                  Just got my Lanparte rig.. Superb build quality and fast shipping. Recommended.
Same here, it went all good. Parts have the great quality that i was looking forward to. Thanks Vitaly.
Lanparte rocks!
Any test footage of the Lanparte in action?
I just received notification that my Lanparte rig has been shipped. Looking forward to putting it through its paces!
One small thing that is bugging me with the Lanparte (because the overall quality is so good) is the thumb-screw to secure the base plate - if it was round instead of a standard thumb-screw it would be a LOT easier to set the base plate any way you want it (without it getting in the way of the camera body).
Please use Lanparte topics to discuss this stuff. This is deals topic.
Plus it is really hard to understant that you don't like.
@Vitaliy_Kiselev roger that.. although I can't find such a topic. You suggest I make a new one? I was talking about the thumb screw that secures the base-plate. The thumb screw / camera (with dslr form factor) gets in the way of each other. If it was round instead of like a lever, there would be no problem. If you look at the Tilta rig, the base plate is secured with a round thumb screw.
Edit: attached an image to show what I'm talking about.
                  @ RRRR
i had the same problem. if you use it as a shoulder rig you might have look for some way of raising the camera to your final eyeposition anyway. for now i did it with a block between the camera and the base plate. Now the camera if lifted away from the screw, up to a better eyeposition.
@meniK I'll propably have a round screw made.. But like you say, an additional riser may help.
@RRR are you sure that the thumb piece does not pull out and reposition? There are many of these that do.
Yes, it does. And I like it as it is, since you can tighten it better when your hands are cold (as they are in Germany right now…).
I'm not sure.. will check it out. I might get a round screw made anyway - the base plate is so well made and tight it does not need heavy securing to sit there.. Personally, I'd find pulling and repositioning more troublesome in the cold when you have gloves on. EDIT: Well, nevermind - it all depends on how things are implemented anyway.. :) I'll check tomorrow.
My Lanparte rig arrived today and after a few hours of configuring it and playing around I'm extremely happy with it overall. It's all pretty solid and very well built. Not too heavy but heavy enough that it'll make a huge difference in the stability of hand-held shots compared to my old crappy Cowboy Studio rig.
The rig is very adaptable with all kinds of adjustment points as well as screw holes for additional accessories. I look forward to getting out with it soon and shooting with it and am already saving for the next accessory to join the family.
Thanks VK for an awesome deal.
