Nebula 4200 - strange monster
  • 221 Replies sorted by
  • Nebula 4200 5-Axis Gyroscopic Stabilizer and Sony A7s II, fits perfectly together to bring the best quality photography.
    720 x 720 - 290K
  • Nebula basic settings-how to balance the gimbal
  • A great combination! Nebula 4200 5-Axis Gyroscopic Stabilizer and Blackmagic Design Pocket Cinema Camera.
    814 x 1024 - 97K
  • Nebula 4200 5-axis gimbal unboxing
  • Weddings are filmed so easy and smooth with the Filmpower Nebula 4200 which is ideal for filmmakers who are keen on taking dynamic images and shooting wedding videos. Try the new combination of the Nebula 4200+Nebula Remote, to capture every action clearly and record every moment perfectly, you can enjoy a simple and smooth process with better results as shown in this beautiful Chinese wedding video.
  • Sony a6300 beautiful slow motion.
  • Clear videos are taken with a Sony A7 and the steady smooth handling of the Sony with the Nebula 4200.
    598 x 479 - 465K
  • Beautiful nighttime video taken in Japan.
  • The great combination of the Filmpower Nebula 4200 Gyroscopic Stabilizer and the well known Canon 70D.
    600 x 571 - 448K
  • Another wedding film by Nebula gimbal.
  • The gimbal of Nebula 4200 has got a wider structure, and the user can open the a6300 camera screen, and then watch the images while recording.
    720 x 720 - 307K
  • Using the Nebula 4200 5-Axis Gyroscopic Stabilizer during filming of the Adorama NYC Dance Project.
  • Beautiful chinese wedding film shoot by 5-axis gimbal
  • Nebula 4200 & ZEISS Batis f2.8 18mm & Sony A7R II
    599 x 545 - 40K
  • Nebula 4200 3-Axis Gyroscopic Stabilizer and bracket,which is a good combination.
    598 x 599 - 59K
  • @Jasketti Very happy to service for you, because the forum has a regulation, I will send you a message to slove the problem.
  • @Avril_Lovin you seem to be connected with the manufacturer right?
    I bought the Nebula 4200 few months back and I havent made up my mind whether I hate it or like it. It was afforable and after spending a good while setting up the gimbal program setting I finally managed to get it to work. Out of the box it was just acting weird.
    Balancing the the camera is however quite easy.
    I also bought a remote a week ago but havent had success connecting it with nebula 4200. The remote just says connecting... (and yes I have checked that blutooth is off on computer/phone)
    So I wonder if you can help out with this connection problem?
    Also it would be of great help if you could send the (working) factory settings for the gimbal (all modes: follow, semi follow and lock).
    I believe some settings must be of since the followmode has some jitter on pan axis in follow mode. This is especially when turning the gimbal slowly.
    I appreciate any help from anyone.
    I am also happy to answer any questions regarding the gimbal. And if I get the remote to work, then about that too :)
  • Nebula 4200 5 axis and Sony A7R II with objective 24-70 mm test.
  • Another fantastic wedding video using Nebula 4200 5-axis gimbal.
  • Use three kinds of gimbal mode, bring different experiences.
  • Nebula 4200 run up stairs test.
  • Beautiful wedding film using the Nebula4200 5-Axis gimbal.
  • As you can see the photographers footsteps are not noticeable whatsoever when using the Nebula 4200.
  • In the early 1970s, a commercial director and also producer named Garrett Brown began to explore a new system to avoid the jitter while shooting videos. He intended to create a high portable device not only separating the camera from photographers but improving the balance of the camera to reduce vibrations and shaking as well.
    This goal was achieved in 1973, by inventing the simple but innovative machine – Brown stabilizer (later renamed: Steadicam).
    At that time, Steadicam attracted a large number of users for its low cost and simple structure.
    Buy as the rapid developing of science and technology, emerged the shortcoming of Steadicam.
    Although Steadicam has made great differences, there are many restrictions to the detriment of current photography needs. Such as Steadicam is too big to be used for narrow scene, and too heavy for long shot. And the fatal weakness is the difficulties for beginners to start in a short time trial, users must take a long time of training to familiar with Steadicam and use it well. With wrong posture, it is counter-productive to keep stable. Still, usually we need to spend a long time on Steadicam for adjustment and balancing.
    Now, the cutting-edge Nebula 4200 5-axis stabilizer has arrived to end the 50-year history of Steadicam. You have to admit that the lightweight and compact stabilizer more suits our needs for its user-friendly and excellent stability.
    However, designs of 3-axis stabilizer cannot address the very crucial part: the bounces caused by photographers’ step while making videos. To solve this problem, Nebula 4200 5-axis greatly integrated the traditional advantages of Steadicam and the latest technologies of gyroscope stabilizer.
    Turned the standard notion of 50-year Steadicam’s structure, 5-axis spring arm is Nebula’s original design, inspired by the damping system of F1 racing cars. Nebula 4200 is known as the only mould-casting gyroscope stabilizer in the world. All parts of this innovative product are made of metal.
    The effect of double spring arm in contraposition is both rebound and absorbing. But the mass of stabilizer and camera appropriately maintains inertial. Except the intentional tremor, the two spring arms of 4200 can absorb any vibrations and bounces under payload acting on the vertical axis. With this kind of buffer, Nebula 4200 reduces vibration, retards speed, makes shooting more smooth even facing hard bumps.
    They are just like the vehicle suspension system, on the one hand isolates road noise, bumps, and vibrations, on the other hand provides enough sustenance for stabilizing car body while making a turn. Besides vertical axis, with different spring tension, the two spring arms are also able to filter part of the vibrations on horizontal axis. That’s why we call as 5-axis.
    Two dovetails are added on spring arm, to show the flexibility of combinations. The standard 1/4 screw hole also makes it easy to carry most of the photography accessories. Every detail we designed is for filmmakers in search of 2 “P”s: professional and possibilities.
    Double spring arm in contraposition turns the standard notion of spring arms in line, in order to spread bounces caused by photographers’ step while moving over two handles. Thus perfectly reduces the jitter and jerking and improves users’ manipulation of stabilizers.
    497 x 497 - 84K
    500 x 500 - 174K
    800 x 462 - 65K
    280 x 158 - 514K
    1280 x 853 - 323K
    634 x 441 - 18K
    497 x 497 - 80K
