GSpot, make your GH2 multi-orgasmic
  • GSpot Patch for GH2 Hack
    First Goal: to find the best balance in datarate and IPP frames size inside the GOP3 for 720p50 PAL and 720p60 NTSC to make it inside the datarate and frames configuration which holds good details and good noise, grain and textures at same time.
    Second Goal: to find the best balance in Scalling Tables with Fallback Tables with good noise and textures in low light and good details in low iso good light also.
    Under development - no new versions in this first post.
    previous history:
    http://personal-view.com/talks/discussion/11079/workhorse
    http://personal-view.com/talks/discussion/11199/boson
    http://personal-view.com/talks/discussion/7355/quality-reliability-extended-time-24h128mbps-24l48mbps-sh48mbps-h40mbps-gop3152430
    http://personal-view.com/talks/discussion/11069/apefos-top-settings-6-patches-for-gh2-hack
    http://personal-view.com/talks/discussion/10650/720p-60p-gh2-hack-an-attempt-to-improve-the-quality-stability-and-reliability.
  • 57 Replies sorted by
  • @apefos Thank you for all the work you Put in to make the GH2 a better camera truly appreciate it. I've used your patch in one music video so far still editing but should be done with it in another 2-3 weeks I'll send you a link to watch. Just read your retiring post, even if you don't have the budget or the personel you can still create great imagery in a short film format or making your story line real focused that will minimize the need of a big crew & actors. The way the camera technology is moving now things are getting better & better and easier. I think you should reconsider and keep your BIG Dreams alive, Never give-up friend Cheers..
  • @apefos I like this Gspot hack, looks nice..:D But i just wanted to ask, because i dont have nothing to lose.:p What is best hack for me, im shooting music videos but i want it to be like more of the film look.. I wanna have wide,mid,close range hack..I mean hack that i can adapt on gh2 for every of these 3 also inside/outside. Lenses that im using: Lumix 14-140 f4-5 Canon FDn 50mm f1.7 Cosmicar 6mm f1.2 cctv (now im waiting for macro x0.45 to add on it and make it really wide lol) Avenir 12mm f1.2 cctv lens Fujian 35mm f1.7 cctv lens
    Also a question for a mr. @driftwood Thanks in adv. Salute
  • @apefos I was shooting in PAL.
  • @frullaccia thanks for the feedback. I do not recomend using the versions 10 october. The versions HML 12 october are tested and approved. Nice to see you got a 7 min clip in setH, but the I and J are supposed to work just in NTSC, not for PAL. Did you test the versions 12 october in PAL or in NTSC?
    The most difficult feature to work is the iDynamic, OIS and AF are more easy to camera. Also, the HBR and FSH / FH are more easy to work with the features compared to 720p.
    Edit post: in your previous tests you did it in PAL, so it seems the tests with 12 oct. versions are in PAL also. Remember that 720p is the most difficult mode for stability, so before using the new setH in a job, test it.
  • @apefos So it is. I have made a test comparing your last patches (10 and 12 october) in HBR mode, with AFS an OIS on (in camera noise reduction 0 value).
    12 october patch I could barely see any difference between h, i, j. All these patches always give a striking performance.
    While using the j set the camera freezed after 1 minute; with the i set the camera stopped after 2.40 min., preserving data; with the h set I made a perfect clip 7 min. long.
  • I believe these are the best patches I ever built. In my tests they are completely reliable considering you follow the instructions. Seems to be the final versions for the GSpot. Something like "State of the Art".
    LOW, MID, HIGH - GSpot Mature Settings - Patches for GH2 Hack - Versions 12 october 2014
    Developed with PTool 3.65d
    Works for PAL and NTSC
    Patches with correct datarates considering quality and stability.
    24L datarate follows 720p datarate.
    24H is higher datarate for better quality.
    Versions are separated for 720p considering a choice between quality or to priorize the use of the electronic auto features from lenses and camera body.
    Electronic auto features are: Auto Exposure, Auto Focus, OIS image stabilization, iDynamic, iResolution, Noise Reduction.
    H-switch: in 720p the I frames size and the P frames size is different in the SH and H slots. Use the SH slot for most situations including high iso low light, and use H slot for low iso good light details. In the H slot the I frames increases in size and the P frames decreases in size, the datarate is similar to SH in good light low iso, but is lower than SH in low light high iso. The H-switch amount is proportional to the needs of each version, and makes more sense in the LOW version for NTSC and PAL and in the MID version for NTSC. H-switch was developed because the use of electronic auto features does not allow enough datarate in 720p for both noise and details simultaneously. With these features disabled the HIGH version allows both noise and details quality simultaneously for NTSC.
    Also, in terms of stability for 720p, try both SH and H, a small difference in datarate, one can be a little more stable than the other. Same thing for FSH and FH.
    The versions:
    LOW: setA
    • h-switch for better details in H mode in both PAL and NTSC, a must have
    • electronic auto features works for PAL and NTSC
    • good quality for 720p50 PAL, average quality for 720p60 NTSC
    MID: setB
    • h-switch for better details in H mode, makes more sense for NTSC
    • electronic auto features works for PAL in all modes
    • electronic auto features works for NTSC in almost all modes, not in SH, try only one feature in SH NTSC
    • top quality for 720p50 PAL, good quality for 720p60 NTSC
    HIGH: setC
    • no h-switch, not needed
    • electronic auto features does not work
    • top quality for 720p60 NTSC, superb quality for 720p50 PAL
    SUPER HIGH: setH
    • maximum datarate for 720p50 PAL before camera freeze
    • for the datarate freaks, can be unstable
    HYPER HIGH: setI
    • 720p always freezes the camera in PAL when shooting the death chart
    • only worth try for NTSC
    • for the datarate geek nerds, can be unstable
    ULTRA HIGH: setJ
    • not tested, settings are math calculations,
    • small chances to work for 720p60 NTSC, but never for PAL
    • are you crazy? better go to the coffee shop, maybe you meet Alexa there
    The patches use low GOP to get better texture and noise quality.
    There is no GOP 3 for 720p60 in the LOW, MID and HIGH because it makes the I frames size to be below the quality limits. Comparing the amount of time that each I frame and each group of P frames in each GOP keep on the screen, 720p50 GOP3 and 720p60 GOP4 are similar, so the texture and noise perceiving are similar.
    The choice of versions is more related about if you need electronic auto features or not. This is because the camera cannot handle high datarates with these features enabled in 720p, so it is a matter of priorize quality or features. For PAL this is not an issue, using the MID setB solves both things, but NTSC is different, see:
    Advice for PAL: use version MID setB because the image quality is great for 720p and the electronic auto features works.
    Advice for NTSC: use version MID setB if you need electronic auto features, the image quality is good in all modes, in 720p use the H which is better for detais and works with the features. If you need better textures and noise quality in 720p use the SH but maybe just one electronic auto feature will work at a time. A tip is to avoid camera shake and exposures changing from bright to dark areas, this avoids stop recording in SH NTSC in the MID setB version. Other option will be to use the version HIGH setC to get great image quality and use version LOW setA to get the electronic auto features working in all modes. If there is no artificial light in the shoot it is possible to shoot PAL in NTSC lands.
    Changing PAL/NTSC or NTSC/PAL: before changing in the menu, turn camera off and remove the memory card. Then turn camera on, change it in the menu and turn camera off again. Then remove battery, insert battery again, insert another memory card, and turn camera on. This is a must to make the camera to work properly. You need two cards, one for NTSC, another for PAL, both formated in camera with correct PAL or NTSC in the menu. Label the cards to know the video format of each card. If you have only one card, you need to format it after changing the menu.
    When using the camera and/or lens features, try to perceive which features can be combined and used together without stop recording. 24H, 24L, HBR, FSH and FH are more stable with these features. SH and H are the most difficult to work with the features without stop recording, this is the reason there are the HIGH, MID and LOW versions. Also it is good idea to try to use one feature at a time.
    These patches push the GH2 to the limits in 720p so it can stop recording, but the ini files was tweaked to avoid camera freeze. In LOW, MID and HIGH versions, if it stops the file will be saved and camera return to stand by mode, so if stop recording happens, just wait camera return to stand by and it can start recording again, no need battery pull, no lost shoot.
    LOW, MID and HIGH versions have more conservative datarates because very high datarates just increases chances of stop recording with minimal benefits in terms of image quality, even in very fast memory cards.
    Careful tweaking in GOP TABLES and DATARATES.
    Using FlowMotion MAtrix.
    Tests done with the Lumix 14-42mm 3.5-5.6 kit lens.
    Tested with and optimized for the Sandisk 45MBps 32GB SDHC card, and above. Try setA and setB in lower speed cards. Try setH and setI in higher speed cards. Best luck on try the setJ.
    HML_hswitch_12october2014.zip
    66K
  • HIGH-A, MID-B, LOW-C, LOW-D, EXTRA HIGH-J, HSWITCH BUNDLE -versions 10 october 2014
    isntructions in the zip file.
    H-M-L-L-EH_45_hswitch.zip
    54K
  • @frullaccia @driftwood @Vitaliy_Kiselev @zsound @spreeni @TrackZillas @cbrandin @NikolayM @JayUKB @producer @joethepro @Aashay @caveport @LPowell @maxr @duartix @Azo @towi @yskunto @marciocons @kris @all other patch developers
    Thanks for informations in P-V topics, for participation in the workhorse, boson and gspot topics, for all the help, it was essential for me to achieve the results.
    It seems that I found the limits of the GH2 for quality/stability/features enabled and also the datarate and gop configurations for highest quality in 720p, and also great quality in the other modes. Now it is time for carefull tests using the GSpot HML bundle with H-switch, to perceive if it is completely reliable or if it needs adjusts.
    After that, with the base already done, I will can start to experiment with matrices, taking into account the matrices design, quantization, and also it's interaction with the other settings in the patch, mainly the gop tables.
    It is good to solve the mysteries, the mind keeps calm and there is no hurry, the job turn into pleasant to do, and now I can do it in parallel with the other tasks.
  • H-switch
    This is a new feature developed specialy for the LOW setC patch version of the HML bundle.
    The LOW setC version from the HML bundle is useful for 720p60 NTSC because it allows the use of the electronic auto features of lenses and camera body, but to make this possible the datarate is low to avoid stop recording in 720p60... So I developed a switch to increase the I frames size when shooting a good light detailed image:
    Use the SH slot for most situations, including low light, or good light without so many details, also for shoots with motion.
    Use the H slot for very detailed images in good light, better for more steady shoots, it increases the I frames size which is useful in low datarate patches to get good details.
    Probably some people are wondering why I do not put a high datarate in the SH and a low datarate in H instead of using different patches. The answer is simple, it just does not work. the datarate becomes lower in low light, but in good light detailed scenes the datarate keeps the same in both slots no matter the numbers. This behavior is also present in the Cluster GOP3, seems to be no way to solve, so the low gop patches with gspot configuration in gop tables cannot have different datarates in the SH and H slot. this is the reason I developed two patches for 720p60: HIGH and LOW and also the H-switch in the LOW. People in PAL lands are lucky because the PAL 720p50 has a sweet spot in quality and stability to use the electronic auto features, the MID version.
    Things got very mature now, the HML bundle and now with this H-switch are the best patches I did until now.
    h-switch.zip
    10K
  • @frullaccia the "not updated version" is unstable in some modes, this is the reason there is the "updated version".
  • @apefos I just started trying the last hml 45 zip (not the updated version) and I found it unstable (but with a wonderful 24H performance). I was using a 90Mbps card.
    Probably you are right about sd cards speed. A faster card could not improve the camera stability.
  • @frullaccia please download the last updated versions, more stable, second zip file in my last post.
    After tweaking the HML patches improved to make the electronic auto features to work, I perceived that probably the 95Mbps card will make no difference... It seems that the stop recording when using these features in high datarate patches is more related to the camera processor power instead of datarate flux to the memory card. After careful tweaking in all other settings in the ini file, the only way I could make these features to work was lowering the datarate, and the amount to lower the datarate is proportional to the fps (frames per second) being used. More fps means that the camera processor needs to work more to pack more frames. So my intuition says that a faster card will not make the electronic auto features to work in higher datarates for 720p. The updated HML patches (second zip file in my previous post) seems to be in the limits of datarate which allows the electronic auto features to work. I will do tests when the 95MBps card arrives.
    After lots of work in the patches, I perceived that the stop recording is different from camera freeze. If camera freezes there are wrong settings in the ini file, the patch is not correct and breaks the codec. The stop recording and return to stanby mode is different, it can be related to two things: a slow memory card, or to a combination of high datarate + high fps + electronic auto features stressing the camera processor. Due to this conclusions I believe the 95MBps card will not make significant difference compared with the 45MBps card, because the card does not improve the camera processor. I will have the answers for this when the 95MBps card arrives.
  • @apefos Your previous patch is excellent. Of course you are right: changing the datarates doesn't help at all. I could see it yesterday during my working test.
    Going to try this last one.
  • GSpot: High, Mid and Low - developed considering quality and stability with electronic auto features enabled. Versions 07 october 2014
    Use the updated versions, second uploaded zip in this post. (the older first zip is unstable in some modes)
    I decided to finish the job for the 45Mbps card, so people who have this card or similar card can use these patches, with special tweaking for using the electronic auto features from lenses and camera body.
    HIGH, MID, LOW: GSpot Mature Settings - updated ini files in the second zip
    only three patches with correct datarates considering quality and stability.
    24p datarate follows 720p datarate due to stability, but with a small step up in 24H.
    versions are separated for 720p considering a choice between quality or to priorize the use of the electronic auto features from lenses and camera body.
    try both SH and H, there is a small datarate difference and one can be a little more stable than the other. same thing for FSH and FH.
    HIGH: setA, tweaked for quality, electronic auto features does not work, top quality for 720p60 NTSC, superb quality for 720p50 PAL.
    MID: setB, electronic auto features works just for PAL, with luck only OIS works in NTSC, top quality for 720p50 PAL, average quality for 720p60 NTSC
    LOW: setC, electronic auto features works for PAL and NTSC, average quality for 720p50 PAL, bottom quality for 720p60 NTSC
    the choice of versions is more related about if you need electronic auto features or not. the reason is because the camera cannot handle high datarates with these features enabled, so it is a matter of priorize quality or features. for PAL this is not a big issue, using the MID setB solves both things, but NTSC is different, see below:
    advice for PAL: use version MID setB because the image quality is great for 720p and the electronic auto features works.
    advice for NTSC: use the version HIGH setA to get great image quality for 720p or use version LOW setC to get the electronic auto features working.
    electronic auto features are: Auto Exposure, Auto Focus, OIS image stabilization, iDynamic, iResolution, ETC extended teleconverter, Noise Reduction. Try using just one electronic auto feature at a time, or try to perceive which features can be combined and used together without stop recording. 24H, 24L, HBR, FSH and FH are more stable with these features. SH and H are the most difficult to work with the features without stop recording, this is the reason there are the HIGH, MID and LOW versions.
    these patches push the GH2 to the limits in 720p and 1080i so it can stop recording, but the ini files was tweaked to avoid camera freeze. if it stops, the file will be saved and camera returns to stand by mode, so no need battery pull, no shoot lost.
    More conservative datarates because very high datarates just increases chances of stop recording with minimal benefits in terms of image quality.
    tested and optimized for the Sandisk 45MBps 32GB SDHC card, and above.
    HML_45.zip
    32K
    HML_45_updated.zip
    52K
  • @apefos Ok, I will use the 96Mbps. In any case today the patch has done a very good job. Frankly, the camera stopped two times this morning, but after a little time everything was ok. This patch is a damn good one! I think I will keep it for tomorrow.
  • @frullaccia you will get no benefits raising the datarate, just make it unstable. there are many settings tweaked in each version which works together for specific datarate, everything must be changed.
    the last three versions are pretty good, stable and great quality. please follow instructions from my pevious post, it tells what version can do.
    when the 95Mbps card arrives I will test the 104, 112 and 120 again.
    I cannot work anymore without the new card, it is time to wait.
    I will stop posting for a while until the 95Mbps card arrives, hope all the people understand...
  • @apefos Today I'm using your last patch for our documentary film about a famous artist. I already used Wkhrs Flmtn 120 and Gspt Nbl 112 in HBR Pal. I have changed the datarate of this last Gspot to 104. Later I will tell you more about this patch.
    All settings in the patches are very well done now, seems to be nothing else to do. So now it is a matter of datarate.
    before start experimenting with new matrices, I will need to find the correct datarates first, two of them, one for high quality noise and details at same time, and another for perfect stability with all camera and lens features enabled.
    The post above already have three versions with this attempt to find these datarates, the higher for best quality and the lower for enable the electronic features. tested with the 45Mbps card.
    I just would like to do a careful fine tuning in finding these datarates using the 95Mbps card to get the best possible from the camera.
    first datarate will deliver the great quality for noise and details at same time, today the 96Mbps ntsc versions allows this, the pal versions can have this from 68Mbps to 80Mbps, I need to do new tests to find where it is the sweet spot for pal. probably this datarate to allow perfect noise and details at same time will not work with electronic features like AF, AE, OIS, iD and iR. It will be for native lenses with all features disabled and for manual third part lenses.
    second datarate which allows to use all electronic features of lenses and body: AF, AE, OIS, iD, iR. This datarate will be lower and probably will not deliver the great noise/details quality simultaneously, needs tests. but will be very useful for using the features from the lens and camera.
    I will try to put the first higher datarate in the SH slot and the second lower datarate in the H slot, I do not know if this will be possible, if not I will do two patches, first for high quality and all features disabled and second for average quality with all features enabled.
    I think this is what people needs, reduce the number of patches and make it work for quality and stability, if possible in just one patch, if not possible it will be in two patches.
    I will need to wait the 95Mbps card to arrive to do this (I ordered one), doing this with the 45Mbps card will be waste of time.
    after this, with the two best datarates found, so I will can start experimenting with matrices because the patch base will be ready for it. I know that different matrices can need some tweaking in the patch but it will be small thing to do, because the main development will be already done.
    Time to wait the 95Mbps card to arrive...
  • Special versions: NTSC and PAL working in same patch - FlowMotion Matrix
    setC = 64Mbps
    setE = 80Mbps
    setG = 96Mbps
    64Mbps, for situations where the electronic features of the lens and camera are a must have. lower datarate allows more stability and works better with the electronic lenses. try using some of these features enabled together, auto focus, auto exposure, idynamic, iresolution, ois image stabilization.
    80Mbps, a mid point which allows some electronic funtions to work, but not all. when using electronic features, try use one at a time, many features enabled together can make stop recording to happens. these features must be use with care and not combined: auto focus, auto exposure, idynamic, irasolution, ois image stabilization.
    96Mbps, higher datarate increases image quality but just works good with manual lenses without electronic contacts, manual exposure, idynamic off and iresolution off. Try it with electronic lenses, but with all features disabled.
    tip: changes in exposure when recording a video can make the camera to stop recording in all versions. when the camera is pointed to an area with sunlight and then it is moved fast to a shadow area this strees the codec and can make the camera to stop recording. pushing the camera to the high limits will never be so stable as can be a conservative settings in the patch. the lower the datarate the less this issue will exist.
    Careful tweaking in the GOP Tables after comparing with Cluster patch. Stable versions considering that there is no camera freeze with the Sandisk 45Mbps card. if the camera hardware are puched so far it can stop recording, but it saves the file and camera go back to stand by mode. so there is no problem in the ini file. it is the camera and/or card limits. Try a faster card or load a lower datarate version.
    Format the card in camera for better performance. After changing the camera PAL/NTSC always turn camera off, remove battery, insert battery again, turn on again and format card.
    when pushing the camera and card to the limits there are some tradeoffs, no free lunch... due to this there are different datarate versions, to chose best one for the camera+card+lens combo combined with the features to be used.
    Tests done with the Sandisk 45MBps card
    Enjoy
    special.zip
    32K
  • @apefos I will test it. By now I can't use your last ini file. Please zip it and redo the uploading. Thanks.
  • Special Patch Version - GSpot FlowMotion
    NTSC and PAL working in the same patch.
    AF, AE and OIS working in the SDC4 death chart without freeze.
    GOP TABLES tweaked carefuly for 720p50 and 720p60.
    GSpot configuration for noise and details quality with improved quality/stability balance in 720p
    Try both SH and H, try both FSH and FH, same datarate, but probably there will be one more stable than the other.
    My tests shows that more stability than this only can be achieved lowering the datarate.
    @frullaccia @TrackZillas @zsound @spreeni @JayUKB @driftwood reports and feedbacks are very welcome.
    sete.ini
    10K
  • BestICanDo
    This seems to be the best I can do for 720p60 NTSC, I cannot find ways to improve the quality and stability anymore, only the 96Mbps version at this moment for stability tests, if it stop recording or freeze the only solution will be lowering the datarate.
    @frullaccia @driftwood please do your tests, I recorded 2 minutes of the SDC4 death chart in NTSC 720p60 SH with continous AF and OIS enabled, handheld camera movements and steady, no stop recording, no freeze, 14-42mm kit lens.
    HBR 30p and FHS 60i also working in the SDC4 death chart with AF and OIS enabled.
    (I only tested the FlowMotion version)
    setG = flowmotion matrix
    setH = nebula tweaked matrix
    BestICanDo.zip
    20K
  • @driftwood @frullaccia
    I did new tests and found some good things:
    did a try in a similar gop table from the "cluster v4 all gop3" , not a direct copy, but a similar design. it delivers a variable bitrate: when there is details it increases datarate, when there is just low light and flat surfaces it lowers the datarate. I perceived that this is not good because it hurts the noise quality in low light, so the previous gop table settings from GSpot are better to hold and keep the noise quality because it makes the gh2 almost constant bitrate no matter the image or light or iso.
    did a try in my last uploaded versions using GOP4 for ntsc 720p60 and using the number 42 instead of 43 in the gop tables for 720p60: good results!
    the GOP4 is very good for 720p60 because it allows the I frames to increase more the size when there are details in image delivering a better quality. Also, in the low light noise image, the gop4 does not hurt the fine random noise, it is good. comparing gop3 for 720p50 and gop4 for 720p60, the amount of time that the I frames will be on the screen are similar, and the amount of time that the PP (in gop3 pal) or PPP (in gop4 ntsc) will be in the screen are similar also, so the noise perceiving is pretty equal to the eye when comparing gop3 for pal and gop4 for ntsc in 720p.
    the number 42 in the gop table instead of 43 did not hurt the image quality and seems to be more stable.
    give a try in the GSpot FlowMotion version uploaded september 30 setJ version with the number 42 and gop4, it should be stable and great quality, give it a try on the death charts with AF and OIS desabled and also with AF and OIS handheld in outdoor shoots. If not stable enough compare it with the setI september 30 which has gop4 and the number 43 in the gop tables for 720p60. one of these may be the one for 720p60 ntsc.
  • @frullaccia thanks for feedback. AFon and stabilizer are difficult to work in very high datarates for 720p. try to find which datarate version will do the job. in the GSpot for PAL from setE and above are great quality, and in GSpot for NTSC from setG and above are great quality. I believe you can find one to give you more time recording with all these features enabled among all datarate versions. You can also try lower datarates versions below setE Pal and below setG NTSC for use with AF and OIS. With these features disabled maybe it will be more stable in the higher datarate versions. for me to do tests I need to wait the 95Mbps card to arrive.
