Panasonic upcoming fast zooms topic
    There will be a 12-35mm and a 35-100mm fast X zooms!!!! Panasonic said they will come in 2012 and have a “large” aperture.
    Via: http://www.43rumors.com/
  • 77 Replies sorted by
  • @ttancredi
    Nope. At CP+ in Japan they again showed same mockups.
  • any slight idea of when it will be finally released?
  • @el3nd1l
    Funny thing is that almost any lenses with electronic focusing can be made parfocal. But they'll keep breathing.
  • Any chance it`s gonna be parfocal?
  • A zoom lens's light transmission is generally in the 70-90% range. The f-number is by far the largest factor determining the brightness of a lens's image.
    http://forums.dpreview.com/forums/read.asp?forum=1030&message=33785655
  • In layman's term, 2.8 lens gives same exposure reading regardless of crop factor... in theory. So they are as fast as Canon's 2.8 zooms. But they look kinda small. I was expecting at least 62mm filter thread. More lens distortion correction will require much edge sharpening. Let's wait and see.
  • The aperture itself isn’t the only factor that determines the amount of light that gets through to the sensor. The design, the glass quality, and the lens coating will each play a significant role, too.
    All in all, ƒ2.8 all the way through is miles ahead of ƒ4–5.8 on the 14–140mm lens (which only stays at ƒ4 in the 14–18mm range, anyway).
  • It doesn't need to be anywhere near 77mm. The 17-69mm f/1.9 Meteor lens has a 77mm thread (16mm lens).
    f/2.8 isn't fast for smaller formats, where the lens is a lot closer to the image plane, and much smaller circle of coverage than 35mm.
    Focus by wire would be a deal breaker imho.
    Manual zoom and focus capability, and then I'd be keen.
  • Amazing, i will need to save for these new lenses ...
  • These are supposed to have manual zoom rings.
  • Does this have a built in servo zoom or not?
    I think I will stick to fully manual primes if not. Just like a zoom run and gun lens and a servo zoom when need be. (which isn't often).
  • Seriously 2.8 all the way through is not slow. You mad nutters.
    Panny OIS is good, both for stills and video, but you do know when to have it in mode 1 or 2.
  • I'm very happy with the OIS of the 14-140. If I need slow pans, I always turn it off. But for hand held stuff on the long end it is almost a tripod!
  • For me the OIS function looks like it was designed for stills and not for video. When you start panning slowly it will first try to keep position and then suddenly realize that this move was intended and follow in a sudden manner. Not nice. But in fact you can still run a software stabilisation afterwards, so OIS takes care that you don´t induce motion blur by unintentional shaking and software makes sure your pans are smooth as butter. Will try to upload an example.
    I also had the feeling that the OIS works better in the 14-140 than on the 14-42.
  • @RRRR I experience the same issues with Panasonic OIS.
  • Meh, I can work around the 2.8, but with a fixed barrel, I'll be tempted.
  • I'm not too happy with the OIS from panasonic lenses so far.. When it gets a bit bumpy it has this wierd effect, almost like strobing movement, which I don't like. It doesn't work at all when walking around. IMO.
  • I guess the OIS is nice. 2.8 is horribly slow but could be useful with new sensors in the future.
    And the size of the lenses will be good for remaining compact. I could see using bothn in daylight shooting often.
  • It should be thrown in with the body in future! The 14-140mm is overrated and is only useful for daylight.
  • They have mega OIS so thats nice :-) Will get these lenses for sure!
  • I'm guessing these lenses won't have lever controls for zoom and focus? It's kind of a shame.
    I was hoping for a lens like the 14-42X with a constant f-number.
  • If I'd consider buying a zoom, then 2.8 would propably not be fast enough IMO. For concerts and events, it would force me to crank up ISO too high..
    So 2.8 is slightly underwhelming.
    It's certainly more interesting than the 14-45 X lens though.
  • I don't get why it's only 2.8... personally.
    Not with Olympus' two super zooms havin' been out for a while. 14-35/2 and 35-100/2 ...perhaps just for the size to quality ratio?
  • I'm excited about the 12-35X f2.8. It's just the kind of lens I'd be looking for, for most of my general purpose stuff. Can't wait to see this hit the market.
