@Vitaliy_Kiselev did they sort out a packaging problems ? Also can any owner tell me the body is it alu or steel ,the video above says it but i'm not sure (i mean the part between "flags" and filter-holders (usual plastic on other matte boxes)
@Vitaliy_Kiselev I tryed, but its hard to pin down the centre of the lens and I thought there must be a white paper somewhere with this kind of information.
And isn't this the right topic? It is related to a post a couple of posts up, because the height of the camera must match the mentioned 85mm standart for matteboxes;-)
I'm in LA, as well, and I just bought a Trusmt from ebay a few weeks ago. I won the auction on the 9th, and they were on a holiday at the time, but notified me immediately that they would ship on Tuesday the 13th, after their holiday. They said that shipping would take about 3-5 days. It arrived on Friday, the 16th. Pretty fast shipping.
I ordered Trust MT's Matte Box and their customer service, quality and shipping speed are great but, considering it ships from China, there is no way you'll get it before Saturday. If you live in LA your best/fastest bet is to go a AbelCine, Film Tools, Sammy's, etc. and dish out top dollar or to order the D-Focus from Jag35, who are based in LA and deliver pretty quick here. I received mine within a couple of days. Works great.
To those who own Cinematics matte box, what do you think about attaching Zacuto Universal Donut?
This video uses a separate 105mm ring. The Cinematics matte box has built-in ring. Just attach velcro around the inner ring. Then attach the Donut. Good idea? Bad idea?
Besides preventing the light leaking, this trick would extend the matte box further away from a camera body when using a small lens.
The distance from the rails to the center of the matte box should be 85mm (industry standard). As far as I know, the TrusMT adheres to that standard. If your camera is higher, you need to lower the camera, it's not TusMT's fault....
Does the Cinematics work with 15mm rails? It wasn't clear from the specs. I already have a lot of 15mm Zacuto rails with my Sniper with Zacuto's Follow Focus.
I've also noticed quite a bit of play in the TrusMT Mattebox. I'm pretty sure it's just the fact that it's the way it was designed. While it's attractive, the play in the swing-away is a little bit disconcerting. It's the way the part was milled.
