Cluster X: Series 1 - moon - ЅріzZ - nebula - drewnet - Slipstream
  • 1008 Replies sorted by
  • @puttydivision GH2 has 720 50p for PAL land and 720 60p for ntsc land.You can choose between them in menu /setup/page 3/video out/pal or ntsc.Restart and format.
  • Very clean image in low light f3.5 s50 iso 3200.Still do not understand how mts file are so small and are so clean. Noise is uniformly distributed . Testing will continue tomorrow during the day. I'm curious how it behaves 720/50p in slow motion. Seems very little under 40m.
    1359 x 767 - 1M
    1359 x 767 - 966K
    1359 x 767 - 1M
    1359 x 767 - 938K
    1359 x 767 - 802K
    1359 x 767 - 508K
  • Hi Nick and others on the forum. Havent posted here for ages as I have been really busy...but I have been following this (and other threads)
    Anyway I have to say that Moon Trial 3 is THE BEST 30 frames setting I have seen yet, its so close to 24P...WOW!!
    I am in PAL land but as I mainly want vids for youtube...I switched to NTSC cause the HBR in 30P is a little smoother for motion than the 25P setting and I can set the shutter to stop any lights flickering while in PAL land and in NTSC camera mode...so its a win win situation for me.
    Anyway the 24P setting always has been noticeably better than any HBR setting (NTSC or PAL)so far...but as I just said the 24P and HBR 30frame is very very close...the 30 frame stuff no longer looks a bit dinky...just nice and clean with character and smooth.....EXCELLENT WORK NICK!!!
  • I apologize if this is obvious, I'm new to all of this. Does DREWNet have a 60P setting for 720? Thanks.
  • Overall, I love moon. However, for a long GOP offering 8-10 QP - its ridiculous! I love the DREWnet setting. If you guys only realised how long it took to measure all the new Cluster settings... if only you knew the pain... I go to sleep now.
  • @driftwood do you really think it gives better results than moon?
    I shot a clip last night of a white wall with the TV reflecting off of it and saw some CRAZY stuff going on. I usually do this test for some reason, flowmotion is bad, and some others are bad, but the mega quant did some of the craziest stuff I've seen. circular banding type stuff
  • @GravitateMediaGroup onionbrain is referring to DREWnet. It does indeed give stunning results.
  • It should be - Cluster X Drewnet provides ridiculous quantisation - Q8 to Q12 averages for most pictures. It matches the GH3 and beyond - utilising 4x4 transform for the whole picture (not just the edges as in the GH3) and not 8x8.
  • @onionbrain Could you go into the conditions a little further?
  • Under certain conditions the new long-gop "DREWnet" is the best looking thing I've ever seen on a GH2. Period. Under certain conditions -- I was getting ISO 1600 that absolutely matched a 5D Mark 3 at ISO 1600.
    I'm continuing to work with it and will have a more substantive response in a few days. But -- my initial reaction to Cluster X DREWnet is -- it's almost like a different camera.
  • Just playing around. I was actually just testing the SLR 35mm 1.4 lens but I love the way Moon handles grading. This isn't too drastic but of course it's a little over saturated on purpose.
    1107 x 628 - 942K
    1108 x 633 - 1007K
  • Just shot some really boring stuff of a bridge and water with Moon and damn, does it hold up to grading. I was trying to break it down but it held up to me pulling it all over the place. Very nice @Driftwood, very nice indeed.
  • @driftwood moon is amazing, I do wanna thank you again and again. I just dropped 24H150 -147, 24L80 - 77, FSH93 - 91, FH48- 46 to be on the safe side, I hope I didn't upset anything. gonna reload moon and check again.
  • *** NEWS *** Nebula 6 GOP Trial 5 Released.
  • @cjdincer careful dropping bitrate numbers as you could upset the delicate balance. Apart from that 'moon' looking very good on your lenses.
  • @Tifose then why it shows visible noise???
  • @rajamalik the ISO was at 160
  • @driftwood i will try that too "Cluster Xs" ?
  • @Tifose ya it grades well. what about the noise?? i guess its above ISO 500?? what was the ISO for this shot??
  • Hi to all, I am waiting for a final release of of the hacks and I am curious: Did anyone try higher audio bitrates, especially with "Moon"? I did use 384kBs before and never had a with any hack. (64gb Sandisk Extreme Pro)
  • I dropped the bitrate numbers just a bit because I fear my 45mbs 32Gb sandisk card giving me read and write errors. So far, I haven't tested the %80 and other speed modes, but it seems cam is working just fine even with panny lenses. süperb quality setting, producing post friendly images, best HBR to date, smooth motion handling, great detail retaining; The clips are converted to Proress 422 HQ with 5dtoRGB and graided in FCPX and the final export converted in compressor to AVCHD youtube sharing codec for uploading. Thanks to @driftwood again. it was fun to shoot those parrots with moon in ex tele. Longer lens is needed. and 45-200mm's AF hunts in couple places where I forgot to use the lock key. here are my 2 minute full hd test samples.
  • I've got a video shoot in Hawaii starting tomorrow, and I'll be shooting with "Moon" trial 3 all the way. Can't wait to report back, but initial testing of this setting has shown it to be superb. Cheers!
  • it's just "my opinion" moon trail 3>mega quantisation
  • which one is the best setting for using fd manual lenses?
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
