Thanks, the chair looks normal. It does appear if your intention was to have the chair in focus (1st image), focus was actually behind the chair. You can see this on the floor behind the chair. Also, it certainly appears you were using a fairly low f-stop since the DOF looks fairly tight considering the field of view. I'm not sure where focus was on your last chair shot; although it appears it may of been just short in front of the chair.
testing out Sir @driftwood AQuarius 3.63 latest and loving it! Problem is, it's not playing smoothly on VLC on my mac but plays find in FCP. Anyone encounter that problem?
Just stepped into the hack world. Waiting for my sandisk extreme card to put something more intense than the driftwood 132mo GOP3, but big thanks already for your work.
Tested sames shots in low light and iso 500 and 3200 with old firmware and hack. The noise quality did not strike me, I can see sligther definition increase. Though I did not anticipate so much difference concerning the mouvement. It seems so much more stable, natural, don't know how to say but it striked my wife who don't know shit about those things.
I have a disk write problem with 720p 50fps with your AQuarius version 1.
Recording stops after 1.30 min. Tried it with both kit lens and Canon FD @ ISO 3200 and 5000. I have a newly formatted 16GB Sandisk Extreme 30MBs card.
Since Q12 version was improved, although there is no telling whether it is helpful to someone, I stick this patch. I think that even Q14-16 is convenient as I stated above.
NOTE: The first screen shot is the wrong and the 2nd is right.
I am a noob and afraid I am getting lost in the details by the various driftwood 170+ mb gop 1 patches. I used gopstoppa and think the results are incredible. Thank you driftwood for your amazing work. I am now looking to upgrade and am not sure the difference between AQuarius ver 2 and reAQuainted patches.
I am using driftwood's AQuarius version 2 hack without changing any of the settings. 1080 24p at 170Mbps AQ3 GOP 1 looks fantastic but 1080 60i at 124Mbps AQ3 GOP 1 looks terrible, much worse than without the hack. I took a sample video and have attached some snapshots. The first photo is taken using 1080 60i without the hack at 17Mbps. The second photo is taken with the hack using 1080 60i at 124Mbps AQ3 GOP 1. For reference I have attached a third photo taken using 1080 24p at 170Mbps AQ3 GOP 1.
I viewed all three's video information in MediaInfo. The first video taken at 1080 60i without hack has a bitrate of 16.6Mbps. The second video taken at 1080 60i with the hack has a bitrate of 63.2Mpbs. The third video taken at 1080 24p with the hack has a bitrate of 150Mbps.
What are best settings in order to obtain maximum image quality in 1080 60i?
No, it's not deinterlaced. All the images are snapshots taken from the video straight from the camera. I have not done any manipulation or deinterlacing.
@zzap64: 60i gop1 doesn't even look interlaced.. It's a bit hard to tell from interlaced footage (the actual quality of it) without deinterlacing.. It definately seems like the fields behave differently in gop1.
@zzap64 You can take up the frame limit for 60 higher (to increase the size of i frames) if youre not using 720p60. Increase it a thousand each trial until youre happy it woprks with your sd card. the moment it fails or stops recording early, then go back to the last working setting on the limits.
@driftwood Thanks. I've never looked in the 'Patches for testers' section before. I'll try changing the frame limit. Have you discovered any best image quality setting for 1080 60i?
I have been testing the AQuarius patch (the original one)... I know at this bitrate the files will not span past 4gb... but I have found that if I let the camera record up to that point and stop on it's own (because of the limit), I cannot play back the video in camera, or capture it with FCP... however, the file is there, and plays with VLC no problem. Has anyone else encountered this bug? If I stop the camera manually before the 4gb limit is reached, the files are fine.
