GH1 cannot be better than this, stable in all recording modes, good enough image quality in all iso, good light, low light (there is no user file here, just the patch because this patch does not use the user file):
second upload has gop10 for wrapped 24p and gop20 for 60p, for better low light performance.
@humpman please, see these two topics about how to avoid banding in GH1 low light high iso videos. there is a trick to make the image very good. The reports say that iso 3200 gets improved. I believe this trick can work pretty good with the last patch I uploaded in previous post above. thanks.
http://www.dvxuser.com/V6/showthread.php?243995-GH-1-GH-13-Fixed-Pattern-Noise-Breakthrough
http://www.dvxuser.com/V6/showthread.php?242979-Shooting-video-at-night-with-the-GH2
In GH1 most important thing is to understand encoder logic and adjust or change it. As GH2 encoder is much smarter and GH1 one is utter stupid.
It would be great achievement to make the bitrate vary between 24-36Mbps instead of 10-100Mbps. we just need to find a way to avoid the bitrate to get too low. maybe the firmware has a minimum datarate to specify. if some people wants it high so they can make it vary between 36-100Mbps, but the big problem in gh1 is not the maximum datarate, the problem is the minimum because it gets too low automaticaly in low detail scenes and in low light.
@Vitaliy_Kiselev yeah, but that is the way for smart guys, and we used to use hammer for such things.
@humpman G2 won't start to record if I checked "Constant 393216=1179648". If I unchecked this option, G2 start to record but then will stop and report that my card is not fast enough. I use the Sandisk Extreme 45MB/s 32GB. It should be good for high bitrate.
If I unchecked all the constant (leaving only min qp=0) and lower the bitrate to 44Mbit, then it is stable but won't pass the death chart.@humpman I try to multiply Constant 393216 by 1 to 10. Only 1, 2, 4, and 8 that enable G2 to start to record. Among those multiplications, only multiplication by 4 that is successfully created an .mts file. It is able to record for 0.72 seconds before reporting that my card is not fast enough and stop recording. I need to unplug the battery to make the camera off. I sent you a link to download the .mts
