GH1 apefos patches
  • 58 Replies sorted by
  • I did all carefully using research about previous GH1 patches and previous knowledge from GH2. So I believe they are correct. But to know this for sure the patches needs tests. Better thing would be GH1 owners do tests, we are a community and basic idea in a community is cooperation.
  • How do you know it's stable when you do not own a GH1?
  • these patches can give you stable recording in all modes, not just 24p.
  • I do not need 24fps. My Gh1 was not spanning and freeze in forest till 2 days ago. Im happy enough with camera which I'm not using anyway:). I will test it if I have time, Thanks for your work anyway.
  • hello @konjow @eyenorth @jleo @Aria @Futurity
    please, can you give some feedback about the patches in first post of this topic? they are the best tweaked patches until now, no need to try all of them, just one... thanks.
  • Versions with double values for constants and limit setting - experimental
    constant for 1080p = 1555200
    constant for 720p = 691200
    limit setting 1024000
    gh1_constants_limit-setting_double.zip
    3K
  • Versions with mid constants and limit setting - experimental
    constant for 1080p = 1572864
    constant for 720p = 786432
    limit setting = 1048576
    mid-constants_limit-seting.zip
    3K
  • Versions with mid and higher constants - experimental
    mid constants versions:
    higher constants versions:
    constant for 1080p = 2097152
    constant for 720p = 1048576
    only use these if patches from previous post make camera stop recording, try mid constants first.
    gh1_higher_constants.zip
    3K
    gh1_mid_constants.zip
    3K
