@5thwall Maybe a tad in grading but if it's all talking heads stuff, there's usually no need for heavy grading. I've actually felt I can push the grading harder in IV2 than Moon5 sometimes but not always. IV2 just isn't great for wide stuff and I'm in no mood to change hacks for different shots so whatda gonna do! :)
@5thWall Recently I've only been using Moon 5 (balanced or emphasis on wides), IV2 (maximum detail for moderate detail subjects) and occasionally Flowmotion 2.02 (for when I need especially predictable performance).
Moon 5 is really great about giving low bitrates on low-detail subjects. Sometimes the bitrate dropped close to what SMBU V1 would give on average but the results were far better. It really does seem to be efficient in the scaling.
@thepalalias These are my favs too based on the same experience. And a Slipstream 1b on a GF2(the only thing missing there is a playback of 720 50p is not possible in cam)
@ 5thwall like you (and everybody else i guess) I've been trying to find that perfect balance. Bitrate, stability, quality, practicality. Since the release of Cluster X it's been a ping pong match for me between DREWnet V8 and Moon T5. (NOTE: I'm using the SanDisk 95Mb/s 64MB cards exclusively) Both have given me almost "firmware" stability - spanning, in camera playback, etc. An occasional stopped recording for longer takes (15 minutes with Moon T5 on 720p 60fps High NTSC) but no camera lock up where you have to pull the battery for either patch.
My humble opinion from personal testing: DREWnet V8 is exceptional all the way around. One of the main advantages over Moon T5 is file size. eg: If an identical movie recording file size is 3.1GB with DREWnet, then the same shot is going to be say...around 5GB with Moon. No big deal until you get a couple hours of takes strung together and find your B-roll is 25GBs with Moon whereas DREWnet would be around say... 13 to 15GBs.
In the end it's about quality to what my eyes see. Moon has me. When I reload Moon after shooting with DREWnet for a while, I'm blown away at the albeit subtle but fantastic quality of Moon T5. Beautiful, clean, edit and grades wonderfully in post with Premiere Pro. My solution to Moon's file size - I've upgraded my computers hard drives for a total of 6.5TB's of working space.
Hope this helps and happy shooting.
PS: Driftwood recently announced Moon T6 is coming. Can't wait to see how it performs!
I would like to report some issues I had yesterday on a wedding with "Moon" trial5. Recording at 50i with the SH settings to keep the bitrate low, GH2 froze 5-6 times and needed to remove battery. Camera on a flycam with the pancake 14mm & Sony wide converter mostly at f/8 with continues focus on. My SD cards sandisk 32GB Extreme HD Video 30MB/s, formatted first on a PC and then in the GH2. My question is, what I have to do so next time won't have the same problem. I need the best settings for motion on 25p or 50i (PAL BluRay). Do I have to buy the sandisk 64GB 95MB/s (not possible right now) or do I have to choose another settings for my SD cards.
@sakattaq76 The most stable setting I've found with Cluster X series is Slipstream 1b. Worked FLAWLESSLY with the sandisk 32GB Extreme HD Video 30MB/s cards I have. Absolutely wonderful patch. At the highest recording setting of 24p High you get right at 3x the bitrate (72Mb/s) verses the highest stock firmware setting of 24Mb/s if I remember correctly.
***Unfortunately with Moon T5 or DREWnet V8 for that matter, I MUST use the 95Mb/s 64GB Card. Sorry I personally don't have better news on that one. The card is pricey.
Thanks @maddog15. I have used Slipstream 1b before and it is very good indeed. I will also next time use a longer GOP settings, just to be sure! Damn it, those sandisks cards must get down, too expensive in my country!
I'd recommend you do what you need to do to purchase that SanDisk card. It's the goto card for ALL patches, I think.
Moon T5
Thanks @Jim_Simon!
@maddog15 Great work on the tv spot!
@kidgray Very nice! Just a focus was a bit off in some of the shots. What lenses did you use?
@benzopilas. Thanx for that! We used a panny 20mm 1.7, Yashica 50mm 2.0, Canon 80mm. Shure some of the shots were little bit out of focus but mostly im loooking for expression in the pictures rather then perfection. Thats the reason. =)
Here's a problem I've been having recently on Moon T5 (overall I'm very happy with it):
On image areas that are basically uniform color and low detail, but somewhat varying in brightness (like a wall, or a white cyc backdrop) I will get really funky pixellation/blocking artifacts. Typically I can fix this in grading, but not always.
Is there a better hack to use in these type of settings? Maybe intravenus v2, or Drewnet?
I tried to use Moon T5 for first time in ETC mode and I'm just shocked: in low light situation the image is simply terrible - ugly wide horizontal lines, banding and much noise! And I'm talking about ISO160, f1.0!!!!!
Any idea how to avoid this???
