variable frame rate test 48 and 2 fps ( at 24p )
Tsutomu Mori interviews
@Vitaliy How is the "Utter failure" going? ;-)
What is the dynamic range of the camera?
Find the mirror nearby and will see :-)
Found the mirror and the reflection of the GH5 looked amazing, just as Panasonic promised! :-)
Shot with the GH5 (Vlog) and Voigtlander 17.5mm:
Our video about best GH5 cage on the market
can't wait until it pops up in special deals
An interesting RAW image comparison: Panasonic GH5 vs Nikon D850, normalized resolution and NR 0. Pretty impressive results for it's sensor size, won't you say?
The GH5 is noisier with half exposure.
@Manu4Vendetta I see pretty much the same noise at one stop lower ISO for a sensor 3,8 times smaller. This is an achievement considering the difference in sensor size between the two, if both wold have used the same tech, the GH5 should have been two stops noisier (not one stop). :)
I found a setting in PC Potplayer which plays my GH5 4k 60P buttery smooth with low (20%) CPU load and 35% GPU load. With default settings my 6 years old computer uses 100% CPU / 5% GPU and the play is choppy. -Vesku
The odd thing is my computer wont play GH4/GH5 4k 30P smoothly with any settings. It always drops some frames. How can it be possible that 4k60P plays better and perfectly?
RED VS GH5 Camera Test
