GH2 Cineform Question
  • 76 Replies sorted by
  • @notrons I have read and reread what you wrote, and it seems like what you are saying the post prep utility does makes a lot of sense as far as work flow.
    Check me if I am right here. To put it simply you will take your original footage and convert it into two types of footage with the exact same name and file type.
    1. will be a medium quality footage with 422 color space so that your color corrections look accurate. 2. will be a uncompressed (maximum quality) up sampled 422 color space footage with the same exact name as the footage from number one.
    When you get done editing your project, you will simply overwrite the lower quality footage from number one with the very high quality footage from number two. At that point, your editor will simply apply the same edits to the super high quality footage which will in turn slow your editor down. But this is unimportant because the only time you use this very high quality footage is when you are exporting?
    The next question would be ... is the post prep utility able to process the files as well or better than neoscene or the other cineform versions? Because if I am correct, you could accomplish a very similar thing to what you are doing with those programs. You would just have to process the files twice instead of automatically having the program do both files for you.
    On a side note. I have expertise regarding RAID. In both of your posts you mention RAID, but you mention two different array types. Personally for critical data storage, I prefer RAID 6 because it allows any two hard drives to go down at the same time. This actually occurs more frequently than you would think because hard drives that come from the same batches tend to fail at the same time. RAID 6 also integrates striping but with parity. THis gives you good speed with great backup capabilities. Of course it does require a 5 or 6 or more disc array, and many RAID controllers don't support it. But it is awesome.
  • Ppl have argued that you should work on files natively, that with some software being able to read and process color at 32bits, you shouldn't bother with transcodes.
    Well, yes and no. iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
    Yeah I go 'round and 'round on this one. Perhaps if you're not pushing the color or vfx too hard, you can stay native, but if you're going to be aggressive, maybe one should transcode. I've yet to find anything definitive on it.
  • @notrons
    A codec basically transcodes the raw material it gets applied to. Technically, it doesn't alter the original file, but "rewraps" the file using its own algorithms, including changing its structure et al. So codecs like ProRes turn 4:2:0 files into 4:2:2, which i have discovered is more stable for editing. Ppl have argued that you should work on files natively, that with some software being able to read and process color at 32bits, you shouldn't bother with transcodes.
    Well, yes and no.
    Thus far, I have directed and shot 10 commercials, as well as a dramatic short film on GH2 and Prime Lenses plus full production values, and I find myself coming back to the point that h.264 is an acquisition and not an editing format. Try doing things like varying the speed of a clip in post natively, and you'll see what I mean. A transcoded file at ProRes 444, or even just 422 on the other hand holds up very very well.
    Even for color grading, there is a difference when I work on transcoded material. I dun have the math to back up my claim, maybe someone else here can, but transcoded material is a lot more stable.
  • Why should I purchase it? It works perfectly in the free version from GoPro. A seamless workflow. I submit that Gopro CF is a viable solution for GH2 users.
  • The free version of Cineform GoPro, when used within Adobe Media Encoder, Premiere Pro, or After Effects, has the low, medium, high, Film Scan 1, Film Scan 2 settings available. I don't see any uncompressed settings however.
  • Brian, i'm not going thru the process again of reinstalling the free Gopro Cineform Studio as it cannot co-exist on the same machine that Neoscene is installed on without uninstalling Neoscene first.
    I suggest you purchase the program designed to process mts files like i have and you will find there are 6 quality settings (low, medium, high, filmscan1, Filmscan2 and uncompressed) The free version of GoPro Cineform Studio i originally installed did not have all these choices.
    The "non destructive" element of Cineform is an integrated procedure called FirstLight that only comes with Cineform Studio Premium and above.
  • @Rambo If you have some information that the the Gopro CF codec is different than the one in Neo -- that the bitrate is lower, please give us a citation, otherwise, as I said, you're spreading misinformation about a key element in the workflow of many people.
  • @brianluce you obviously don't own Cineform Neoscene or you would know the difference.
    David Newman (not Neuman as you called him) has said GoPro Cineform Studio Premium has replaced NeoHD and GoPro Cineform Studio Professional has replaced Neo4k and Neo3D. Neoscene is still a separate product to Studio.
  • "Automatically convert to uncompressed 4:2:2 or a pro HQ codec like Avid or ProRes for final render"
    I got to know Cineform as standing in one row with Avid Dnxhd and Prores, just performing much better. Actually all 3 codecs are "visually" lossless. The whole metadata/non destructive grading thing came later in. I had it at work, and if the large versions that support 4:4:4 + alpha where not that expensive I would buy it for myself. Gonna test the GoPro Version of it if I find the time.
  • @B3Guy - understood, and not having used Cineform myself I don't know the facts. But I did investigate it when I was considering my workflow and decided against it. If it works as you describe (and I believe you are correct) then it is indeed a very proprietary format dependent on licensing (as per @kazuo). I just couldn't wrap my head around Cineform first converting to a 4:2:2 color space during editing and not changing the original - although I do understand the concept. I just felt that it was...risky.
    As far as maintaining the original footage, from a storage perspective that should be your only real concern. Import from flash card to storage disk (RAID5 array with backup) and rename with prefix and timestamp. If you work with 4:2:2 converted files from this point forward you will never have to touch your originals again. You will always be able to regenerate any subsequent file format if you maintain the original.
    Automatically convert to uncompressed 4:2:2 or a pro HQ codec like Avid or ProRes for final render - this will give you the best possible output for color grading, effects and chroma key, etc.
    If you are color grading you will probably want to convert your original 8bit 4:2:0 .mts files to 4:2:2 for the extra latitude. If you choose a good quality proxy format your editing sessions will move right along, and you will have the benefit of 4:2:2 color space for your corrections. When your edits are finished you can link in the uncompressed footage (or other HQ codec) for the final render. The Post Prep Utility will automatically do both conversions and will create HQ and proxy files of identical names making it much easier to link them in at render time.
    At the super-high gh2 bitrates, footage gets a bit hard to navigate - with transitions, effects and color grading it is like molasses on the timeline. If doing more than a simple edit it may pay to also convert the originals to a proxy format to make that timeline easier to manage plus you get the extra color space. Once your project is complete you can delete ALL of the intermediate files - you can always easily regenerate them if you need them! It is also best to keep your work footage on a RAID0 array of 3 or more drives. The faster the I/O the better.
    It may seem like a lot of handling but I have tools that automate the bulk of the grunt work - and the results are always high-quality and worth the extra effort!
    I am sure that Cineform is an excellent product and can bring a lot of convenience to workflow, but as fast as the GH2 scene is changing I wouldn't want to cling to any overly-proprietary format ; )
  • @Rambo Bit rate is same as Neo as far as I can tell. I believe you are mistaken and are spreading wrong information. It's the same codec, everything I've read from David Neuman's posts indicates that. Neuman says Gopro studio is replacing Neoscene.
  • The beauty of using Cineform (as I understand it) . . . comes from it keeping metadata concerning all of your modifications to the footage. No permanent changes are made until you render/export out to another filetype. The original footage always remains while you color, etc, so whatever you do, it is non-destructive.
    Also, it is quite handy for dealing with 3D footage.
  • @tderuiter - if you would like to experiment with different high-quality codecs you should check out http://hdcinematics.com/NewWeb/tools.html and grab a copy of the DSLR Post Prep Utility. It will do automatic conversions of your .mts files to ProRes and Avid DNxHD in both HQ and proxy formats as well as uncompressed 10bit 4:2:2 for final rendering (and can now wrap .mts files for Lightworks).
    Generally speaking, with the Post Prep Util you can render both HQ and proxy formats automatically, and with exactly the same names (but in separate directories). You edit the proxy footage (which has the benefit of 4:2:2 color space giving you as much latitude as possible during editing - and the footage holds up better to corrections) and when finished either link to the uncompressed footage for rendering - or replace the footage to achieve the same effect. This is exactly what intermediate formats like Cineform are all about. I think you will find that either ProRes or DNxHD codecs will serve you very well - and all for free ; )
  • I lower the contrast in Cineform Studio in order to make the footage easier to color grade. Is that the best way to do it in Cineform? Also I noticed that when you do this noise becomes more apparent. Is there a free program that can remove gamma noise as well or close to other paid programs?
  • GoPro Cineform Studio Bitrate quality is capped a low rate, this way it protects Neoscene product.
  • @Rambo Why not? It seems to work really well and seems to be the same codec.
  • The GoPro version is a very restricted version of the conform codec, not the same as the paid for NeoScene. I've used NeoScene since it was first released, never had lockup issues, works awesome for pushing grading and editing on a lower spec PC.
    I would not use the GoPro version for converting GH footage.
  • It also works with Vegas Pro.
  • I've been trying to do it with hbr25 and 24p footage, through media encoder to gopro-cineform but, it fails every time it starts. anyone knows how to set the codec for hbr, for interlaced footage? progressive or upper first?
  • Wow, thats great news! Guess its limited to 1080p 422?
  • @Jspatz
    If you have the free GoPro and Adobe's AME/PP/AE you can import MTS files and export to Cineform AVI/MOV files. :-)
  • The free version does not import MTS
  • nah, it's free now. Go to the GoPro site. Gopro bought them out. That's how I got my CF and Vegas sees it.
  • Cineform is not a free codec. I have used it for a couple of years now, and while I must say it is a very good codec, even when compared to ProRes or Avid's DxnD, it is quite a troublesome tool to use because of its proprietary license. If you ever reset your computer, it will lock up and you have to write to Cineform to ask for a new key to unlock the software. This protects the software from piracy, but it's a damn hassle for endusers.
    Try 5DtoRGB. Awesome software that leverages codecs like ProRes and Avid. And it's free!
  • I don't think it'll do anything for DR, but the CF codec might nonetheless hold up a little better to grading, at least as compared to unhacked files. it's free too, it's a very good editing codec -- you can edit CF on a Pentium II if need be.
