AMD X570, B550, A520 chipsets and motherboards on them
    • First in Ryzen family of chipsets made inside company, chipsets are very profitable business, this is why AMD doing this
    • Much higher TDW of 15 watts
    • 4x PCIe 3.0 lines connecting CPU and chipset will be replaced by 4x PCIe 4.0 lines doubling throughput
    • All lines provided by chipset will be PCIe 3.0 or PCIe 4.0.
    • Number of provided lines will rise by 25-50%
    • It'll have 4 USB 3.1 Gen2 ports controller not requiring additional Asmedia chips and supporting part of power delivery standards.
    • We can see build in 10Gbe network controller (that will still require additional chips and transformer).
  • 116 Replies sorted by
  • ASRock boards on chipset will be:
    • ASRock X570 Phantom Gaming X
    • ASRock X570 Phantom Gaming 6
    • ASRock X570 Phantom Gaming 4
    • ASRock X570 Extreme4
    • ASRock X570 Taichi
    • ASRock X570 Pro4
    • ASRock X570 Pro4 R2.0
    • ASRock X570M Pro4
    • ASRock X570M Pro4 R2.0
  • About B550 and other low end chipset
    Despite specualtion that AMD will stop working with ASMedia in the development of next-generation 500 series motherboard PCH chipset after developing X570 motherboard chipsets on its own, ASMedia has maintained that its partnership with AMD in the next-generation 500 series chipsets will remain unchanged,as it has secured all the orders for mainstream motherboard PCH chipsets, the sources said.
    AsMedia will keep doing it.
  • Asus upcoming motherboards list
    • ROG STRIX X570-E GAMING
    • ROG STRIX X570-F GAMING
    • ROG STRIX X570-I GAMING
    • ROG CROSSHAIR VIII FORMULA
    • ROG CROSSHAIR VIII HERO
    • ROG CROSSHAIR VIII HERO (WI-FI)
    • ROG CROSSHAIR VIII IMPACT
    • TUF GAMING X570-PLUS (WI-FI)
    • PRIME X570-P
    • PRIME X570-PRO
    • Pro WS X570-ACE
    • X570 Aorus Xtreme
    • X570 Aorus Master
    • X570 Aorus Ultra
    • X570 Aorus Elite
    • X570 I Aorus Pro WiFi
    • X570 Aorus Pro
    • X570 Gaming X.
    780 x 296 - 56K
  • It'll be lot of X570 motherboards at Computex, including Biostar
    750 x 477 - 73K
  • Some weird leaks
    • 40 PCIe 2.0 chipset lines, this is really weird as chipset lines must long ago move to PCIe 3.0.
    • PCIe 3.0 16 lines will be available for x570 only, but not for lower end chipsets
    • 8 USB 3.1 Gen2 ports in chipset
    • Most important are not PCIe 4.0 lines to GPU, but PCIe 4.0 4x to chipset as it is long lasting issue in older chipsets
  • Specs from Biostar x570 MB leak
    As we can see, only meaningful change is much better PCIe M.2 SSD support compared to previous chipsets.
    x570 chipset have structure similar to Intel chipsets.
    678 x 939 - 128K
    764 x 915 - 132K
  • Colorful CVN X570 Gaming Pro MB
    744 x 489 - 67K
    704 x 602 - 62K
  • MSI Gaming Plus ANd Gaming Pro Carbon Boards
    701 x 774 - 113K
    715 x 802 - 128K
  • Chipset block scheme leaked
    Nice thing that it can support 2 PCIe 4.0 M.2 SSDs now contrary to one PCIe 2.0 in previous. And due to PCIe 4.0 interconnect to CPU it can even copy at full speed from one to another if you use PCIe 3.0 SSDs.
    But very bad thing is that using 3 SSDs lead to x4 slot being turned off. So we again have pair of x8 max available for GPUs.
    800 x 818 - 89K
  • One more chart
    800 x 450 - 57K
  • X570 ACE
    738 x 417 - 53K
    800 x 453 - 66K
  • Tech stuff
    14nm BGA 768 package (around 32% more compared to x470). 24.5mmx24.5mm.
    800 x 331 - 87K
    747 x 880 - 85K
  • MSI Boards
    Links to product pages
    MPG X570 Gaming Plus
    Two M.2 slots with one being non PCIe 4.0.
    For gamers who just want to focus on playing for fun or for competition, MPG X570 GAMING PLUS provides an uncomplicated and essential platform for gaming quickly with AMD Ryzen. To support more cores processors, exclusive Frozr Heatsink, Extended Heatsink and M.2 Shield Frozr are also included with advanced technology to make sure any thermal issues won’t occur. Furthermore, Atypical PCB design also makes cable management with SATA and USB ports easier than before. Take enjoyment in a reliable design with the MPG X570 GAMING PLUS for sustained system performance.
    MSI Gaming Edge WiFi
    Mostly same thing with Wi-Fi.
    Play dangerously with MPG X570 GAMING EDGE WIFI and strike fear into the hearts of every foe. The upgraded larger Extended Heatsink Design integrates with Pre-installed I.O Shielding not only improves cooling for high-end CPU but also provides easy installation. Onboard Intel wireless-AC makes download speeds up to 1.73 Gbps to enjoy high-speed networking connection. Sharpen any build with a highly functional motherboard MPG X570 GAMING EDGE WIFI, ready for immersive gaming experience.
    MPG X570 Gaming Pro Carbon WiFi
    Again - same thing but with better looks.
    Inspired by supercars concept, MPG X570 GAMING PRO CARBON WIFI is a high-performance motherboard with an intense high-speed look, combining with MSI Mystic Light for colorful customization with millions of colors and 29 LED effects. The latest Lightning Gen4, Frozr Heatsink Design and M.2 Shield Frozr ensure high-speed performance and better thermal solution. Tune advanced gaming system configurations such as WIFI 6 AX with up to 3x bandwidth, delivering speeds up to 2400Mbps, and Pre-installed I/O Shielding for more convenient installation.
    MEG X570 Ace
    Better VRM.
    More or less useful thing. 3x M.2 PCIe 4.0 places.
    Go for the gold, MEG X570 ACE follows a golden luxurious scheme with exclusive Mystic Light Infinity for the mirror reflection effects with millions of colors. It also features Dual LAN including 2.5G gaming LAN and Wi-Fi 6, the latest technology to make sure networking quality. MEG series motherboards all include Extended Heat-Pipe Design, connecting between heatsinks, aiming at enlarging the surface of heat dissipation. Audio Boost HD is an unforgettable audio technology including high definition audio processors and ESS audio DAC. MEG X570 ACE provides enthusiast gamers everything to win every game.
    MSI Prestige X570 Creation
    Seems similar to previous but with WiFi. Has 10Gbit LAN port.
    Unleash your imagination PRESTIGE X570 CREATION, this motherboard is best for content creation while doing heavy loading operations. Featuring dual LAN with 10G Super LAN, this makes sure both Intranet and Internet connection faster than before. Wi-Fi 6 is the next generation networking solution offering 3x bandwidth and lower latency. Furthermore, PRESTIGE X570 CREATION owns a total thermal solution including Frozr Heatsink, Extended-Heat-Pipe and M.2 Shield Frozr. Frozr Heatsink Design is equipped with patented double ball bearing fan with MSI exclusive Propeller Blade Technology and Zero Frozr and AI Tuning Technology to maintain the best performance, plus Extended Heat-Pipe Design to enlarge the surface of heat dissipation. M.2 Shield Frozr can cool down M.2 devices and prevent throttling. The brand-new Creator Center is MSI exclusive software for designers and content creators with optimized system modes and resources for a wide range of scenarios and needs.
    MEG X570 Godlike
    Absolutely mad $800 price top MB.
    Except some tests and ads it is no reason to even look at such.
    MEG X570 GODLIKE continues to dominate the gaming motherboard market catered for not only hardcore gamers but also enthusiast overclockers. Exclusive GODLIKE features including Dynamic Dashboard with OLED display for various hardware conditions, Killer network solutions including Killer xTend, the latest Killer Wi-Fi 6 also provide better connections. Xtreme Audio DAC also brings a selection of premium audio hardware for the most immersive audio experiences. Other than that, MEG X570 GODLIKE features the brand-new Frozr Heatsink Design, Extended Heat-pipe and Double side M.2 Shield Frozr for the best thermal solution. Mystic Light Infinity II introduces new RGB lighting effects with infinity mirror reflection effects. Bundled with MEG X570 GODLIKE, the M.2 XPANDER-Z Gen4 card expands M.2 Gen4 SSDs and 10G Super LAN Card provides extreme transfer speed no matter downloading, playing game, or even watching a 4K video on the internet.
    PR
    May, 2019 –MSI, the world leading motherboard brand, has proudly announced our brand new AMD AM4 motherboards with X570 chipsets. Not only tailored for enthusiast gamers, we also offer more possibilities for content creation and office use, dedicated to all types of PC users to satisfy their needs. This time, we carefully prepared a great variety of advanced technology and features to help our customers create the most immersive experiences and maximize performance.
    “AMD is continuously working closely with MSI to create exceptional hardware designs that deliver incredible performance for users. AMD X570 chipsets support upcoming 3rd Generation AMD Ryzen Processors and PCIe 4.0 technology, a revolutionary enhancement in transfer speed for both PCIe devices and M.2 storage”said Chris Kilburn, corporate vice president and general manager, Client Channel, AMD. ”We are excited about what AMD and MSI deliver for our customers with MSI X570 motherboards and MSI Lightning Gen 4 solutions.”
    FROZR HEATSINK DESIGN
    To support upcoming 3rd Gen AMD Ryzen™ processors’ advanced performance algorithms, MSI X570 motherboards utilize high-end thermal solutions with our new Frozr Heatsink Design. This integrates the heatsink and a patented fan with double ball bearings for better durability, combining with Propeller Blade Technology to generate more airflow, lower noise and Zero Frozr Technology to auto-adjust fan speed for chipset temperature, and based on personal preference.
    All MSI X570 motherboards feature the latest PCIe 4.0 technology for PCIe peripherals and M.2 storage slots. The Lightning Gen4 M.2 slots can support up to 64 GB/s bandwidth and faster transfer speed than before. For such high performance conditions, M.2 Shield Frozr helps cool M.2 devices to avoid throttling.
    CORE BOOST WITH IR DIGITAL VRM
    Core Boost technology has become an iconic MSI feature, not only supporting multi-core CPUs but also helping create the perfect conditions for CPU overclocking . Combining IR digital power design with all MSI X570 motherboards and dual 8pin power connectors, this ensures precise and undistorted power delivery to the CPU for a faster and more stable system.
    SERVER GRADE PCB
    To sustain reliable and long-lasting system performance, server grade PCB construction prevents PCB bending and improves signal transfer effectiveness by up to 30%.
    The brand new Dragon Center has adopted Universal Windows Platform (UWP) functionality to enhance versatility for all devices. An upgraded, user-friendly and intuitive user interface offers an enhanced experience. By integrating all MSI exclusive software for all MSI products into the new Dragon Center users will easily find what they need in Dragon Center or sync all MSI products at the same time.
    800 x 702 - 98K
    766 x 797 - 109K
    800 x 752 - 105K
    800 x 734 - 95K
    800 x 712 - 103K
    800 x 696 - 99K
    792 x 853 - 142K
    743 x 878 - 123K
    770 x 882 - 113K
    800 x 809 - 94K
  • X570 I Aorus Pro Wi-Fi, $219
    • 8-phase Digital VRM
    • Wi-Fi 6
    • Intel GbE LAN chip
    • Realtek ALC1220-VB audio
    • Two M.2 slots
    X570 Aorus Elite, $199
    • 14-phase digital VRM with dual heatsinks
    • Realtek ALC1200 audio
    • Six SATA ports
    • Only two M.2 slots
    • Only two PCIe x16 slots
    X570 Aorus Pro, $249
    • Six SATA ports
    • Three PCIe x16 slots (one is from chipset and is limited to x4)
    X570 Aorus Ultra, $299
    • 14-phase digital VRM with dual finned heatsinks
    • Intel Wi-Fi 6 802.11ax
    • Six SATA ports
    • Three M.2 slots
    X570 Aorus Master, $349
    • Realtek 2.5Gbe network chip
    • Six SATA ports
    • Three M.2 slots
    X570 AORUS Extreme, $599
    • 16-phase digital VRM with dual finned heatsinks
    • 10Mbit Aquantia LAN
    • Six SATA ports
    • Three M.2 slots
    GIGABYTE TECHNOLOGY Co. Ltd, a leading manufacturer of motherboards and graphics cards, announced the launch of the newest X570 AORUS series motherboards primed to unleash the potential of the highly anticipated 3rd Gen AMD Ryzen™ desktop™ processors. Fully compatible with these new processors, X570 AORUS series motherboards kick off the PCIe® 4.0 era with extensive feature sets. The flagship X570 AORUS XTREME motherboard is fitted with a 16-phase digital power design for unmatched power management and a Fins-Array Stacked Fin Heatsink with Direct Touch Heatpipes for the strongest VRM cooling. Both features are aimed towards optimizing performance on the 3rd Gen AMD Ryzen desktop processors. Select X570 AORUS motherboards also deliver ultra fast connectivity at 2.4Gbps with the WiFi 6 802.11ax wireless standard and further improve the user experience with the newest iteration of Q-Flash Plus Technology for users to update the BIOS with ease and convenience. X570 AORUS series motherboards lead the new era of gaming performance.
    “In anticipation of the release of the AMD X570 chipset and 3rd Gen AMD Ryzen™ desktop processors, GIGABYTE is ready to launch a product series that sets the standard for compatibility and product quality from an AMD platform based motherboard while checking all the boxes for a gaming motherboard,” said Jackson Hsu, Director of the GIGABYTE Channel Solutions Product Development Division. “Gamers and performance focused users will be impressed with the features that GIGABYTE has implemented on the X570 AORUS motherboards. Some of these highlight features include a 16-phase digital power design, PCIe 4.0, high speed network connectivity, RGB Fusion lighting, and a new BIOS UI. Through our professional research and development, we have engineered a product that offers both the performance and stability gamers are looking for when building an AMD platform desktop.”
    The highly anticipated 3rd Gen AMD Ryzen™ desktop processors deliver on the hype, outclassing previous generation processors with impressive performance jumps that users covet when they upgrade from one generation of processors to the next. Capitalizing on this performance potential, GIGABYTE packs at least 14-power phases in the digital power designs of each ATX board in the X570 AORUS Series. Different tasks require different levels of power consumption so to account for this varying power consumption, GIGABYTE uses a PowIRstage or DrMOS and different MOSFETs to ensure a more stable current flow and better power and thermal management while the CPU is running at its full potential. The flagship X570 AORUS XTREME motherboard boasts a 16-phase, all Infineon digital power design with each phase capable of managing up to 70A for lower impedance and improved balance. With 16-phases to work with, the motherboard reduces the loading per phase so that less heat is generated, improving the overall power efficiency, durability and service life of the motherboard. This allows for better performance and better overclocking and enables users to maximize the overclocking potential on the new 3rd Gen AMD Ryzen desktop processors without the concerns of an unstable power supply or high temperatures causing overclocking failures or diminished performance. The Fins-Array Stacked Fin Heatsink, Direct Touch Heatpipes, and the Nanocarbon Baseplate provide an incredible amount of cooling to the VRM and chipset making this the most comprehensive cooling solution for the 3rd Gen AMD Ryzen™ desktop processors, perfect for an AMD platform build.
    PCIe 4.0 is here and with it comes higher bandwidth. With 32GB/s bandwidth and increased bandwidth for graphics cards, PCIe NVMe AIC SSDs, and M.2 NVMe SSDs, the new interface far surpasses the bandwidth limitations of previous generations. GIGABYTE has keyed in on the performance potential of PCIe 4.0 and has refined the design of its motherboards to elevate the performance of peripheral components. Design features such as server-grade PCBs with low inductance and a PCIe 4.0 B-CLK IC maximize the PCIe bandwidth to increase the data transmission capacity on PCIe storage devices and boost overclocking performance from CPUs and memory. The motherboard unlocks hidden performance potential on peripheral components, allowing for blazing fast transmission speeds on these devices. As the PCIe 4.0 era arrives, GIGABYTE has also introduced its newest PCIe 4.0 interface based PCIe NVMe M.2 SSD and AORUS M.2 PCIe 4.0 riser cards which allow for 4800 MB/s transmission speeds on the PCIe NVMe M.2 SSDs. Users can install four NVMe M.2 SSDs at once with the AORUS M.2 PCIe 4.0 riser card to increase storage capacity and even build a RAID array through the OS for impressive storage performance and solid data integrity, fully taking advantage of the new PCIe 4.0 interface.
    M.2 slots on the X570 AORUS Series Motherboards support PCIe 4.0 and SATA modes so users can purchase M.2 SSDs without compatibility concerns. The 64Gb/s bandwidth of PCIe 4.0 enables M.2 NVMe SSDs to perform at their full potential. Thermal throttling can be a detriment to SSD performance by slowing down read/write speeds and GIGABYTE has implemented M.2 Thermal Guards to combat the excess heat from device operation. M.2 SSD devices are protected from the heat and can perform like they are designed to.
    The entire X570 AORUS lineup offers Intel® Gbe LAN and the X570 AORUS MASTER and X570 AORUS XTREME provide 2.5Gbps and 10Gbps connection speeds respectively. Gamers now have the fastest and most stable wired network connectivity with this setup. All WiFi enabled models in the lineup feature the Intel® WiFi 6 802.11ax standard which delivers blazing fast 2.4Gbps connection speeds that almost rival the 2.5Gbps Ethernet connection speeds. With both high-speed Ethernet and WiFi, users have extra flexibility and ridiculously fast connection speeds.
    Fan favorite and well-received features from previous AORUS lineups make their return to select X570 AORUS motherboards. Sleek I/O shroud design, RGB Fusion LED lighting, Smart Fan, Hi-Fi audio, and many more trademark features have been further refined and added to the mix with AMD’s built-in features. The newest edition of Smart Fan technology is featured on two of the X570 AORUS motherboards and comes with a noise sensor that measures the decibel levels of the fan noise and enables users to adjust the noise levels to their liking for improved noise reduction. Silent and cool fan operation has never been more user friendly.
    AORUS X570 series motherboards come with the newest version of Q-Flash Plus Technology. Users can easily update the BIOS without even installing a processor, memory, graphics cards, or booting up the PC so they can flash the BIOS without the concerns of not being able to boot up the system due to compatibility issues. X570 AORUS series motherboards use an upgraded BIOS interface, providing users with a more intuitive user interface so they can easily tune their settings to upgrade their performance and overclocking.
    X570 AORUS motherboards use only the finest components reinforced by GIGABYTE Ultra Durable™ Technology to extend product durability and service life. Through the use of all solid caps, digital power designs, and Smart Fan technology to provide energy-conserving and effective cooling solutions, AORUS motherboards are an excellent choice for users seeking to build a high-end PC system so they can enjoy the best gaming experience motherboards have to offer.
    • Supports AMD 3rd Gen Ryzen™/ 2nd Gen Ryzen™/ 2nd Gen Ryzen™ with Radeon™ Vega Graphics/ Ryzen™ with Radeon™ Vega Graphics Processors
    • Dual Channel ECC/ Non-ECC Unbuffered DDR4, 4 DIMMs
    • Direct 16 Phases Infineon Digital VRM Solution with 70A PowIRstage
    • Thermal Reactive Armor Design with Fins-Array Heatsink, Direct Touch Heatpipe and NanoCarbon Baseplate
    • Triple Ultra-Fast NVMe PCIe 4.0/3.0 x4 M.2 with Triple Thermal Guards
    • Onboard Intel® WiFi 6 802.11ax 2T2R & BT 5 with 2X AORUS Antenna
    • Rear 130dB SNR AMP-UP Audio with ALC1220-VB & ESS SABRE 9218 DAC with WIMA Audio Capacitors
    • AQUANTIA® 10GbE BASE-T LAN + Intel® Gigabit LAN with cFosSpeed
    • Exclusive RGB FAN COMMANDER for Professional Casemoders
    • USB TurboCharger for Mobile Device Fast Charge Support
    • RGB FUSION with Multi-Zone Addressable LED Light Show Design, Support Addressable LED & RGB LED Strips
    • Smart Fan 5 Features Multiple Temperature Sensors , Hybrid Fan Headers with FAN STOP and Noise Detection
    • Front & Rear USB 3.1 Gen 2 Type-C™ Headers
    • Q-Flash Plus Update BIOS Without Installing CPU, Memory and Graphics Card
    • CEC 2019 Ready, Save Power With a Simple Click
    Other boards
    800 x 623 - 68K
    800 x 581 - 70K
    800 x 517 - 87K
    800 x 679 - 113K
    800 x 655 - 111K
    800 x 660 - 113K
    800 x 658 - 115K
    800 x 609 - 96K
  • Asrock
    Phantom Gaming 4
    X570 Steel Legend
    X570 Extreme 4
    X570 Creator
    X570 Pro4
    Phantom Gaming X
    • Intel® Wi-Fi 6 802.11ax (2.4Gbps) + BT 5.0
    • 2.5 Gigabit LAN
    • Intel® Gigabit LAN
    • 2 Hyper M.2 (PCIe Gen4 x4 & SATA3), 1 Hyper M.2 (PCIe Gen4 x4)
    • 3 PCIe 4.0 x16, 2 PCIe 4.0 x1
    • Realtek ALC1220
    • 8 SATA3 ports
    • 3 USB 3.2 Gen2 (Rear Type A+C, Front Type-C),
    Taichi
    • Realtek ALC1220
    • 8 SATA3 ports
    The leading global motherboard ,graphics card and small form factor manufacturer, ASRock, is proud to announce and showcase the latest PC products, which include motherboards, small form factor PC and graphics cards, at the upcoming COMPUTEX Taipei 2019. ASRock welcomes visitors to experience our leading products and technologies at booth #L0410 of the Taipei Nangang Exhibition Center Hall 1 in Taipei, Taiwan from May 28 th to June 1 st, 2019.
    ASRock will reveal the latest creation based on the revolutionary AMD X570 chipset. The new product is filled with many exciting features and new technology such as the support of PCI Express® 4.0 standard, this specification doubles the throughput of PCIe 3.0 and provides speeds up to a staggering 16 GT/s. And not only that , the new X570 motherboards also comes with a Wi-Fi 6 (802.11ax) high-efficiency wireless network, better cooling solutions, even more eye catching designs as well as RGB lighting effects, providing a total solution and complete technology breakthrough to accommodate data center and high-speed consumer applications.
    During COMPUTEX 2019, ASRock teamed up with Phison Electronics and will be demoing the incredible speed of PCI Express 4.0 with their latest PCIe 4.0 x4 NVMe M.2 SSD solution. Since this new standard was supported across the whole X570 motherboard series, PCI Express 4.0 storage devices will soon be the future for every performance enthusiast.
    “We are excited the launch of AMD X570 chipset based motherboard at COMPUTEX 2019 to accelerates the speed of PCI Express to the next level, in order to handle the high performance computing required faster PCI Express bandwidth, “said Chris Lee, General Manager of ASRock Motherboard & Gaming Peripherals BU. “The partnership with Phison will demonstrate the incredible data transfer speed with ASRock X570 series motherboard and Phison PCIe Gen4x4 NVMe SSD, to meet the PC enthusiast most demanding performance for various applications.”
    “We are happy to be a strong contributor of AMD’s PCIe 4.0 ecosystem. In joint force with AMD’s leadership Ryzen™ and X570 chipsets and Gen4 enabled motherboard partners, Phison’s will be releasing its own PCIe Gen4x4 NVMe PS5016-E16 SSD solution to the market, completing the world’s first consumer affordable PCIe 4.0 PC application platform”, said K.S. Pua, chairman and CEO of PHISON. “Through the strategic alliances, ecosystem partners can finally embrace the growth of emerging application markets that can benefit from high-performance computing, such as 5G services and 8K HD contents, unlocking the gate to the new technology era.”
    664 x 701 - 113K
    800 x 577 - 66K
    800 x 588 - 86K
    800 x 712 - 124K
    800 x 649 - 92K
    800 x 786 - 124K
    800 x 547 - 69K
    800 x 750 - 99K
    800 x 442 - 71K
    800 x 571 - 78K
    800 x 453 - 67K
  • AMD also dropped official support for first gen Ryzen to make more new CPUs sales
    717 x 409 - 68K
  • Asus Motherboards
    ROG Crosshair VIII Formula
    • ATX (12 x 9.6 in.)
    • 4 DDR4/ 128 GB DRAM
    • PCIe - x16 or x8/x8, PCIe 4.0 x1 - 1
    • 8 SATA ports
    • Two M.2 1x 22110 (SATA + PCIe 4.0 x4)
    • Has USB 3.2 Gen 2 front connector
    • USB 3.2 Gen 2 - 7 x Type-A at back, 1 x Type-C at back
    • Intel® I211AT LAN
    • Aquantia 5G LAN
    • Intel Wireless-AX 200 2 x 2 Wi-Fi 6 (Strix X570-E)
    • Realtek S1220A Audio
    ROG Crosshair VIII Hero (Wi-Fi)
    • 8 SATA ports
    • Intel® I211AT LAN
    • Realtek 2.5G LAN
    Crosshair VIII Impact
    Mini DTX board.
    STRIX x570 I
    They also have full size Strix and Strix X570-F boards.
    • PCIe - x16 or x8/x8, PCIe 4.0 x1 - 2
    • 8 SATA ports
    • USB 3.2 Gen 2 - 3 x Type-A at back, 1 x Type-C at back - X570-F
    • USB 3.2 Gen 2 - 7 x Type-A at back, 1 x Type-C at back - X570-E
    • Intel® I211AT LAN
    • Realtek 2.5G LAN (Strix X570-E)
    TUF Gaming X570-Plus
    Also they have TUF Gaming X570-Plus Wi-Fi.
    • PCIe - x16 or x8/x8, PCIe 4.0 x1 - 2 (3 for Plus model)
    • 8 SATA ports
    • No USB 3.2 Gen 2 front connector
    • USB 3.2 Gen 2 - 2 x Type-A at back, 1 x Type-C at back
    • Realtek L8200A LAN
    • Realtek S1200A Audio
    800 x 733 - 102K
    800 x 638 - 92K
    800 x 731 - 105K
    800 x 602 - 96K
    800 x 652 - 116K
  • Info updated.
  • COLORFUL CVN X570 GAMING PRO V14
    541 x 523 - 49K
    800 x 447 - 68K
  • Big thanks! All in one place.
    x570 MBs are more expensive clearly.
