believe new 25p brought so many comments ! Progressive modes are often wrapped into interlaced. What matters is what I get in quicktime and it's definitely progressive ! I always use Neoscene Cineform to convert .mts into Apple ProRes HQ. I am a happy PAL user with 25p. I have noticed that Noise Reduction seems much better in high ISO, I may post some tests on Vimeo soon. I still wonder with Panasonic gives so crapy, unclear, unstandard names to its video modes ! 720p50p/1080p25p/1080p24p would be so much better than "HBR" "Cinema" "FHD" "SH" "FSH" and WTF ! why 25p is name "High Bitrate" as is not any higher than 1080p 24p? (24 Mbs max?)
In the end It is a decent and good update, I hope our FRIEND will bring a great hack with intra codec !
Any lens will do. I just updated mine the past hour with an old FD lens on, and it was fine. You just need to make sure you have 3 bars of battery (ie fully charged) or else it won't let you update.
