@driftwood here's a Pizza in Hd with yr latest reAquanted 176 intra aq3! Settings : Smooth cinema mode -2-2-2-2, 50 shutter, iso 3200, Nikon 50mm f1.8, Kipon adapter. Uploaded directly the .mts file no color correction just a crazy wihte balance took during the dayligth used indoor. Smooth Cinema is slightly better for indoor.
I think a GH-2 and putting some good $$ into lenses is the way to go. From our experience with the GH-1 and GH-2. Those Panasonic engineers will give us some nice new features and open further hacking when the GH-3 comes out next year. We see the 95mb/s San Disk Cards. There is a ton more headroom for quality in the bandwidth. Of course if we can get 10 bit color, pretty sure we will have 1080p/60 in the next body. Who knows maybe a limited 120 frames per second in a burst mode. I wish we knew who the Panasonic GH-X engineers are, so we can send them a Christmas card.
My university was the first one in Europe to own a RED, I know it in and out and I dare to contradict. Yes, it's all about IQ, not the price. But if you don't see the difference it's good you never bought one…
The hacked GH2 is amazing, I would take it any time as crash cam next to a RED. But the hack can't overcome the serious hardware limitations of the GH2.
If it pleases you, I'd say a very carefully exposed GH2 at 24p can come quite close to a non-MX R1 @ 120 fps handled by a not so good cameraperson and color grader.
@sohus - We have an older RED (never got it MX'd) and I'd beg to differ with you. No, the GH2 won't match the current iteration of RED, but it's damned close right now to putting out an image that rivals the first redcode images back in the day. Where will this lead with the GH2? We don't know, but continuously comparing the price of these two cameras is pointless. The only thing to compare are the images, and right now the GH2 is seriously nipping at the heals of the much bigger, much heavier older brother. Are there others on this forum who own a (or use frequently) a RED and are now using the reAQuanted patch on their GH2? What are your thoughts?
@paglez No, this camera won't be a RED. How hard is that to understand? $700 vs $40.000. No 10-bit, different internals... it does amazing things with Driftwood GOP 1 but you can improve upon the hardware, only upon the codec settings and some other stuff.
Anamorphic Test with @driftwood's reaquainted. Didn't have the time to quite do the razzle dazzle I did with the last test, but still extremely happy with the results -- everything w/the 14mm pancake except the scarecrow with the 25mm leica.
In premiere cs5 with GH2 footage, you should be choosing AVCHD and then the proper frame size and fps (1080p24). However, I just tried the preset for AVC-Intra and it seems the same with GH2 clips from the driftwood GOP1 176 v3 as I have a yelllow line in my timeline. You can always change this in a sequence, by dragging your .mts onto the "new item" icon in the bottom of the project window and premiere will setup your sequence based on your source video parameters. When I do this, it sets up a sequence in AVCHD. If you are having problems with playback, try running resolution at half. And for instant, renderless, full resolution playback of footage from these cameras, you should have a NVIDIA card that uses the mercury playback. And if you don't have the nvidia card listed, there are hacks for premiere too, that enable mercury playback.
as far as premeire 5.5 working with patch reaquainted, I have no issues. At this point, I work with the 24p mts files right out of the camera. But it was a reason I upgraded across the board to i7 with 16gb ram and ssd. I knew it was just going to get worse as the patch quality went up!
Having ssd as your program/boot drive with video files on another drive(not neccessarily ssd) makes as big a diff as fast cpu. I still have stutter problems playing the post encode files with wmp, media player classic does better. My wd media player on the 1080p tv has no issues as long as the final bit rate is under 60.
I shot a lot of 720/60 with latest driftwood reaq. yesterday. I had two times where the camera just stopped recording without an error. But I also had 4 pretty long shots, 1 min plus where it worked fine. sandisk sdhc class 10.
What is the best setting we have for 720/60p? Reaquainted is more stable than the other 176ers, but still not real stable.
I've never had 24p stop. These were demanding clips with trees, running kids and 14-140 lens with long zoom ins and outs. all real world.
The two areas where the quality changes are most noticable without 400% zoom are in 720p and in the way the 24p just kicks ass holding quality when it's graded.
@Vitaliy After GOP1 great Driftwood patches, I think that the only big improvement that remains for our GH2 is a idynamic range improvement. It would possible to get it via ptools? If so, GH2 camera would be at the same level than RED or similar. Do you think so?
Question for those with premiere problems -- are you trying to edit the avchd naitively or with some sort of intermediate codec (I ask because a company I work with is thinking of working with premiere so any sort of information like this is very useful, especially as we'll be shooting on hacked gh2s).
QX9770 16gb ram ssd... works like a charm with vlc. It's clearly with premiere wmv etc. so I d like to know is anyone gave a try with this patch and premiere cs 5.5. Thanks
With Premiere CS 5.5 (win7 64) I have a lot of difficulties to edit the content I shooted with the latest driftwood patch. Everything looks fine under vlc, but lot of "lag" with premiere (even once exported). Any idea ?
@driftwood Thanks for your sharing and efforts. :)
I'm using your 176M GOP AQ3. The quality is amazing.
176Mbit/s means that sdcard should support more than 176MBit(22MByte)/s. So, At least class 10(20MByte/s) is required to use your Extreme settings. It's right??
If I use a sdcard more than 20MByte/s like a Sandisk Extreme Pro 32GB(45MByte/s) I want to get a more I Frame size. By changing "1080p24 Frame Limit=6108808" to more larger size, Is it ok?
And, Is there any plan to support more bitrate for 1080 60i? Relatively bitrate of 60i very low...
I also update the set which can use 80% with Q=16. The frame size under lowlight is large a little rather than the former set of Q=18. And in this as well as a former patch, I-frame size keeps more than 1M also under high stress. Since my friend wanted 3GOP with large I-frame size, I made this. :-)
@driftwood mmm from that sample, i can see an overall improvement on the blacks, but i also can see something strange going on on the grays, specially with motion in a highly detailed scene, on the video you linked, it is more obvious at 2:27 looking at the wheels of the yellow car that appears at the left of the black one, seems like there is, on the wheel itself, and on the trail of movement, like a less bitrate portion of image than in others parts of the shoot
i don´t know if that is actually fixable, or hahahahh if it is only me, and my monitor
and of course, thank you for making with your time and knowledge something that i know for sure i can´t do, not in a million years i could understand what is it exactly what you do, to me is magic, i´m mean you an vitaliy, (and other members of the community) can speak the language of the machines! :) greetings!
