it's just too much blue what you want to dial in. It's a well known issue from other 10bit log cameras like FS7 or C300. It's "only" 10bit and it's therefore still limited. If you are focussed on a sky with deeper blue you have to use a polarizer for future shots. To save this shots add luma noise like Vitaliy said
A handy wind protector for GH5:
I confirm it is a precious help in run and gun situations
Panasonic Canada
$200 off Lumix GH5 price also available at your camera dealer
Good sale on Varavon GH5 cages at B&H
https://www.bhphotovideo.com/c/product/1332453-REG/varavon_zeus_gh5_st_zeus_gh5_cage_standard.html
and
https://www.bhphotovideo.com/c/product/1332452-REG/varavon_zeus_gh5_zeus_gh5_cage_body_only.html
Yes AF is so much quicker changing the shutter angle from 180d to 179d on my native GH5 lenses
Some AF explanations from the same author YodaYeo .
hi hoping someone can ask some questions for me regarding the gh5, 10 bit vlog l and final cut pro 1. for 10 bit vlog l footage should i be using the rec709 or rec2020 colour space? 2. if my vlog-l luminance level is 0-1023 - then why in my luma scopes does my footage get clipped at 95? 3. is there a way to change how final cut pro reads the native 10 bit files from the gh5? - as in video or data levels?
all i want to know is really is final cut pro reading my 10 bit files correctly? -is final cut pro doing the right thing and clipping my footage at 95?..or should it be using the full range?..or am i talking rubbish? see attached screengrab of footage from vector scope - no footage goes above 95,,why is that?
Here's a couple of a lion dance videos from a competition I shot in November. Held in Massachusetts inside a Chinese restaurant.
Used the GH5 plus 12-35mm f/2.8 II lens. I do not have that lens anymore. Traded it in for the 12-60mm f/2.8 since I wanted a good lens that has a little bit more reach.
Shot it in 4K 60p. The video is directly off the card and so completely untouched and uploaded straight to YouTube. Not fun at all uploading big 4K 60p files.
ISO was set to 3,200. The Aperture was mostly at f/4 to f/4.5. Sometimes a little lower and sometimes a little higher. I was debating if I should choose an ISO of 1600 instead to get cleaner images but I would have had to use something like f/2.8 and I didn't want to see any focus hunting since I decided to shoot it in Auto focus mode. Yes, I was sort of testing the new firmware update with this event to see how the auto focus would handle. Who knows, maybe I should have chosen an ISO of 1600 but too late now.
Still have a lot more footage of this event to upload to my channel.
I would suggest reading this article: http://blog.josephmoore.name/2016/05/10/v-log-l-a-bit-bucket-half-full/
My trip to Brasil. GH5 + 12-35mm :) Great adventure machine, good battery, dual I.S.
GH5 slomo test at Milan Fashion Week. 150fps and 180fps
Varavon ZEUS Standard Cage for Panasonic GH5 for $209
Wandering with the GH5, trying to capture fleeting moments... this was shot in 4k 50fps with an Atomos Ninja Inferno:
This is a video I made about a hole Friday procession in a small Mediterranean island 4K 60p slowed at 40% on a 24p timeline Link from Facebook , i dunno how to let preview visible here https://www.facebook.com/permalink.php?story_fbid=581811658845444&id=100010498454306
Please do not post sole links. Add meaning to this.
A video and music piece about the Titlis mountain in Switzerland ad the way to it's top.
Image video for home builders. Unfortunately a small budget, not everything was able to be done, and deadlines.
Gh5, Phanton 4 PRO. Samyang lens and Nikkors, Metabones Speed Booster, Arri HMI Lights. Premier, Davinci, Nuke for a small cleanup.
Long version and tv spot
The second version of the color, brighter in contrast, more yellow, a little unreal color but I like it :)
@peaceonearth That was absolutely fantastic. Imagery and editing were just incredible.
@rezyserzycia Love your unique style. The intro with the frenetic cuts was still not jarring with the use of the warp effects. Top notch.
Any way to mute the left Chanel of the GH5 during playback? (But still record the left and right channel as normal)
Not in post, but for playback in the moment on set.
