this is so cool! I appreciate your work! thanks!
@humpman I try to multiply Constant 393216 by 1 to 10. Only 1, 2, 4, and 8 that enable G2 to start to record. Among those multiplications, only multiplication by 4 that is successfully created an .mts file. It is able to record for 0.72 seconds before reporting that my card is not fast enough and stop recording. I need to unplug the battery to make the camera off. I sent you a link to download the .mts
@humpman G2 won't start to record if I checked "Constant 393216=1179648". If I unchecked this option, G2 start to record but then will stop and report that my card is not fast enough. I use the Sandisk Extreme 45MB/s 32GB. It should be good for high bitrate.
If I unchecked all the constant (leaving only min qp=0) and lower the bitrate to 44Mbit, then it is stable but won't pass the death chart.@Vitaliy_Kiselev yeah, but that is the way for smart guys, and we used to use hammer for such things.
It would be great achievement to make the bitrate vary between 24-36Mbps instead of 10-100Mbps. we just need to find a way to avoid the bitrate to get too low. maybe the firmware has a minimum datarate to specify. if some people wants it high so they can make it vary between 36-100Mbps, but the big problem in gh1 is not the maximum datarate, the problem is the minimum because it gets too low automaticaly in low detail scenes and in low light.
In GH1 most important thing is to understand encoder logic and adjust or change it. As GH2 encoder is much smarter and GH1 one is utter stupid.
