@bottles101 Great. Let me know when this be quite fan arrives. Looks like stock fan , but quieter for sure
Interesting, I did not know PWM could be used with it given that stock is three wires.
I did find that if I put any aftermarket fan's wiring in parallel with the stock fan wiring (rather than replacing the stock fan) it does not throw any error.
Meaning that worst case scenario, as long as the light is not overheating from whatever aftermarket fan is used, the stock fan can be left connected in parallel to prevent it from throwing the error and/or affecting light output, and simply separate the stock fan to a soundproof box somewhere on the floor (like a portable ice chest). So it would still running the stock just to prevent the error but the fan is neither contributing airflow or noise. Obviously not ideal since would make the light less mobile but might be good knowing there is at least something of a solution to the error itself, if it comes to that.
I have a different fan headed my way that will hopefully pull enough air to not overheat, it's an oversized 92mm be quiet pure wings 2, looks like it will fit as long as it is epoxied directly to the heatsink instead of using the screw holes. Might even be able to just use some Sugru. Anyway I get the feeling due to the oversized fan it will cover the heatsink a lot better and pulls more air while still being relatively quieter.
In the meantime I am going to do a couple tests to mimic the exact level of current pulled by stock to see if that stops the error. Probably by just taking a couple .15A fans and putting them in parallel in the circuit. If this works then a resistor can be added to the circuit to increase the current to match what the board is expecting.
My two unit of SL60W have different models of fan: Snowfan YY9225M12B http://www.09635.com/trade/3621254.aspx
Progressive PD922512LB https://himg.china.cn/0/3_774_93129_533_800.jpg
Being "Progressive" lot of noiser than "Snowfan"
@bottles101 100% Agree. Now i'm working with Noctua NF-A8 PWM with restrictor cable and a bridge, so i have a 2 speed/modes fan. ULN airflow is not enought even for SL60. And to make things worse, the ULN adds a lot of flickering to the light at its low power (10-30%). Dont know the reason, but the extrange battery symbol and the flicker makes the noctuas not usable at all. So it's time for hound a silent fan that fit and macht the current of original part. Attached the image of the cable i make, with 2 speed wire.
                  @Grimor I just tried doing this myself on an SL-150W and as it turns out this model does not have that part of the board at all. See attachment. Power goes straight off the board.
Given that the stock fan is rated for six times the current of the Noctua (.30 vs .05A) I think the board is throwing an error because it is not pulling enough power. The flashing battery symbol on the display is the same as when no fan is plugged in.
I am thinking a different fan needs used, one that pulls more current, or maybe there is a resistor that can be bypassed on the noctua so it pulls more current. Even if you wanted to just ignore the flashing error on the board the SL-150W quickly overheats when used with a Noctua NF-A8 ULN, it is just too slow for that much heat and causes the light to shutdown within a few minutes.
                  Solved. Noctua and stock fan has same wire colours, but in diferent order. The issue was i was trying to plug in the same port as stock fan. There's a little PCB (labeled FANRC) screwed to the main board with a big capacitor and several microresistors in the other side that need to be disconnected and plug the noctua direct to the main board in order to work. Dont know the purpose of this pcb, and the risk of get it off.
Maybe keep the fan spinning after powering off the unit, @Vitaliy_Kiselev ?
                  @Jooon @gdg444 @scochtape i bought a noctua NF-A8 ULN but can't make it work with sl60w. I strip and solder cables with same color (yellow-yellow, black-black and red-red). Led light keeps blinking. I notice that old plug has different order that new one, so i change signal and +12v order with no luck. What i'm missing here?
@Grimor The heat is blown out through the front heat sink, so it's practically the same, no changes here.
But talking about the fan: If you want replace the fan with a less noisy one, changing the body is a good time to also replace the fan. There is quite a difference regarding the fan noise between different SL-60 lights, so it might not be necessary, but if you have a loud one it's definitely worth it.
Parts needed: be quiet! Shadow Wings SW1 Low-Speed 80mm 1400rpm (BL050) - Get exactly this fan, there are different speed versions of this fan
3 x Dupont Cables Male-Female 10 cm (AliExpress)
This is a straight forward replacement for the original fan, you just have to widen the holes on the fan to accept 3mm screws. Use three dupont cables to connect the fan to the main board (the plug on the original fan is different).
Thanks, very good looking thing.
I made a shorter, lighter body with a flat 1/4" tripod mount for the Godox SL-60 video light that can be printed on any 3D printer.
This modification saves about 400 g and makes the lamp 4 cm shorter. The flat bottom with the integrated 1/4" mount lets you use any camera tripod.
Free download on Thingiverse: Godox SL-60 LED Video Light Short Body
                  Does anyone know how to replace the fan on the Godox SL60W LED, I saw your review and picked one up and have ordered a Noctua NF-A8 ULN Premium 80mm Fan but cannot find any info on replacement. Do I go in from the front assuming fan is behind the heat sink? Any help would be appreciated. Thanks for your time
UPDATE:
After taking this light apart and "attempting" to replace the fan I discovered the SL60W is using the old fan plug ins. The Noctua NF-A8 ULN uses the newer style so unless you can get an adapter or start splicing wires don't really think it's worth the trouble, live and learn.
                  Issue with SL-100W and SL-200W
Another view on noise spectrum
Note that here values are normalized.
Light on
Light off
Note that here values are normalized, so do not compare level of this with anything.
Near Turning off Event
You can see ripple made by switch click.
                  Additional noise video (we made A-weighted measurements, but it is more detailed 3D spectrogram)
Our Video Review
True but its same battery as AD600 which looks good for still which I considered. btw AC/dc for ad600 cost optionally +$150 it may apply in here as well as I cant see it included.
Yep.
SLB60 is photo light, it is not for video, hence such approach.
Godox is photo company that originated from flashes and such.
I know, but much more expensive, and battery part is custom, so very little use.
https://www.amazon.com/Version-Outdoors-Portable-Continuous-Photography/dp/B0721BJ4CJ/
PV US Lab, Godox SL60W Noise measurement at 30 centimeters
PV US Lab, Godox SL60W Noise measurement at 1 meter
                  PV US Lab, Godox SL60W Illuminance at 1 meter
