ReAQuainted and AQuarius brings in the Auto Quantiser settings which offer better macroblocking potential. AQuarius ver 2 update brings you 1080i60 with AQ3.
@driftwood What is your best patch? I have used them all... I like GOPstoppa and reAQainted a lot. What are the major differences between GOPstoppa and QuantMeBaby? And what did you change for AQuarius?
*** NEW *** AQuarius version 2 for ptools 3.63d edition with 1080/60i on GOP1 INTRA (the impossible to work with 720p60 is left on its original 30 GOP). All the old features of 1080p24H and 720p50/1080i50 are as before - GOP1 INTRA.
The old AQuarius patch WILL NOT work on the new ptools 3.63D. So please use this when flashing new firmwares.
Test away!
Driftwood Version 2 of 'Aquarius' for ptools3.63d - sete.zip
I dig the motion improvement but i'd like to stay stable. Planning on buying a sandisk extreme, right now i have a Class 10 from silicon power. Would you advise a GOP3 preset or QuantMeBaby's fine?
(Download one of the 'packages' with more than one setting set to a;b;c; etc.. and work out which one you like!) 44mbps is VERY stable. (and its still 4x stock FW)
Hi guys, Can anyone recommend me any patch that can work well for live event shooting like a wedding? I am looking for something very stable and it cannot be GOP1 cuz of file size. Spanning will be nice too.
@nktdr you can only use AQuamotion (100 mbps) with Transcend cards. To use the other settings, pick up Sandisk Extreme (not UHS-1, but the old school ones), currently on sale at B&H for a mere $50 for 32 gigs. Get em before there gone (I got 6).
@soru Since Q12 version of GOP3ZILLA was made, I stick this. Probably, since this may be unable to be used with neither 30p nor EXTELE, please use only with 24p. Possibly, since I may have improved this to a slight degree, this is the test patch. :-)
I test yours (Driftwood INTRA Patch: 'AQuarius' ). Quality is exellent, but with my SanDisk Extreme i get some errors with scenes where was lot of movment or Zoom while recording.
@soru Thanks mate! ;-) Although this patch needs some points to use since it has separated from the theory, supposing someone can use this "Outlaw setting", I will also regard it as not bad.
Hi, everyone. This is a sample of bkmcwd's 66Mbps 3GOP AQ3. I think that it is one of his best patches for incredible resolution. And most of all, It saves the card storage. I'll recommend you to take the patch for your travel. In my test, 1GOP for beautiful noise, 3GOP for resolution and saving storage, I think.
# though the only part of sea is shot with GH1 hacked.
@pinger007 Thanks! :-) Although the instruction of only gimbal part is in my YouTube channel, regrettably it is altogether explained in Japanese. :( watch?v=x4vxNaO2Yi4 watch?v=dL6uDNcLBKE
@drogo its a H264 thing, personally no idea - but there is a tone of information on google about it. Personally I think that if 'cpb_delay' is better- then don't worry- as 176mbps is peak.
Currently the current AVCHD is going to be the best quality for a while- as VK has stated that this PTool update will mainly be concerned with other things.
I've been testing Driftwood's 'AQuarius'.... but I am curious, can someone please explain to me why the bitrate was dropped by 6mbits for the sake of better "cpb_delay timing"? What is the advantage of better cpb_delay timing? Is it just more stable?
