AMD X570, B550, A520 chipsets and motherboards on them
  • 116 Replies sorted by
    800 x 331 - 87K
    747 x 880 - 85K
  • Tech stuff
    14nm BGA 768 package (around 32% more compared to x470). 24.5mmx24.5mm.
    800 x 453 - 66K
  • X570 ACE
    738 x 417 - 53K
  • One more chart
    800 x 450 - 57K
  • Chipset block scheme leaked
    Nice thing that it can support 2 PCIe 4.0 M.2 SSDs now contrary to one PCIe 2.0 in previous. And due to PCIe 4.0 interconnect to CPU it can even copy at full speed from one to another if you use PCIe 3.0 SSDs.
    But very bad thing is that using 3 SSDs lead to x4 slot being turned off. So we again have pair of x8 max available for GPUs.
    800 x 818 - 89K
  • MSI Gaming Plus ANd Gaming Pro Carbon Boards
    701 x 774 - 113K
    715 x 802 - 128K
  • Colorful CVN X570 Gaming Pro MB
    744 x 489 - 67K
    704 x 602 - 62K
  • Specs from Biostar x570 MB leak
    As we can see, only meaningful change is much better PCIe M.2 SSD support compared to previous chipsets.
    x570 chipset have structure similar to Intel chipsets.
    678 x 939 - 128K
    764 x 915 - 132K
  • Some weird leaks
    • 40 PCIe 2.0 chipset lines, this is really weird as chipset lines must long ago move to PCIe 3.0.
    • PCIe 3.0 16 lines will be available for x570 only, but not for lower end chipsets
    • 8 USB 3.1 Gen2 ports in chipset
    • Most important are not PCIe 4.0 lines to GPU, but PCIe 4.0 4x to chipset as it is long lasting issue in older chipsets
  • It'll be lot of X570 motherboards at Computex, including Biostar
    750 x 477 - 73K
    • X570 Aorus Xtreme
    • X570 Aorus Master
    • X570 Aorus Ultra
    • X570 Aorus Elite
    • X570 I Aorus Pro WiFi
    • X570 Aorus Pro
    • X570 Gaming X.
    780 x 296 - 56K
  • Asus upcoming motherboards list
    • ROG STRIX X570-E GAMING
    • ROG STRIX X570-F GAMING
    • ROG STRIX X570-I GAMING
    • ROG CROSSHAIR VIII FORMULA
    • ROG CROSSHAIR VIII HERO
    • ROG CROSSHAIR VIII HERO (WI-FI)
    • ROG CROSSHAIR VIII IMPACT
    • TUF GAMING X570-PLUS (WI-FI)
    • PRIME X570-P
    • PRIME X570-PRO
    • Pro WS X570-ACE
  • About B550 and other low end chipset
    Despite specualtion that AMD will stop working with ASMedia in the development of next-generation 500 series motherboard PCH chipset after developing X570 motherboard chipsets on its own, ASMedia has maintained that its partnership with AMD in the next-generation 500 series chipsets will remain unchanged,as it has secured all the orders for mainstream motherboard PCH chipsets, the sources said.
    AsMedia will keep doing it.
  • ASRock boards on chipset will be:
    • ASRock X570 Phantom Gaming X
    • ASRock X570 Phantom Gaming 6
    • ASRock X570 Phantom Gaming 4
    • ASRock X570 Extreme4
    • ASRock X570 Taichi
    • ASRock X570 Pro4
    • ASRock X570 Pro4 R2.0
    • ASRock X570M Pro4
    • ASRock X570M Pro4 R2.0
