Livestream
Can be fake, but...
AMD Ryzen 9 5900X
Small leak on that happened with Zen 3 original plans to have 4 threads per core
Original Zen 3 design had 4 hyperthreading threads per each core.
But AMD could not make it work good due to thermal issues
As you have more threads you have more parts of each core used and thermal situation becomes worse. In benchmark case CPU can be forced to drop frequency up to 2 times to keep things under control.
In real life of modern 7nm processors they have parts of CPU constantly turned off to limit thermal happening due to leakage. And you can't do it adding too much threads.
Intel also needed to slow down CPU during heavy AVX-512 loads.
AMD can repeat stunt they made with client IO die (part of processor that deal with IO and RAM)
X570 chipset had been actually just mostly rewired IO die from Zen 2 CPU.
X670 chipset can be again just die put on separate board.
Specific models
New rumors
Note that for Zen 2 and Zen 1 number of total fully nondefective chiplets reached 98% after few months, so almost all of lower end CPUs have intentionally disabled cores and even most of the nonconnected chiplets in Threadrippers had been fully functional.
Now all Cores can share larger amounts of cache and add to that latency !!! Plop
Unlike the previous generation design where each CCD comprised of two CCX's (Core Complexes), the Zen 3 CCD will consist of a single CCX which will feature 8 cores that can run in either a single-thread mode (1T) or a two-thread mode (2T) for up to 16 threads per CCX. Since the chip houses a maximum of two CCDs, the core and thread count will max out at 16 cores and 32 threads which is the same as the existing flagship AM4 desktop CPU, the Ryzen 9 3950X.
Each Zen 3 core will feature 512 KB of L2 cache for a total of 4 MB of L2 cache per CCD. That should equal 8 MB of L2 cache on a dual CCD CPU. Along with the L2 cache, each CCD will also comprise of up to 32 MB of shared L3 cache. For Zen 2, the L3 cache was split between the two CCX's with each CCX having their own separate (Up To) 16 MB cache. The size of the cache remains the same per CCD but now all cores can share a larger number of L3 cache.
https://wccftech.com/amd-zen-3-ryzen-4000-vermeer-cpus-detailed-up-to-16-cores-32-threads/
New info tells about 10 core model in lineup
Two chiplet versions will be
According to rumors for present TSMC 7nm process and small chiplet size usually 85-90% of chiplets have all 8 cores working and 98% have at least 6 out of 8 working. So, almost all 10 core CPUs and most of 12 core ones are being made by disabling perfectly working cores, just out of marketing purposes.
IPC performance increase will be up to + 15% for integer workloads. For EPYC processors with up to 32 cores, AMD wants to achieve a performance increase of + 20% compared to the Rome processors with Zen 2 cores - the single-treaded performance should also increase by + 20%. For the larger EPYC processors with up to 64 cores, AMD expects a performance increase of around 10 to 15%. Apparently, AMD can achieve a higher clock rate for processors with fewer cores, so that the performance increase has a correspondingly higher effect with fewer cores.
Threadripper and Epyc socket will change from Zen 4
With Genoa, AMD is switching from the SP3 to the SP5 platform. The nominal thermal design power ranges from 120 to 240 W, although there are already special models that allow themselves more than 225 W (official TDP limit for normal models). The TDP increases slightly towards the top. AMD gives up platform compatibility with Genoa after three generations. However, due to the use of DDR5 and PCI-Express 5.0 as well as other functions, AMD has no other choice at this point.
Igor Wallossek's on AMD upcoming Vermeer processor series based on Zen3 architecture.The new information is for the clock speeds, which were decoded from an OPN code Igor was given by the source:
OPN CODE
100-000000059-52_ 48/35 _ Y
The 48 stands for 4.8 GHz boost clock, while 35 means 3.5 GHz base clock. It is still not the final sample, but definitely a faster stepping from the previous report. In June Igor covered first data on the B0 samples which were featuring a boost clock of 4.6 GHz and a base clock of 3.7 GHz.
100-000000059-14_46/37_Y
100-000000059-15_46/37_NEngineering samples mentioned are of course 16 cores and 32 thread CPUs, successors to Ryzen 9 3950X. The new OPN code means that the Vermeer sample is running 100 MHz higher on boost clock compared to 3950X, while the base clock has the same frequency.
Present leaks suggest that benchmarks that use all 16 cores will hsow only 3-7% performance increase comapred to same CPU in Zen 2 lineup.
Thermal constraints no longer allow AMD to increase performance as had been planned.
None of released CPUs will be overclockable (if you do not count extreme nitrogen and such).
AMD might in fact skip desktop 4000 series in favor of 5000.
This can make a lot of sense, as the current 4000 series lineup is extremely misleading.
AMD already introduced the series with Renoir-based Ryzen 4000U and Ryzen 4000H models.
New propaganda from Adored TV
Note that their claims about Zen 2 had been mostly bullshit (I mean performance gains and frequencies).
Here also note that they do not focus on performance per clock.
To get big integer performance advantage they need revolutionary architecture changes.
And note that they are not changing 7nm process much.
Idea of banchamrks can be making special ones that heavily depend on RAM throughput, so making good progress in this regard and comparing you can get needed numbers.
AMD in an official briefing call with us confirmed that the company's "Zen 3" client processors are on-track for launch within 2020. This refutes rumors that "Zen 3" based Ryzen processors had been delayed to 2021 in favor of giving the upcoming Ryzen 3000XT reign over the rest of the year. The call was chaired by AMD's client-segment product managers who were speaking purely in context of their product segment, which is how we deduce that they were referring to "Vermeer" and not [just] "Milan." They were responding to speculation that "Zen 3" has been delayed to 2021, forcing AMD to refresh its existing IP.
In the call, AMD told us that the information about "Zen 3" launching in 2020 is not under embargo, and so here we are. An AMD spokesperson told us that "the rumor on Zen 3 delay is inaccurate." AMD recently also refuted rumors of "Zen 3" being based on 5 nm, by putting out microarchitecture roadmap slides on the occasion of a recent investor relations event, which reaffirmed "Zen 3" as a 7 nm-class microarchitecture.
Back on track.
Digitimes, VideoCardz, and RetiredEngineer (twitter) started an intriguing rumor that Ryzen 4000 might end up at 5nm+. Asking around at a reliable place, we have to disappoint some of you as this won't be the case. The Ryzen 4000 series based on Zen 3 core is still at 7nm.
As expected 5nm thing had been idiotic TSMC PR move. As it seems that they don't have 5nm suitable for high powered chips at all now. And wanted to make info clouds for US to make it look that existing 5nm will be suitable for their needs.
