All discussion that moved from nex-hack.info site.
Useful info:
ILCE-6000 Level 2 & 3 Service Manual Level 2 and 3 document is available on elecktrotanya.com
Modifications are no longer possible with current Sony cameras. Sony now uses encryption and signing of files. The operating system used has also changed a lot since then. All in all, we can look forward to what was/is possible with the old cameras. If the Sony A1 has a fault and you still have a warranty, then it is best to complain about the camera and ask for the fault to be rectified.
Life happened. As such things have no future (as new camera will make most things obsolete) and require huge amount of unpaid time.
1st. From what i understood 2nd gen Sony cameras have recovery mode for firmware if firmware flashing failed interrupted or failed and camera is bricked, but only if version is newer than current one.
Did anyone figure out how to only change version of original firmware file say my camera currently FW v1.1 i want to flash custom firmware which i call version v1.2 then it failed and camera is bricked to recover camera i need to flash v1.3 official which does not exist for my camera, is there way to switch only version of official firmware package v1.1 to v1.3 somehow so i can use it to recover in worst case scenario?
All discussion that moved from nex-hack.info site. From what i can tell not all discussion have been moved, the most interesting part actually related to firmware is still there in archive.
@Vitaliy_Kiselev what happen to other people who been into hacking alpha series they all split from the project?
I am probably late to the party, but i am interested in hacking Sony firmware, the only problem i have is how not to brick the camera in the process of updating if i make mistake in the hack and can i flash old firmware to the chip in a hardware way?
Is there an email subscription list to be notified of new supported cameras? I see that it is supported up until the Sony A7R Mark IV. I would like to be notified when Sony A7R Mark V is added. Just bought it at a great price but unfortunately did not research enough about language limitations.
Good evening everyone, my name is Francesco :-) I'm desperately looking for someone owning a Sony A7RII camera with never upgraded firmware version 1.00 to help me dump and share this only version unaffected by "star-eater" algorithm with the community! Any help or even contact of someone owning such a device would be really appreciated ;-) Francesco
Just find tons of Info of Sony sensor AdjustCommand in adjstctl.elf of 7M3 firmware v4.00,
@malco Just find tons of Info of Sony sensor AdjustCommand in adjstctl.elf of 7M3 firmware v4.00, for example: struc_SonySenserCmd < 0x603, 1, "READ", 0x3E0166> struc_SonySenserCmd < 0x603, 2, "WRITE", 0x3E0166> struc_SonySenserCmd < 0x603, 3, "SAVE", 0x3E0166> struc_SonySenserCmd < 0x603, 4, "PDT_WRITE", 0x3E0166> struc_SonySenserCmd < 0x603, 5, "PDT_READ", 0x3E0166> struc_SonySenserCmd < 0x603, 6, "GET_PDT_STAT", 0x3E0166> struc_SonySenserCmd < 0x603, 8, "RESET", 0x3E0166> struc_SonySenserCmd < 0x603, 0x400F, "ID1", 0x3E0166> struc_SonySenserCmd < 0x603, 0x10, "VERSION", 0x3E0166> struc_SonySenserCmd < 0x603, 0x11, "DATA_CMP", 0x3E0166> struc_SonySenserCmd < 0x603, 0x12, "DATA_CHECK", 0x3E0166> struc_SonySenserCmd < 0x603, 0x4020, "FACTORY", 0x3E0166> struc_SonySenserCmd < 0x603, 0x21, "SERVICE", 0x3E0166> struc_SonySenserCmd < 0x603, 0x4022, "FACTORY_256", 0x3E0166> struc_SonySenserCmd < 0x603, 0x30, "OFFSET_ACCESS", 0x3E0166>
is possible to put software into camera one more time even if is already newest update, but if installed soft is hacked, probably "hard update" will help, problem is that updater will not re-update it because by this soft camera is obviously updated.
I have strange problem with my a7 mkI, camera seems to be hacked, or maybe it's just some soft flow? Sometimes camera exposing strangely, with high black point and very small dynamic range, seems to be hacked from outside by radio such as wifi...
Hi team! That's some amazing work. By any chance has anyone tried this with the A7C? I was about to buy one (in Japan) and discovered they force it to be in Japanese. It's been a long time since I've done anything more advanced than plonk Magic Lantern onto a 5DmkII... Thanks!
So I don't have a lot of money, but a friend his handed down his Sony Nex-7 camera to me and I'd like to remove the 30 minute recording limit. I only just became aware of the possibility of hacked firmware allowing this, but I've never done anything like this before and I'm afraid of bricking the camera. This is the nicest camera I've ever owned, possibly even the nicest camera I will ever own. Does any one have any info or tips on how to make this happen? Is there a pre-made file I can just download and throw on the camera? I'd rather not mess with a hex editor, I've had bad experiences with them in the past.
Similarly, any tips on making sure the camera doesn't overheat? I've heard buying an official Sony memory card will do it, but I'm skeptical, because when I've shot test videos, when the camera overheats the whole body starts to get warm. I bought the fastest 256gb Sandisk card I could get, but maybe it requires a higher electrical output that causes the overheating? I think the official Sony cards only go up to 16gb. Any advice about that would be great, too.
@Vitaliy_Kiselev Ah okey. If there is anybody willing to improve My a7ii om very happy to pay for the work! Sorry for bad English
It is clearly possible, but may require lot of work. I think Android file changes have zero effect on actual bitrate.
is it possible to tweak a higher bitrate? Maybe trough a mediaprofile.xml like in a normal android os. Im using a sony a7ii. Thanks
I have a Sony Alpha A7RII. My gimbal connected to the camera by PC Remote Connection. The gimbal support taking pictures and video recording from the gimbal panel and app. I car record video but I can not take pictures, the gimbal support service told me that there is a limitation from the PC Remote protocol of the Sony camera that this model can not save pictures on the camera memory card on PC. Then I start Sony Remote application and looks like it is true I didn't find any options to make a copy on the memory card. Is that a chance to remove this limitation and make camera to save pictures to the SD Card?.. Looks like since A7III came to the market they have added an option to the menu system which is called PC Remote Settings -> PC + Camera. Maybe there is a chance to the firmware hack just to change default behaviour from saving to PC to saving to SD Card...
Can anyone develop something to turn japanese only a6400 to english manual? This is killing me. I purchased the a6400 in japan, and got a brand new box not floor model, but found out it was japan version only, too late to return. Someone please help.
@pasha4ur I used it in August. All was good back then.
Developers, please create 1 video course with description how to make program like (for example) https://github.com/ma1co/PMCADemo + camera API description if you don't want make other apps for money.
thx
Hello
Why everything in sony hacks is stopped?
People is ready to donate for apps development on previous cameras but lazy developers don't want do anything. (
And no full Wiki to show how to make such apps for beginners.
There is a play memories app called 'light trail' that for some reason they restrict to the 5100 and a7s. Just wondering if anyone has tried to install this on other models using the open memories system, i.e. sony-pmca-re. I want to install it on my a6000 and i suspect there is a way to do this. Thanks.
Hello guys. New here and looking to unlock the languages on a Japanese Sony A7ii. Would anybody have the time (and patience) to possibly walk me through it please? Any help would be appreciated. Thanks.
