@flighttime Glad to receive your message, sorry for reply late, I have sent message to you, you could contact our support for help, they will slove your problem.
Greetings. I've seen this request before on this thread but realize you can't answer it directly on the site. I recently purchased a 4200 and have managed to lose the default settings in the SimpleBGC app. I would truly appreciate the settings for all three profiles as the gimbal was working reasonably well out of the box. Two other issues... I can't switch between settings and don't hear a beat when attempting nor will clicking 4 or 5 times initiate anything. I'm also having trouble updating. It fails on both Mac and PC using bluetooth and after installing all drivers, I'm unable to connect using USB. After the drivers are installed on the PC I see COM1, COM2 and COM3 but none allow for a connection. On the Mac, I've never seen any change at all after the drivers are installed. Thanks very much for your help.
How to make creative camera movements?
Japan's park scenery is very good and the picture looks so smooth. This Japanese users shooting technology is very good.
Fantastic wedding show presented by Love Bridal shot by a Filmpower upgraded Nebula 4200 with tactical grip.
Take a look at this video about BTS Adorama Through The Lens S03EP6
@olli66 You could see the picture and video below. The tactical grip could have double 1/4 scerw hole for DIY your own set, variety shooting mode.
I just ordered the Nebula 4200. I hope the setup is not too tricky. I am exited! Any possible way to mount it on a tripod/monopod/crane or to take some weight off with some other accessoir?
A great memory of a Chriatmas market 2016 recorded by Nebula 4200!To feel the season which is peaceful and delightful.
Upgraded Nebula 4200 5-axis tactical version shot by T-one Image.
Roaming around in the Kyoto gloaming
The footage is so smooth, this is a clear winter day under the lens.
The footage is from Adorama TV and shot by Timbuz.
Test with nebula4200——the effect as a slide moving
Picture is very smooth, looks nice.
Nebula 4200 tutorial video
Nebula stabilizer and Nebula Gyro Jib live shots at IBC
Nebula 4200+Camera Sony A7Sii+Canon 10X22mm
Malcolm used a Filmpower Nebula 4200 5-Axis Gyroscopic Stabilizer and a Canon 5D to capture the smooth moves by this fantastic dancer.
Nebula 4200 5-axis and Sony a7s ii
@creativegrapes Sorry for reply late, I have sent message to you and will hlep you to slove the problem.
