GH2 High Quality GOP3 Settings, Series 2: 'AN' Valkyrie, GOLGOP3-13, GOP3ZILLA, Duke, natural :-)
  • 670 Replies sorted by
  • @yda321 Many thanks for your comment! :-)
    Although recommendation is dependent on your purpose, I recommend you latest GOP3ZILLA4, GOLGOP3-13-BETA7s, and latest Valkyrie 444 TZ3 or Lite.
    Please check the top page of this thread.
  • 你制作的固件都很好 不过哪个版本最好的啊?能推荐一个最好的固件我吗?
  • @ users
    My impression is not so bad although I have repeated verification about HBR30p of Duke. Therefore, I see a situation for a while.
    About Spizz T6, since I am considerably satisfied with T4, I cannot decide the directivity of improvement now.
    About other settings, if your impression can be heard, I am glad. :-)
  • Seeing HBR30p, my impression is not too bad.
    I felt the potential to become even better by improving a little. :-)
  • @towi
    Thanks for your comment, mate! :-)
    in HBR/25p things look pretty good.
    Woops! I had forgotten the PAL side!
    I also think 25p is not bad indeed. However, improvement is required in the NTSC side.
  • @bkmcwd
    ummmmm... HBR of Duke is still not good
    I've just tested Duke (only HBR/25p mode) on my codec torture chart and also in lowlight (tungsten)... so these are really only preliminary test. But so far it looks promising (also the JM-SP decoder results look very good!) 30p may be different ...
  • ummmmm... HBR30p of Duke is still not good, although 24p is good. :-(
    I will improve it.
    1295 x 633 - 545K
    1296 x 634 - 560K
    1296 x 632 - 548K
  • UPDATE: Valkyrie 444 TYPE-ZERO3 & 444 Lite
    I updated Valkyrie 444 TYPE-ZERO3 and 444 Lite. :-)
    *FB1 in 24p was only changed.
    bkmcwd Valkyrie 444 TYPE-ZERO3 1.01.zip
    1K
    bkmcwd Valkyrie 444 Lite 1.01.zip
    1K
  • *HBR30p of Duke is still not good, although 24p is good. I will improve it.
    http://personal-view.com/talks/discussion/comment/128510#Comment_128510
    New!
    Duke & Duke Lite
    "Duke" is a new setting based on the new concept, but it is in the structure high reliability at the same time.
    If the character of Duke is denoted by a word, it may be said that it is "middle of the GOLGOP3-13 and GOP3ZILLA".
    Or more simply, it will be the setting "which raised resolving of GOLGOP3-13 more."
    For the Suites by, I am not sure yet whether the best in this. However, I think that both of GOLGOP3-13 and GOP3ZILLA users are pleased with this.
    I prepared the standard type and the Lite type also in Duke. In the Lite type, the frame size in which the playback in a camera is possible is used in all the modes also including 24p.
    In the standard type, in-camera playback is often impossible in 24p, but a higher image quality is achieved.
    Please tell me your impressions! If this is also still unstable, I will further adjust.
    *The original matrix is adopted in the newest Dukes.
    *24H and 24L are high quality 3GOP setting with mega size I-frames in Duke.
    *24H and 24L are high quality 3GOP setting with super mega size I-frames in Duke_Lite.
    *24p80%(30p) is available in 24H & 24L both.
    *60i, 50i, HBR30p and HBR25p are also high quality and stable 3GOP settings.
    *720/50p and 720/60p are 6GOP. It has tuned up so that the bit rate at the time of motion may go up rather than the scene of statics.
    *In camera playback is available in all rec mode except 24p of Duke, at least available after reboot the camera.(Not tested full yet, but probably)
    *EX Tele, iA mode work.(Not tested full yet, but probably) (Take care only in 720/60p)
    *Spanning in 24H, 24L with SanDisk 95MB/s 64GB SDXC Card. Also in other rec mode, almost available.
    bkmcwd Duke_BETA.zip
    1K
    bkmcwd Duke_Lite_BETA.zip
    1K
  • @ GOLGOP3-13 lovers :-)
    GOLGOP3-13-A2_BETA7 and GOLGOP3-13-MAX2_BETA7
    I release the new "GOLGOP3-13-A2" and "GOLGOP3-13-MAX2" settings.
    All of these matrices are the same as before. The only changed part is in 720/60p.
    *These have passed the continuation zooming test for 6 minutes or more with Panny AF lens.
    *Please try them! And many thanks for feedbacks from you!
    *If these are also still unstable, I will further adjust.
    Special thanks to @har_k, @ojiko, @syoushow, @Mrhechang, @Shon, @spreeni, @kankala, @abraham1307, @jul and @towi!
    And especially thanks to Nick @driftwood. :-)
    NOTE:
    *Although bit rate setups are quite high, the bit rate which actually appears are lower than these. Since the actual bit rate changes by the object to shoot, please confirm by yourself.(Max bitrate : about 120M in 24p, about 75M in HBR, about 70M in 720/50p, about 60M in 720/60p.)
    *'MAX' version and 'A' version are completely the same except 24p.
    *The original matrix is adopted in the newest GOLGOP3-13s. It is the middle of a Sedna matrix and a stock character. If I say plainly, it will be the Sedna matrix optimized in 3GOP structure.
    *24H and 24L are high quality 3GOP setting with mega size I-frames in GOLGOP3-13-A2.
    *24H and 24L are high quality 3GOP setting with super mega size I-frames in GOLGOP3-13-MAX2.
    *720/50p and 720/60p are 6GOP. It has tuned up so that the bit rate at the time of motion may go up rather than the time of statics.
    *In camera playback is available in all rec mode except 24p of GOLGOP3-13-MAX2, at least available after reboot the camera.(Not tested full yet, but probably)
    bkmcwd GOLGOP3-13-A2_BETA7.zip
    1K
    bkmcwd GOLGOP3-13-MAX2_BETA7.zip
    1K
  • UPDATE(2013/06/02)Valkyrie 444 Lite is upgraded to official "Valkyrie 444 Lite 1.01" setting.http://personal-view.com/talks/discussion/comment/128374#Comment_128374
    UPDATE(2013/06/02)Valkyrie 444 TYPE-ZERO3 is upgraded to official "Valkyrie 444 TYPE-ZERO3 1.01" setting.http://personal-view.com/talks/discussion/comment/128374#Comment_128374
    UPDATE(2013/05/30):Valkyrie 444 Lite BETA is upgraded as official "Valkyrie 444 Lite" setting. http://personal-view.com/talks/discussion/comment/123699#Comment_123699
    UPDATE(2013/05/30):Valkyrie 444 TYPE-ZERO3 BETA2 is upgraded as official "Valkyrie 444 TYPE-ZERO3" setting. http://www.personal-view.com/talks/discussion/comment/100441#Comment_100441
  • UPDATE(2013/06/02):I have released GOP3ZILLA4_BETA_Corrected version.
    @ GOP3ZILLA lovers :-)
    GOP3ZILLA4_BETA
    I release the new version of "GOP3ZILLA" setting.
    In this version, the GOP tables are adjusted more appropriately. I think that this is further stable and with higher bitrate from GOP3ZILLA3 in HBR or 720p.
    Please try it! And many thanks for your feedbacks!
    *About 24p, it is completely the same as former versions.
    NOTE:
    *Although bit rate setups are quite high, the bit rate which actually appears are lower than these. Since the actual bit rate changes by the object to shoot, please confirm by yourself.(Max bitrate : about 100M in 24p, about 75M in HBR.)
    *This is the simple setting which harnessed the feature of the stock as it was. I recognize this to be the normal evolution version of the stock.
    *24H and 24L are high quality 3GOP setting with mega size I-frames.
    *720/50p and 720/60p are 6GOP and 9GOP. It has tuned up so that the bit rate at the time of motion may go up rather than the time of statics.
    *I especially recommend you use with SanDisk 95MB/s 64GB SDXC card. However, I have got the report that the card of other classes 10 can also be used satisfactorily.
    *In camera playback is available in all rec mode, at least available after reboot the camera.(Not tested full yet, but probably)
    *Spanning in 24H, 24L with SanDisk 95MB/s 64GB SDXC Card. In other rec mode, need test.
    bkmcwd GOP3ZILLA4_BETA.zip
    895B
    bkmcwd GOP3ZILLA4_BETA_Corrected version.zip
    905B
  • Thank you!
  • @spreeni
    Hi mate! :-)
    Honestly, I have not made the spanning test almost. Therefore, you need to try and check spanning in advance.
    However, about stability, I think that it is enough in SH (PAL) of my newest settings with 95MB/1 SDXC cards.
    I recommend you Valkyrie 444 TZ3 BETA2 or GOLGOP3-13s_BETA6.
    At least, in auto focusing, it is stable rather than other high-bit rate LowGOP settings, IMHO.
  • @bkmcwd I have to do a filming job tommorrow and my client wants me to shoot in 720p50 (PAL). I've never used this format before and I wonder, if you can recommend one of your patches which runs stable in SH (PAL) mode. The job will be a documentary, with much action, long period shots (spanning important!) and under use of autofocus function.
  • @All
    I am working on improvemant of Spizz, GOP3ZILLA, and GOLGOP3-13 now.
    Regarding Spizz, probably, I need the advice from Nick in selection of a matrix. Since the matrix of SpizzT4 and moonT6 is considerably different, I consider now whether what I do with these.
    GOP3ZILLA, I am adjusting the GOP tables. This is for stabilizing it more.
    GOLGOP3-13, I am going to make another version which changed the Y matrix. I will give another name to this new one.
    When tests are required, please give me cooperation. :-)
    Regarding Valkyrie 444, I'm going to upgrade TZ3 BETA2 and Lite BETA to the official versions.
  • @tymeorama
    Many thanks for using Valkyrie! :-)
    Your footage looks very nice.
  • Made in September with Valkyrie 444 TYPE-ZERO (I'm not really sure about the version, but it was with bkmcwd patch). I was there only to help the guy who set up the lights, I picked up my gh2 to do some tests with a Samyang 85, a Pentax 43mm and a CCTV 35mm, and finally, I ended up making a small video for the group. Thank you @bkmcwd for the great job, and thanks to @driftwood, @cbrandin, and @Vitaliy_Kiselev.
  • @bkmcwd thanks! :D
  • @brucker
    Many thanks for trying Valkyries and feedbacks! And thanks for very interesting footage. :-)
    また感想をお聞かせください<(_ _)>
  • @Azo
    Since I myself do not do green screen work, I am not detailed. Although there are many detailed people...
  • @botha
    thanks man, glad you liked it! (pardon the first bit i think i got the unsqueeze wrong.... getting used to the quirks of this lens is taking a while :P )
    i looove Boom but recently i've needed playback ( filming poets and writers) and while Valkyrie Lite is nice i think TZ3 Beta2 is absolutely brilliant for the balance between great looking+stable+playback+not as SDcard hungry.
    i think it's going to stay on my GH2 for a while,.. or atleast until bkmcwd comes out with the next version :P
    NB: used a sandisk 64gb/95mb superduperwhateveritscalled :P
  • @brucker
    Wonderful cinematic footage! Thanks for this.
    'Valkyrie 444 TYPE-ZERO3 BETA2' and 'Valkyrie 444 TYPE-ZERO2 Candidate1.5d' is one of the best settings ever.
  • @bkmcwd thank you very much for TZ Beta2 i think it is gorgeous! And it worked very well for me,... only used 24p because it's just loverly!
    Here's a lens test i did earlier this week,... anamorphic lens, 24p, Standard 0,0,0,0, straight out of the camera, basic cutting in Resolve Lite and then rendered straight out,.... no leveling/adjustments/tweaks/FX of any kind. I did play around a bit afterwards and it grades very nice and smoothly :) :
    お疲れ様でしたbkmcwdさん!
  • @bkmcwd @everyone
    I wanted to know if the Valkyrie 444 TYPE-ZERO3_BETA2 would be good for green screen work. If it is not could you be please recommend a patch that is good with green screen.
    Thank you....
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
