Cluster X: Series 1 - moon - ЅріzZ - nebula - drewnet - Slipstream
  • 1008 Replies sorted by
  • @Zaven13 Yeah, can you give it a trial run? I'm still pondering...
  • @driftwood, Did CLX Nebula trial 4 have any NTSC adjustments? looks like GOP tables were changed.
  • @Mirrorkisser @abraham1307 @cjdincer
    I am starting the test for improving 'Spizz' requested from Nick. I think that this takes time for a while. Many thanks for your feedbacks about Spizz. :-)
  • We're now at the climax of all settings to date.
    Folks this is it!
    Cluster X Series = the ultimate series - simply awesome!
  • @bkmcwd here is a HBR sample from Cluster X 6 GOP Nebula: Best HBR footage from my cam so far.(just converted with compressor for youtube) Other modes are also ok. tonight I've loaded 'Spizz' and give it a try couple of days. excellent setting 6 GOP nebula is. I hope 3GOP is better.and very curious about ClusterX intra VK. Also have to mention intravenus V1 is my personal best. Thank you Driftwood.
    all -2 smooth iso160
  • @driftwood, Thanks for releasing Spizz
  • @RKM Bart, that looks very promising - and with EX Tele! :-) Excellent shot.
  • Here is my promised birdvideo with Cluster X Nebula trial 2 Nikon 400mm f3.5@Ex tele 1080p30 playback at 25fps, ND4, 1/100, f3.5
    Got only one hangup with a lot of clips. Very very very nice setting. Excellent work Driftwood.
    Bart
  • @driftwood: Spizz sounds super interesting! Trying it right away. For which scenarios did you invent the new matrix? Cheers and thanks for your efforts!
  • Cluster X Series updated above.
  • Wrong thread
  • NEWS: Still a lot of testing going on with all new Cluster Xs :-)
  • Wrong thread
  • I just shot some stuff with Cluster X Series: 6 GOP - 'Nebula' and it's looking really good. Today is very sunny and contrasty, but all looks great so far! Can't wait to try it out some more over the weekend.
  • OK, I didn't knew you were using some objective measure to access IQ, that's a good systematic approach, even though PSNR/MSE is a very poor (although simple and very fast to compute) when compared to SSIM: https://ece.uwaterloo.ca/~z70wang/publications/SPM09.pdf
    I was about to ask you how on Earth was StreamEye reporting PSNR values without a reference (uncompressed video) but after some research (and finally reading the manual) it seems that it's able to compute a very good estimation (thus the name E-PSNR) from the encoded stream (macroblocks, headers and quantisers). Well... it's better than nothing, and still very useful for settings development. :)
    Time to do some patching...
  • @duartix I can get fairly low Q with an appalling matrix on certain pictures. It has to be a decent matrix for overall use so a death chart and my own 'busy' park scene of death (a scene which includes lots of trees and bushes and a moire prone grille in a wall) is being used to judge the results. Basically the goal is to get average PSNR to near (or just over) to 50db YUV in Elecard for a fairly busy hi/low contrast image. |:-)
    I'm hoping you guys will give me the subjective quality test results!
    Its going to take some time so be patient all.
  • Ok, I'll wait, thanks again! Meanwhile I'll test your advance.
    Q16? Isn't it overkill? I've read reports saying that SSIM values of 0.985 are near transparent and my x264 exports regurlarly exceed that at Q20. I'm probably comparing apples and oranges because any similarities between the GH2 and x264 regarding h.264 profiles, might be a pure coincidence. I even seriously doubt that the GH2 codec is tuned for SSIM, probably it's just PSNR. No CABAC either, no dynamic DCT partitions, different scaling matrices, etc...
    Taking these considerations I understand perfectly that your priorities are on absolute IQ, while mine are more focused on efficiency and "just" maintaining visual transparency, but since you have a lot of "Pro" settings, I'm grasping at some "diversity" here, in the lines of a Sanity sidekick. :)
    Great work!
  • @duartix Soon... its the mystique! But just for you, its all about trying to achieve the best balanced settings for Q16 throughout the differing GOPs.
  • Cheers Nick @driftwwod.
    First of all I'd like to thank you for working on long GOPs too.
    The trials links might be more pinpoint like this: http://www.personal-view.com/talks/discussion/comment/105936#Comment_105936 and http://www.personal-view.com/talks/discussion/comment/106345#Comment_106345
    For efficiency reasons I've very much interested in these settings. Which matrices are you using in them?
    If you don't mind, it would be nice if you set a purpose/mission statement/small description in the first thread. :)
  • @Driftwood
    I'm on Cluster X Nebula 6 GOP now. Not a very representative test. I use ExTele on a Nikon 400mm f3.5 wide open for filming ducks in the snow. I shoot 30p and slow down in post to 25p for more relaxed looking ducks. I also use a ND4x drop in filter, but that doesn't help much. I'm forced to close down the aperture at times or slightly increase the shutter above 1/60th. I'll try to post some results as soon as possible. Thanks for all your hard work.
  • I've been stuck to Cluster V6 DrewNet as it seems to be the only one which spans forever. 6 GOP Nebula ran for 10min before stopping. Are any of the other X versions likely to span reliably?
  • Cluster X 6 GOP 'Nebula' - looks like intra .I tested only noise in low light (24h).
  • Looking forward to this series.
  • 1 GOP Intra - moon - Top Grading - Best Motion
    Update News (updated 18/02/2013): Released after 720p/HBR/FSH renumerations - Great quality and QP all round in the moon tradition ;-) - 'moon' (trial 5) 1080p24 stays with the sharper 'Blue moon' matrix and the QP of Trial 3 - nice all round mix.
    Cluster X Series: 'Moon' includes 1 GOP Intra 24p & HBR25/ 3 GOP 720p50/60 and HBR30p/FSH modes Trial 5 (Released 18/02/2013)
    Including;-
    • 1080p24 All Intra - Low 14-16 QP avg picture quantisation - hi-bitrate 100+ to 151Mbps superior quality
    • 1080i50/HBR 25p All Intra - 14-16 avg QP - 60Mbps Med detail scenes bitrate excellent quality to 90Mbps hi bitrate/hi detail great quality
    • 1080i60/HBR30p 3 GOP with P frames avg 14-16 QP 50Mbps Lo bitrate great quality to 72Mbps Hi bitrate hi detail
    • 720p50/60p 3 GOPwith P Frames - avg 14-16 QP - 50+Mbps to 72Mbps stabilised hi bitrate / detail / quality
    80% Mode recordings should be operated on the high bitrate 'L' setting primed for this mode.
    This setting is primed for 1080p24 'in tight', medium, and busy detail scenes offering even sharper quantisation performance and is in the middle of trial 3 and trial 4 to please everybody (inc. me).
    moon
    Driftwood 'VK' Trial 1 - setd.zip
    2K
    Driftwood 'VK' Trial 2 - setd.zip
    2K
    Driftwood 'Moon' Trial 3 - setd.zip
    2K
    Driftwood Cluster X Series 'moon' Trial 4 featuring 'Blue Moon' Matrix - setd.zip
    2K
    Driftwood Cluster X Series 'moon' Trial 5 'Blue Moon' Matrix QP16 - plus reliable 720p-HBR-FSH - setd.zip
    2K
  • 3 GOP - Hi-Quality - Pro Motion 'Spizz'
    Update News (03/03/2013): Spizz Trial 5 released based on some of the ideas from Nebula and DREWnet. Its a safe QP15 and seems to work on all modes including iA (Intelligent Auto) @bkmcwd and @towi will be testing these findings and improving them even further. More possible updates on Spizz with bkmcwd's and towi's findings soon.
    HISTORY
    Cluster X Series: 3 GOP 'Spizz' from Driftwood, bkmcwd and with the help of @towi Trial 5 (Released 03/03/2013)
    Updated Matrix and NO frame limit to cater for the hi-bitrate superior looking files. 1080p24 now records at a minimum of around 90Mbps on low detail stuff and 137Mbps at high detail. 720 SH/1080iFSH now work on iA modes, HBR modes should be very high quality.
    Many thanks to @bkmcwd and @towi for improving these settings.
    Cluster X Series: 3 GOP 'Spizz' from bkmcwd Trial 4 (Released 12/02/2013)
    An update and 'tune-up' to Trial 3 with stability in 720p modes. Matrix and frame limit amendments to cater for the hi-bitrate superior looking files.
    Cluster X Series: 3 GOP 'Spizz' Trial 3 (Released 06/02/2013)
    An update to Trial 2 with stability in 720p60 by utilising a 6 GOP. Also the 24p L setting is now fashioned to 72Mbps i/b frames for fast action and more ameniable quality than the previous 50Mbps L setting.
    Note: 3 GOP 720p60 is still being worked on by bkmcwd amd 'may' appear in Trial 4. However, the 6 GOP as usual is the best there is.
    Cluster X Series: 3 GOP 'Spizz' Trial 2 (Released 03/02/2013)
    An update to Trial 1 with stability in HBR/FSH/720p modes and better overall constant picture QP.
    Cluster X Series: 3 GOP 'Spizz' Trial 1
    • All round 3 GOP from 720p, FSH 1080i, HBR, and top rate 24p all using the new balanced Cluster X series matrix.
    • Very Hi-quality reliable setting including upto 117Mbps 24p.
    • Unique 3 GOP 720p implementation with great QP upto 76Mbps Hi Scene detail / 40Mbps avg Lo scene detail.
    • Hi quality HBR Progressive 25p/30p and FSH 1080i interlaced modes. Upto 80+Mbps Hi-detail scenes.
    • No Frame limit on any of the 3 GOP settings and ALL utilising B frames.
    Further tests & releases of these settings will be conducted by @bkmcwd and @towi.
    Spizz in action:- 3 Pictures of 24p, HBR25p & 720p50 (Spizz handles 720p50 at 3 GOP - Flowmo uses 6 GOP) modes demonstrated against another popular 3 GOP setting. You be the judge.
    24p
    24p
    HBR25p HBR
    720p50 720p50
    Cluster X Series - 'Spizz' 3 GOP - Trial 1 - setc.zip
    1K
    Cluster X Series - 'Spizz' 3 GOP - Trial 2 - setc.zip
    2K
    Cluster X Series - 'Spizz' - 3 GOP - Trial 3 - setc.zip
    1K
    bkmcwd - Cluster X 'Spizz' Trial 4 - sete.ini.zip
    2K
    Driftwood Cluster X Series - SPIZZ - Trial 5 from Driftwood and bkmwcd - setc.zip
    2K
Start New Topic
Howdy, Stranger!
Sign In Register as New User
Tags in Topic
Top Posters
